Tire fitment question - Mustang Evolution
Old 02-24-2013, 03:50 PM   #1
Hi everyone, I am looking to buy some 19x9 wheels with a +42 offset and want to run 275/40/19's on them on all four corners if possible. Anybody have this setup or know if it will fit up front? It looks like it would be really tight but may work. Thanks
kk89 is offline   Reply With Quote
Old 02-24-2013, 03:55 PM   #2
jayman33's Avatar
You wont have any issue running those. Why are you deciding on running a 19x9 rather than a staggered setup or 19x9.5?
jayman33 is offline   Reply With Quote
Old 02-24-2013, 03:57 PM   #3
the wheels i found that i like only come in 19X9 and 19X10 and i really would like to be able to rotate tires if possible. Boss 302s wheels (like on the laguna secs)
Old 02-24-2013, 04:00 PM   #4
The Blue Dragon
GrabberBlue5.0's Avatar
There's a guy on another forum running 20x10's on all four corners and 305 tires, I think he may have a +42 offset
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 02-24-2013, 04:02 PM   #5
Do you think i should run the 275's all around on 19x9 or would it be better to get the staggered set and run 245/45/19 up front and 275/20/19 out back (they are exactly the same height is why i chose these two sizes)
Old 02-24-2013, 04:05 PM   #6
jayman33's Avatar
Honestly I would go for the Staggered setup. I wouldn't go 245/45 up front 255/40 is a little better and should be about the same price. Also take a look at 285/35 for the rears. If you're gonna go staggered that's a pretty good size and the sidewalls will be very similar in size.
Old 02-24-2013, 04:07 PM   #7
i want to get continental extreme dws and they are not offered in a 255/40, and i was a little worried the 285 would stick out to far.
Old 02-24-2013, 04:09 PM   #8
Redstang1's Avatar
I'm ordering 275's all the way around in my stock brembo wheels. You will be fine just have a little bulge but should look really goos
Redstang1 is offline   Reply With Quote
Old 02-24-2013, 04:10 PM   #9
jayman33's Avatar
I don't know that offset of the 19x10's, maybe you'll be able to run a square setup of that? I would buy two and test fit before you buy the 19x9's.
Old 02-24-2013, 04:17 PM   #10
the offset for the 10 is listed as 47.5, i considered that too. My dilemma arises because it is far cheaper to buy them as a set of 4 (they basically throw the tpms and reset tool in for free)
Old 02-24-2013, 04:19 PM   #11
The Blue Dragon
I'm running 275 on 19x9's all around right now, but I'm actually in the process of getting a staggered setup from jayman33
Old 02-24-2013, 04:20 PM   #12
jayman33's Avatar
Levittbrown?
I would get the staggered setup if that's the case. Its a dang good deal they have on that setup.
Old 02-24-2013, 04:21 PM   #13
Oh cool, grabber do you happen to know what offset you have and could you comment on how close the fronts come to rubbing (there is a bolt on the strut that seems like it would be very close)
Old 02-24-2013, 04:46 PM   #14
The Blue Dragon
Eh, not sure of the offset, if someone knows the brembo wheel offset then that's what I have. Are you talking about the bolt that holds the rotor and hub assembly together to the strut?
Old 02-24-2013, 04:52 PM   #15
The bolt that looks like it would be closest is on the strut tower and it is connected to a brace that goes down to the front sway bar. If you are running factory brembo's i cant imagine the offset is much different from factory laguna seca wheels.
Old 02-24-2013, 10:05 PM   #16
On my factory Brembo 19x9" wheels, I'm running 275/35-19 front and 285/35-19 rear tires. No clearance issues or increase in bumpsteer, despite what some people claimed I would experience. Sits perfect, and my overall traction for launching and handling is GREATLY improved!
Matt K is offline   Reply With Quote
Old 02-25-2013, 01:26 AM   #17
Redstang1's Avatar
You mind posting pictures?
Old 02-25-2013, 06:25 AM   #18
Jetag93's Avatar
I'm running 275/40/19's on RTR 19x9.5 rims with +33 offset which is .35 inches less than your +42 offset so you should be fine.
2013 DIB Premium GT/CS, 6MT, Cervinis Ram-Air Hood, RTR Charcoal 19X9.5s, BBK Cat Deletes & X-Pipe, DMH E-Cutouts, GT500 Rear Diffuser w/GT500 Quad-tip Axle-Backs, AED E85 Lope Tune, Boss 302 Intake, BBK 85mm TB, JLT CAI, Dynatech Alum DS, FRPP 3.73's, Eibach Pro-Springs and Pro-Struts/shocks, J&M Adj Panhard Bar, UPR Billet Alum LCA's, BMR UCA & Bracket & Relo Brackets, Eibach Adj Sway Bars, MGW Shifter, Brembo brake kit w/14" slotted 2 piece Boogie Full Tilt Racing Rotors, Llumar 30/5 Tint
Jetag93 is offline   Reply With Quote
Old 02-25-2013, 07:35 AM   #19
TooSlow4U's Avatar
If you put street tires on for normal day to day driving Nitto Motivos allow side to side rotation. I run this setup so I can have staggered and still rotate. When I drag I throw on the slicks.
TooSlow4U is offline   Reply With Quote
Old 02-25-2013, 07:37 AM   #20
Sure, here are some I just went outside & snapped with my iphone...
Getting dynoed after reinstalling stock mufflers (don't ask)
Old 02-25-2013, 08:07 AM   #21
The Blue Dragon
His offset is +48 on all four, he said tires rubs plastic in wheel wells but that's because he's running 305's up front
Old 02-25-2013, 10:14 AM   #22
Very cool, thank you all for the help, I think I have made up my mind (maybe).
Old 03-03-2013, 01:29 PM   #23
Just a quick update and a thank you for those of you who took the time to answer my questions. I ended up getting the boss 302s wheels in a staggered fit, 19x9 & 19x10. Tires are nitro info 245/40 and 285/30. While I had the car up on jackstands i took the opportunity to bolt on some steeda lower control arms, which i really like so far in my short test drive. I also installed a steeda cai and the 93 tune to go with it, which really woke the car up. Here is a picture of the wheels (please overlook the fact the car is filthy, snowed a good bit of last week and more on the way this week).
Old 03-04-2013, 08:00 PM   #24
Nice!
El Fufi is offline   Reply With Quote
Old 03-05-2013, 11:40 AM   #25
mtuck's Avatar
Looks good
mtuck is offline   Reply With Quote
Old 03-05-2013, 01:00 PM   #26
McQueen's Avatar
19x9 and 19x10
255-40-19 and 275-40-19
After my next track day I will change then to 275-35-19 and 305-35-19.
ID:	94124   Click image for larger version
McQueen is offline   Reply With Quote
Old 03-05-2013, 05:04 PM   #27
Originally Posted by McQueen View Post
19x9 and 19x10
Isnt 275 a little wide for the front tire?
Old 03-05-2013, 09:58 PM   #28
Nope. I run it. More grip, better handling. How is that bad?
Old 03-06-2013, 12:06 AM   #29
For the rim maybe.
Old 03-06-2013, 03:25 AM   #30
For the rim maybe.
Depends on the tire used. It fits fine on mine, as shown.
04:07 PM
