Mickey Thompson Street Comp vs Nitto INVO - Mustang Evolution
Old 02-23-2013, 08:40 AM   #1
2013fiveO's Avatar
Does anyone have any experience with either of these tires? I’m looking at getting them from AM in 255/40/19. The MTs $239.99 are cheaper but are the Nittos $274.99 worth the extra $140 a set?
2013fiveO is offline   Reply With Quote
Old 02-26-2013, 01:45 PM   #2
BigHead2010's Avatar
Same here. Whatre you going with for the rear
BigHead2010 is offline   Reply With Quote
Old 02-26-2013, 01:48 PM   #3
2013fiveO's Avatar
Well I was gona go 255/40-19 but after some reading it looks like 285/35-19s will fit all around. I may go that route.
Old 02-26-2013, 02:05 PM   #4
Ya im trying to dexide what I shld do on my 19x8.5 and 19x10 amrs im thinkin 255/40 and 285/35
Old 02-26-2013, 02:10 PM   #5
The Blue Dragon
GrabberBlue5.0's Avatar
285's will work fine all the way around. What size wheel? I saw 19" but what's the width?
I just did a little research on the MT tires, they're owned by cooper and very similar to the cooper rs3-s, and those are excellent tires. The people that have then love them. Save yourself some money and give the mts a try, unless you need an all season tire. Then the invos are the way to go
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 02-26-2013, 02:13 PM   #6
2013fiveO's Avatar
I have the Brembo package. The ford spec sheet says they are 19x9 but I've read a few threads saying they are 19x9.5. ?
Old 02-26-2013, 02:17 PM   #7
The Blue Dragon
Nah, they're 19x9's. 285's on those wheels will be fine all around, with the proper offset you get even run 19x10's all around
Old 02-26-2013, 02:17 PM   #8
The Blue Dragon
I would not go any wider than 285 though
Old 02-26-2013, 02:19 PM   #9
2013fiveO's Avatar
Thanks for the info.
Old 02-26-2013, 02:23 PM   #10
The Blue Dragon
No problem!
Old 02-26-2013, 02:25 PM   #11
What wld you recommend for 19x8.5/19x10 charcoal amrs from am? What size and what tire?
Old 02-26-2013, 02:36 PM   #12
The Blue Dragon
What are you trying to accomplish? Is this a street car, autox, drag car, dd? What are you end goals?
Old 02-26-2013, 03:10 PM   #13
Dd street car, and maybe around 450 hp by the time im done nothing serious
Old 02-26-2013, 03:52 PM   #14
The Blue Dragon
Staggered wheels and tires will cause a "push" in the corners. But you would be fine with any decent all season. 255/40 and 285/35 19 should be pretty good. If you're wanting something super aggressive the maybe go 295 or even 305 on the rear. As far as tires are you looking for traction, quiet, tread life, cheap?
Old 02-26-2013, 03:55 PM   #15
McQueen's Avatar
Yea but the push can be easily control with the right pedal and that is FUN!!!
McQueen is offline   Reply With Quote
Old 02-26-2013, 04:00 PM   #16
I just order 245/45 and 275/40 bfg gforce 2. Decided I'd rather have a little more sidewall
Old 02-26-2013, 05:20 PM   #17
The Blue Dragon
That's not a bad size either, I have the bfg kdw2s and they're pretty good
Old 02-26-2013, 10:25 PM   #18
UOP Shadow's Avatar
Looking at the nittos for our alcoa 20s for our 2013 GT500.
2013 Ford Mustang SVT 20th Anniversary Cobra Shelby GT500. Stock, almost.
UOP Shadow is offline   Reply With Quote
Old 02-27-2013, 04:50 AM   #19
I have the Mickey Thompson ET Street Radial II - 305/35-19 on 10" rims and love them...its nice that there is no wheel spin anymore, you have to really want to light these up to get them to spin...!
Boss IM, with Araid cai, bama 93 race tune, GT500 cat back, jba off-road x-pipe & longtubes, mgw shifter,4.10 gears, Aluminum Flywheel & driveshaft, Adjustable Panhard Rod, BMR adj. uca & lca, BMR relo. brackets, BMR Springs with 1.5" drop, BMR adj. swaybar, BMR tubular K member 1/2 drop motor mounts & BMR tubular A arms, steeda alu. rad. support, aluminum water pump pully, 85mm BBK TB, Rear seat delete. Boss oil cooler, Battery in trunk. AC delete, Evap delete
brianw64 is offline   Reply With Quote
Old 02-27-2013, 04:53 AM   #20
McQueen's Avatar
How about wet traction??
Old 02-27-2013, 05:30 AM   #21
not much wet traction, but u can drive in the rain, carefully.... but if your running street slicks u gotto be prepared for that....
Old 02-27-2013, 05:34 AM   #22
McQueen's Avatar
Yea same with the michelin ss i have, not a fan of the rain
Might give them a try next.
Old 02-27-2013, 05:41 AM   #23
The Blue Dragon
Aren't these bias ply tires?
Old 02-27-2013, 06:48 AM   #24
What year car? I want a 305/35 but didn't know if it wld fit my 2011 the offset is +40
Old 02-27-2013, 06:59 AM   #25
2012 and not sure if they are a bias ply or not, i know they do not break free unless u really hammer it!!
Old 02-27-2013, 07:11 AM   #26
The Blue Dragon
Bias ply tires have a lot more sidewall flex than radial tires (which most street tires are radial tires). Most MT drs and slicks are bias ply. Are those tires DR's?
I'm only asking because I would like to know how they feel on the street while turning
Old 02-27-2013, 07:43 AM   #27
Black5.0's Avatar
They're radials. They're awesome on the street, like he said, really have to try to spin em. I was caught in the rain with em a few times, even on highway. They were fine, just drive like you know they're on there.
Black5.0 is offline   Reply With Quote
Old 02-27-2013, 08:47 AM   #28
+1 on what black5.0 said , they are awesome but if you want to go and not spin at red lights or drag?? u wont spin...!!
Old 02-27-2013, 09:04 AM   #29
Stang8psi's Avatar
Region: Delaware
Nitto invos are not all season tires!
Stang8psi is offline   Reply With Quote
Old 02-27-2013, 09:24 AM   #30
The Blue Dragon
You are correct, I saw the tread pattern and siping on the tires and thought it was, the tread pattern looks convincing enough to be an all season though.
Old 03-08-2013, 08:09 PM   #31
UOP Shadow's Avatar
Who is running the invos?
Old 03-09-2013, 05:41 AM   #32
Ravnus's Avatar
I have the BF 275/40/19's in the back. Wish i had gotten the 275/35/19's because the 40 tire is tall in the back and car sits up a little.
Ravnus is offline   Reply With Quote
Old 03-09-2013, 07:35 AM   #33
OzzyLiriano's Avatar
Right here, and they are amazing!
275/35/20
295/35/20
OzzyLiriano is offline   Reply With Quote
Old 03-09-2013, 08:25 AM   #34
UOP Shadow's Avatar
275/35/20
295/35/20
Attachment 94879
Nice. How are they in the rain & cold? I need to order some meat in the next week to get this bad boy on the road with style!
Old 03-09-2013, 09:12 AM   #35
Can't tell u, i live in miami but havent had rain just yet
06:02 AM
