Which CF DS? - Mustang Evolution
Old 02-08-2013, 06:51 PM   #1
Joyride's Avatar
Which CF DS?
I am looking into buying a carbon fiber driveshaft This week and am wondering which one to buy? Will the Shelby one fit? Which is lighter and/or cheaper? Thanks guys
Joyride is offline   Reply With Quote
Old 02-08-2013, 07:17 PM   #2
alrefire's Avatar
The shelby won't fit, I think, because it had a dofferent transmission
Old 02-08-2013, 08:29 PM   #3
The Blue Dragon
GrabberBlue5.0's Avatar
Shelby DS will not fit. Why CF DS? Just get aluminum. They're still good for 900 hp and only about 2-4 lbs heavier, which isn't enough to justify the money IMO.
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 02-08-2013, 08:31 PM   #4
McQueen's Avatar
Ds is a great upgrade but there are soooo many more mods to be done first and that will make a bigger difference. But that is just my opinion, i will not get a ds till i get a blower.
Aluminum should be just as good as CF and alot less $$$.
McQueen is offline   Reply With Quote
Old 02-08-2013, 08:35 PM   #5
The Blue Dragon
Meh, I disagree, I believe there is a lot to be had from aluminum DS. Less parasitic drivetrain loss, vehicle will run more efficiently and there will be less stress on the entire power train due to less mass being rotated, not to mention it frees up rwhp.
Now the order in which you buy it is completely up to you
Old 02-08-2013, 08:39 PM   #6
McQueen's Avatar
I never said that it was a bad buy or a waste of money, all i said the order which he is doing it is unusual but like you said it is completely up to the owner.
Old 02-08-2013, 09:27 PM   #7
The Blue Dragon
What order is he buying mods? I don't know what other mods he has. Honestly if you want more power and better economy, this is probably one of the best ways to go, doesn't even require a tune.
Old 02-09-2013, 04:46 AM   #8
McQueen's Avatar
He just got it a week or so ago i believe. How much is the mpg difference with the ds??
Old 02-09-2013, 05:22 AM   #9
Grabber Blue5.0's Avatar
Little to none.
While an aluminum drive shaft is a good upgrade there are many other things I'd do first. The OP needs to give us a lot more info like if he has an auto or manual, what he's already done, and what is the cars primary goal?
Old 02-09-2013, 03:26 PM   #10
Joyride's Avatar
Ok, right now I have an mgw shifter, axlebacks and boss side exhaust. I will not do anything that will void the warranty. Ultimately, I am installing the roush blower with a complete suspension setup. It's a manual track pack gt. I was thinking carbon fiber because I heard that they were lighter and don't cause as much noise. Price isn't a big deal as long as the CF is not more than 450 over the aluminum.
Old 02-09-2013, 04:32 PM   #11
McQueen's Avatar
I am pretty sure a DS would void your warranty even tho it is lighter or whatever. Because you are messing directly with the drivetrain.
Old 02-09-2013, 05:47 PM   #12
Joyride's Avatar
Darn. Can the stock driveshaft handle 575 crank hp?
Old 02-09-2013, 05:51 PM   #13
nosympathy's Avatar
Think there are some people on here with them holding up too 600HP at the wheels.
Old 02-09-2013, 05:54 PM   #14
McQueen's Avatar
Yes, the roush stage 3 has 575 and it has the stock gt DS.
Old 02-09-2013, 06:18 PM   #15
Joyride's Avatar
Actually, I have a good relationship with my dealer. Maybe they will let me use the aftermarket driveshaft. Anyways, can't I just reinstall the stock one when I go in?
Old 02-09-2013, 06:21 PM   #16
nosympathy's Avatar
Yeah you can ask them, some won't care.
And yes you can reinstall it. Just seems like a full on PITA.
Old 02-09-2013, 06:33 PM   #17
alrefire's Avatar
How are you going to hit 575 hp without voiding warranty
Old 02-10-2013, 11:26 AM   #18
Joyride's Avatar
Roush supercharger phase1 . Keeps your power train warranty. Ill just go with the DSS since no one has posted their opinion of a CF driveshaft.
Old 02-10-2013, 04:18 PM   #19
Bladezx's Avatar
I've seen videos of ones up 700-800 hp with stock tranny and driveshaft.
