GT500 fuel pump - Mustang Evolution
Old 02-11-2013, 08:06 PM   #1
GT500 fuel pump
How much power can the gt500 fuel pump setup m-9407-msvta can handle? I got 410whp on a M/dyno and i need more fuel, i don't want to buy this and top out at 450 because of lack of fuel! And yes, i'm boosted!
keving54b is offline   Reply With Quote
Old 02-11-2013, 08:56 PM   #2
I also have a blower in my 2011 (Vortech). Vortech sells an electronic voltage controller (just like the Kenne Bell Boost-a-pump) that might be what you are looking for. It overdrives your fuel pump to deliver more fuel as the boost pressure increases. Works flwalessly for me with 664 HP (554 rear wheel). This is hooked to the stock 2011 Mustang GT pump. PM me if you need more info...
2011mustanggt is offline   Reply With Quote
Old 02-11-2013, 09:06 PM   #3
I have a 2010 gt with a KB Boost a pump and at 5500 a had to lift cause it went lean. From what i've seen the 11+ fuel pump are verry good!
Old 04-18-2014, 01:12 PM   #4
Does anyone else make a boost a pump type device?
Old 04-18-2014, 06:32 PM   #5
https://www.msdignition.com/Products...e_Booster.aspx
Old 04-20-2014, 06:10 PM   #6
Is the GT500 2013 fuel pump same as a 2013 Base GT? I have a chance to acquire gas tank with fuel pump for $150. I have plans to add a vortec next year..
NoTop5.0 is offline   Reply With Quote
Old 04-21-2014, 06:18 PM   #7
Nop, coyotes use a single pump and gt500 dual pumps. You will also need a second module for the extra pump + power supply. If you are going FI buy this Ford Racing High Performance Mustang Dual Fuel Pump Kit M-9407-GT05 (05-09 GT) - Free Shipping - AmericanMuscle
Saves you time and problems down the road and easy to up grade the pumps if needed.
04:51 AM
