Ford Racing Tuner - Mustang Evolution
Old 02-02-2013, 04:23 PM   #1
JJB82's Avatar
Ford Racing Tuner
I'm setting up the tire size on my Ford racing tuner. I have a 2012 mustang gtcs. My tire size is 245/45/19. Does anybody know what the revolutions per mile is?
JJB82 is offline   Reply With Quote
Old 02-02-2013, 04:46 PM   #2
Grabber Blue5.0's Avatar
729
Old 02-02-2013, 05:31 PM   #3
JJB82's Avatar
By default it was set to 740. Will changing it to 729 make much of a difference?
Old 02-02-2013, 06:41 PM   #4
Yes.
Old 02-02-2013, 07:46 PM   #5
back n a stang's Avatar
Easy way to keep up with speed changes is by looking at overall height. For example.... if it was factory tire and rim and the overall height was 27.8 and you made a change to a tire that is gonna give you a new overall height of 27.9 or something like this that close then no its no biggie.Gear changes can throw major change too. If you go to a 18" wheel then more sidewall can correct it.More sidewall can be a good thing by the way.As for 20"" you may need to drop to smaller profile. I had 19x9 brembo wheels with the factory perilli's.I bought some drifts in 19'' and staggered them. I think mine are (F) 245/40/19 in front and 285/35/19 rear.Both are Hankooks and height is very close to factory tire heights. Hope this helps....JMO man..... If you would like to know specs Tirerack gives a good breakdown of all these measurements
Old 02-03-2013, 05:17 AM   #6
Use this for future reference.
Tire size calculator
Old 02-03-2013, 07:34 AM   #7
JJB82's Avatar
I try to select 729, but the closest it will allow me to select is 733. I can't go any lower than that. Should I select 733 since its closer to 729 or leave it at its default setting of 740?
Old 02-03-2013, 07:50 AM   #8
Set it at 733 and don't give it a second thought.
Old 02-03-2013, 08:26 AM   #9
JJB82's Avatar
Thanks hopefully ill notice some kind of difference
02:02 PM
