Shifting in the cold - Mustang Evolution
Old 02-02-2013, 11:54 AM   #1
Entotalenigma's Avatar
Hey guys! I just wanted to make sure my car doesn't need to be looked at. I live close to Canada in northern ny and the temp in winter ranges from -20 to 30 Fahrenheit. I warm up the car for 5-10 min but it is always really hard to shift until I've been driving for a while. Is this common?
Entotalenigma is offline   Reply With Quote
Old 02-02-2013, 12:21 PM   #2
McQueen's Avatar
Yes, it happens to me in miami when it gets in the 60 lol. But when it gets warm up then it is all good.
McQueen is offline   Reply With Quote
Old 02-02-2013, 12:22 PM   #3
sprdave's Avatar
Yes,it seems to be a problem for some m82 Transmissions.From what I have read
Ford on the 13s have all changed the fluid to dual clutch transmission fluid.This is
suppost to fix this.On my 12 v6 I just put a barton two post shift bracket in along with a SR performance short shifter and drained and kept the transmission fluid and put in
Redline MTL fluid in mine.I have almost no problems now.
sprdave is offline   Reply With Quote
Old 02-02-2013, 12:45 PM   #4
That sucks 60's I thought at that temp I would be ok so I guess I might have this problem all year round. The only thing that sucks is that when you are accelerating it slows you down because you have to fight with the shifter.
---------- Post added at 02:45 PM ---------- Previous post was at 02:43 PM ----------
What temp do you drive in?
Old 02-02-2013, 03:48 PM   #5
smokeum's Avatar
My '13 doesn't like to shift (< 30 deg) until after I drive a few miles, expecially the 1 - 2 shift.
smokeum is offline   Reply With Quote
Old 02-02-2013, 05:05 PM   #6
MustangForEver's Avatar
Really common if you own mt82 transmission you have clunky shifts untill.its warmed up
MustangForEver is offline   Reply With Quote
Old 02-02-2013, 05:11 PM   #7
Untamed5.0's Avatar
I have this problem whenever it's really cold outside. I'm going to switch the fluid to see if that fixes the problem.
Untamed5.0 is offline   Reply With Quote
Old 02-02-2013, 05:44 PM   #8
Warming up the car idling won't do jack to warm up the transmission, it's just gently turning the input shaft. Changing to QDC, which your Ford dealer will do for you free if you ask nicely, will deal with alot of this without worries about warranty hassle from DIY should the unfortunate happen.
Old 02-02-2013, 08:15 PM   #9
What is qdc?
Old 02-02-2013, 08:34 PM   #10
Loc: Austin,TX
Pretty common deal but once she warmed up she shifts as smooth as butter.
Old 02-02-2013, 09:04 PM   #11
QDC is Ford's dual clutch fluid. It's thinner than the QS fluid that's in there and is quicker to move around and warm up in cooler weather. It's the standard fill now for the MT-82 and is actually pretty decent stuff.
05:47 PM
