Service Advancetrac - Mustang Evolution
Old 01-30-2013, 06:02 AM   #1
Untamed5.0's Avatar
Service Advancetrac
I just started having an issue today where after I pull my key out of the ignition the gauge cluster comes on and off and then eventually it comes on and says "Service Advancetrac". After a few moments it goes off and gauges go off and the security indicator flashes like normal. After exiting the vehicle and locking it things seem ok. Then the gauges start to flash again and the same message appears. Any reason why this is happening? NOTE: vehicle is BAMA tuned.
Untamed5.0 is offline   Reply With Quote
Old 01-30-2013, 06:22 AM   #2
Untamed5.0's Avatar
UPDATE: Flashed back to stock and now the "Check Engine" light is on and the "Security" light is flashing.
Old 01-30-2013, 10:50 AM   #3
sprdave's Avatar
Why not try disconnecting your battery for 10 minutes.It might reset everything.
sprdave is offline   Reply With Quote
Old 01-30-2013, 10:51 AM   #4
Untamed5.0's Avatar
I disconnected the battery and touched the ends of the cables together for 10 seconds and it fixed the problem. Compliments of a Ford technician lol WIN!
Old 01-30-2013, 11:11 AM   #5
Check your battery condition. random electrical glitches can be caused by fairly slight undervolt conditions on a modern car.
Old 01-30-2013, 04:01 PM   #6
Site Sponsor
Sponsor
AMWill's Avatar
Agreed, check your battery's condition. Battery issues usually cause weird results. Plus, there's no reason the Bama tune should cause this symptom.
Let us know how you make out!
Shane
Toll Free: 866.727.1266
Free Same-Day Shipping!
Old 01-30-2013, 07:20 PM   #7
Untamed5.0's Avatar
Whew all is well after disconnecting and reconnecting the battery. That was quite a scare!
Old 01-31-2013, 06:00 AM   #8
Untamed5.0's Avatar
Ok I thought all was well but it is doing it again this morning and I tried what I did yesterday with the battery with no luck this sucks
Old 01-31-2013, 11:17 AM   #9
nhcowboy's Avatar
Sounds like the next step is to check your battery... Maybe replace... Perhaps a short somewhere too?
2011 Black Mustang GT Premium
Corsa XO & Sport AB/Airaid/Bama 93R
Best 1/4 mile to date 60' 2.009
12.538 ET @112.33
100+ Deg 85 Hum RPR 3PM 1/2 tank street tires
nhcowboy is offline   Reply With Quote
Old 01-31-2013, 03:21 PM   #10
Untamed5.0's Avatar
Just had the battery replaced less than 1000 miles ago by the Ford dealer.
Old 01-31-2013, 04:05 PM   #11
redbeast0712's Avatar
Region: Nevada
You said your check engine light came on. What is the code?
redbeast0712 is offline   Reply With Quote
Old 02-01-2013, 11:19 AM   #12
Untamed5.0's Avatar
I checked it but it said there were no codes. Weird.
Old 02-01-2013, 11:33 AM   #13
Region: Nevada
That is weird. Well does your advactrac still work. Can you turn it off and on still. I don't know to much about how it works.
Old 02-01-2013, 04:30 PM   #14
Site Sponsor
Sponsor
AMWill's Avatar
Untamed5.0,
It is possible to have a battery with a cracked or damaged cell. That might be the case for you brand new battery. You should have it tested, just in case.
Next time a CEL comes on, keep your tuner in the car so you can check it right away. The CEL will help point us in the right direct!
Shane
Old 02-02-2013, 05:08 PM   #15
Untamed5.0's Avatar
Thanks for the replies. I haven't had an issue in the past few days. This is really strange. The next time I do I'll be prepared with tuner in hand.
Old 01-30-2016, 07:28 AM   #16
So did you find a repair untamed 5.0? I believe my 2011 Gt is having the same issue
Nascarfan758 is offline   Reply With Quote
10:46 AM
