2013 5.0 Gears? - Mustang Evolution
Old 02-24-2013, 12:21 AM   #1
FORDGT14's Avatar
Question 2013 5.0 Gears?
I've got a 2013 5.0. I cant seem to decide on which gears to go with, Im caught between 3.73's or 4.10's... I read that there really isn't a big difference in gas milage between the two if you have a 6 speed manual, which is what I have. If that's true, then I'll definitely go with the 4.10's, but if it completely kills gas milage, then I'll most likely go with 3.73's.
I do some freeway driving, but I'll be moving into the city within the next few months, so I won't be making the long freeway drives anymore.
Let me know what you guys think and what your experiences with the two are. I'd like to order the gears on Monday if I can figure out which ones to get by then.
Thanks,
Cameron.
FORDGT14 is offline   Reply With Quote
Old 02-24-2013, 12:26 AM   #2
nosympathy's Avatar
Thanks,
Cameron.
ok, there are other threads with this answer, but you have to throw some things out there first.
What gears are you currently running?
Are you planning on doing FI at some point?
Are you installing the gears yourself?
Old 02-24-2013, 12:37 AM   #3
Hard to go wrong with 3.73's...
Matt K is offline   Reply With Quote
Old 02-24-2013, 12:56 AM   #4
FORDGT14's Avatar
I have stock gears, I believe they are 3.31's. and yeah I'd like to go FI eventually. And no, I'm having a shop do it.
Old 02-24-2013, 01:06 AM   #5
nosympathy's Avatar
4.10 are too steep for FI so unless you want to change them out later 3.73 are your best bet. I went from 3.31 to 3.73 and it is a huge difference.
I only asked about having a shop do it as a lot of shops seem to run gear specials where you buy everything from them and they give you a discounted deal. I got my gears done for 550 which included everything. 3.73 frpp gears, royal purple fluids, rebuild kit, etc.
Old 02-24-2013, 08:07 AM   #6
Smoke's Avatar
+1 same price here .u might have to buy a tuner to adjust your speedo
Smoke is offline   Reply With Quote
Old 02-24-2013, 08:18 AM   #7
Jetag93's Avatar
I think the dealer can reset the speedo calibration too.
2013 DIB Premium GT/CS, 6MT, Cervinis Ram-Air Hood, RTR Charcoal 19X9.5s, BBK Cat Deletes & X-Pipe, DMH E-Cutouts, GT500 Rear Diffuser w/GT500 Quad-tip Axle-Backs, AED E85 Lope Tune, Boss 302 Intake, BBK 85mm TB, JLT CAI, Dynatech Alum DS, FRPP 3.73's, Eibach Pro-Springs and Pro-Struts/shocks, J&M Adj Panhard Bar, UPR Billet Alum LCA's, BMR UCA & Bracket & Relo Brackets, Eibach Adj Sway Bars, MGW Shifter, Brembo brake kit w/14" slotted 2 piece Boogie Full Tilt Racing Rotors, Llumar 30/5 Tint
Jetag93 is offline   Reply With Quote
Old 02-24-2013, 08:35 AM   #8
Boomdizzle's Avatar
I'd go with the 3.73's. I always had the opinion that that is the perfect gear for a DD.
Torque: It's like crack for your right foot
Boomdizzle is offline   Reply With Quote
Old 02-24-2013, 09:45 AM   #9
gtstyles2's Avatar
I hear going to 4.10 1st gear will be practically useless
Old 02-24-2013, 09:54 AM   #10
Smoke's Avatar
O ok
Old 02-24-2013, 11:25 AM   #11
FORDGT14's Avatar
Ok, looks like I'm going with 3.73's then, thanks guys.
Old 02-24-2013, 11:25 AM   #12
2011 Kona Blue's Avatar
The factory stock gears in the 2013 GT are either 3:15, 3:55 or 3:73. Only factory 3:31 gears are offered on the V6 model. So which factory gear ratio did you get when you purchased your 5.0
Old 02-24-2013, 11:27 AM   #13
FORDGT14's Avatar
I honestly have no idea.. I got the '13 Premium 5.0 and thats really all I know. Where could i look to find out?
Old 02-24-2013, 11:30 AM   #14
Jetag93's Avatar
Wrong. The standard 6mt gear for GT is 3:31 with options for 3:55 or 3.73.
Old 02-24-2013, 11:34 AM   #15
Well I know the auto has 3:15 not 3:31. So your saying the manual has 3:31. Learn something new every day. Very interesting. I wonder why Ford would use a different gear ratio for the automatic compared to the manual. Since the OP has manual, he could have either 3:31, 3:55 or 3:73 factory gears.
Old 02-24-2013, 11:37 AM   #16
Jetag93's Avatar
You have 3:31 unless ur sticker shows a different gear option.
Old 02-24-2013, 11:39 AM   #17
Kamman's Avatar
Where your gears are located look for a plate should be stamped what gears are in your rear diff.
Kamman is offline   Reply With Quote
Old 02-24-2013, 11:41 AM   #18
I was told it has a code on the inside door panel of the drivers side seat
Old 02-24-2013, 12:03 PM   #19
redbeast0712's Avatar
Region: Nevada
It on the divers side door I believe mine is yy for 3.15 I'm not sure what the others ones are
---------- Post added at 10:03 AM ---------- Previous post was at 09:58 AM ----------
This is from another thread on here.
You can check either the sticker on your differential or the door jam sticker on the driver's side:
The Ford axle ratio codes are:
BB - 3.73 ratio
CC - 2.73 ratio
DD - 3.55 ratio
GG - 3.31 ratio
YY - 3.15 ratio
redbeast0712 is offline   Reply With Quote
Old 02-24-2013, 12:25 PM   #20
Kamman's Avatar
That is True ! Just looked Again my is on the door as well. shows a Rear Sprocket type code GG but also has a stamp on my rear end of a 3:31
Old 02-24-2013, 02:28 PM   #21
Grabber Blue5.0's Avatar
Because the gears in the 6R80 are different than the MT82.
Old 02-24-2013, 10:15 PM   #22
Villero1834's Avatar
Window sticker should say it , if not look at your rear axle and there should be a sticker that says which one you have .. Mine says 3.73
Villero1834 is offline   Reply With Quote
Old 02-26-2014, 09:40 AM   #23
2013 5.0 AT
I just ordered 3:55 Ford Racing gears for my 13 auto..did a bit if research but just wanted input on the differences…thx
jmorg is offline   Reply With Quote
Old 03-05-2014, 04:00 PM   #24
bellski's Avatar
I have 410 gears on mine. I drove it from Milwaukee to Myrtle Beach last summer for Mustang week- got 22 mpg avg on the trip. Didn't think that was too bad. Turning about 2200 rpm at 72 in 6th gear.
2011 GT M6 Premium- Mechanical upgrades include: Boss 302 Intake, JLT CAI, JPC LT Headers, Off Road X Pipe, and mufflers, 410 Gears, Granatelli Hot Street Coil Packs, 93 Octane Ghost Cam Tune by Jon Lund,Eibach ProKit Springs,shocks, struts and sway bars, BMR LCA's, Strut Tower Brace, and adjustable Panhard Bar, Maximum Motorsports Camber/Caster Plates, Barton Shortshifter and bracket, Wilwood Superlight Brakes w/6 and 4 piston calipers, Steeda Spyders- 9-1/2X20 with 275/35 and 11X20 with 315/35 Nitto Invos.
bellski is offline   Reply With Quote
04:24 AM