Bladezx is offline   Reply With Quote
Old 02-10-2013, 08:05 PM   #20
The Blue Dragon
I recently purchased the dss aluminum DS, but have yet to install it. The CF DS just isn't worth it IMO to drop an extra 4-500 to she'd just a couple more pounds
Old 02-10-2013, 08:09 PM   #21
McQueen's Avatar
+1
Old 02-11-2013, 06:35 AM   #22
I have the aluminum ds and in my opinion that one mod alone was the most noticeable gain of all the mods, except410 gears, the ds feels like u gain 25 hp even tho its just less rotational weight, the minute u pop the clutch u feel it...!
Boss IM, with Araid cai, bama 93 race tune, GT500 cat back, jba off-road x-pipe & longtubes, mgw shifter,4.10 gears, Aluminum Flywheel & driveshaft, Adjustable Panhard Rod, BMR adj. uca & lca, BMR relo. brackets, BMR Springs with 1.5" drop, BMR adj. swaybar, BMR tubular K member 1/2 drop motor mounts & BMR tubular A arms, steeda alu. rad. support, aluminum water pump pully, 85mm BBK TB, Rear seat delete. Boss oil cooler, Battery in trunk. AC delete, Evap delete
brianw64 is offline   Reply With Quote
Old 02-11-2013, 06:51 AM   #23
Joyride's Avatar
On lethal performance, it's 350 more. Supposedly it reduces cabin noise a lot. Every bit of weight helps.
Old 02-11-2013, 06:56 AM   #24
tc x 4's Avatar
I agree on the CF, if your spending $700+ on a DS to start with, what's $350 more. A few #s less in rotating mass is a huge difference.
Old 02-11-2013, 07:02 AM   #25
The Blue Dragon
I got my DS for $670 shipped to my door brand new, lethal charges $1100? I think, shaftmasters can be had for right at $600. Still not worth it IMO, even if you could get the CF DS for $1000 even it still wouldn't be worth it unless you just had to drop every ounce of weight possible
Old 02-11-2013, 11:56 AM   #26
Joyride's Avatar
Where did you buy it and did you use a sale code?
Old 02-11-2013, 12:11 PM   #27
The Blue Dragon
Sent you a pm joyride
Old 02-12-2013, 07:40 AM   #28
GrayGhost's Avatar
I don't know... maybe if one is concerned about the manner in which a driveshaft may fail, a carbon fiber unit might be a good idea to invest in rather than a one-piece aluminum unit. Both a stock or one-piece aluminum driveshaft have the potential of wreaking havoc on the underside(and inside through the floorpan!) of your car. Carbon fiber has the added plus of absorbing more of the drivetrain harmonics. With that said, I don't see an aluminum unit failing at your eventual power rates.
Get your suspension done, first... I would recommend DSS or PST.
2011 Mustang GT Premium 401A Spec- Sterling Gray, aka "Graycie", 6-Speed MT, 3.73, Brembo Brake Package, Current Mods: FRPP-Brakelines/Brake Ducts/Alternator/Radiator/Oil Pan/Oil Cooler/Trans.Scoop/Alum.Axle Cover, Steeda-Sport Springs/3rd Link/Adj.UCA/Alum.LCA/Rel.Brackets/Adj.PHB & Brace/Adj.F&R Swaybars/Adj.Front Endlinks/HD Strut Mounts/X11 Ball Joint/Bumpsteer/CAI, Koni Sport Shocks, ATI Damper, MGW Shifter, Kooks Catback, Wavetrac Diff, Michelin Pilot Super Sport... 93 Octane Performance Tune by VMP
GrayGhost is offline   Reply With Quote
Old 02-12-2013, 08:59 AM   #29
The Blue Dragon
That's why you buy the front DS safety loop
Old 02-12-2013, 09:28 AM   #30
Joyride's Avatar
Why suspension first?
Old 02-12-2013, 09:55 AM   #31
GrayGhost's Avatar
PST requires you to take a measurement. They suggest all suspension work be completed before doing the driveshaft. Suspension modifications change the geometry(pinion angle) and can alter the articulation of the cv-joint, I think. DSS does not require any measurements, for some reason.
Old 02-12-2013, 10:03 AM   #32
GrayGhost's Avatar
I agree... for both OEM or aftermarket aluminum shafts, but it kind of defeats the purpose of dropping a significant amount of weight, then adding a little more weight with the safety loops. As long as it's not rotational mass you are adding, I guess it's not that bad.
04:40 AM
