Aluminum Drive shaft - Mustang Evolution
Old 02-25-2013, 07:54 AM   #1
Is it worth upgrading the standard driveshaft on the 2012 ford mustang gt with an aluminum driveshaft. Im also looking at installing a precision industry torque converter with a 3200 stall. So far I have the JLT cold air kit, boss intake and roush exhast. I drive the car daily when the weather is good so I dont want to do something that will affect its driveablity. I also like going to the track and looking for better acceleration and better launches. Thanks
Sprintradc is offline   Reply With Quote
Old 02-25-2013, 08:06 AM   #2
The Blue Dragon
GrabberBlue5.0's Avatar
Aluminum DS is absolutely worth it. I just installed mine on Saturday and can tell a decent difference. A higher stall converter will decrease streetability from my understanding but I've never owned an auto with a stall so I can't say for sure.
Look into BMR lca relocation brackets for harder launches
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 02-25-2013, 08:19 AM   #3
IanM's Avatar
+1 for the aluminum driveshaft, well worth the effort and time...
2011 Grabber Blue GT California Special, 3.73 Gears, 6-Speed Manual, Steeda CAI, Steeda 93 tune, aluminum driveshaft (The Driveshaft Shop Co.), MGW shifter, Roush axle-back exhaust, Roush Side Rocker Panel Splitters, Ford Racing BOSS 302 front splitter, sound-tube delete, painted plug covers, JLT oil separator. Shelby transmission scoop & powder-coated trunk brace & many more items...
IanM is offline   Reply With Quote
Old 02-25-2013, 10:03 AM   #4
nosympathy's Avatar
From how I understand it the stall convertor takes the energy from the engine while you are stopped and multiplies it. Kinda like starting off the line with 3.73 gears and then switching magically to 3.31 gears after the initial launch.
So pretty much every stop light your at it would feel like being in a manual car with the person dumping the clutch at every light.
If it makes driving that bad? Dunno but I can see how it would since you get all or nothing.
Old 02-25-2013, 10:10 AM   #5
I don't know much about newer stangs. But for stall usually around 2800 is better for a street car. Just to clarify, a 3200 stall will still grab before 3200 rpm. It depends on how hard you are accelerating. 3200 rpms would be when max holding strength is reached. So if you are easing into the throttle the car will move well before 3200. It would be similar to dropping the clutch if you floored the pedal really hard.
Old 02-25-2013, 10:24 AM   #6
every 1lb of rotational mass = 10lbs of dead weight and every 120lbs is about a tenth of a second faster. You also pick up a bit of hp/tq
Old 02-25-2013, 10:36 AM   #7
2011 Kona Blue's Avatar
So since the one piece aluminum driveshaft is 30 pounds of rotational mass lighter than the stock driveshaft, one can expect between 2 to 3 tenths quicker acceleration by switching. Sweet deal.
Old 02-25-2013, 11:17 AM   #8
well not quite but say the 300lbs of dead weight equal so what ever that would do, say 2 maybe~ something like that. It can vary car to car but it will be noticable.
30lbs is a bunch, my 01 V6 OEM shaft was 25lbs and the alum one was 15 so only 10lbs saved on that one. Remember yokes those go back on the new alum one so gotta count those in on the weight.
Old 02-25-2013, 11:21 AM   #9
The Blue Dragon
DSS aluminum DS is only 21 lbs
Old 02-25-2013, 11:49 AM   #10
Srohda's Avatar
I thought every 1 lb of rotational mass is equal to 4 lbs of dead weight?
2012 GT Premium w/Brembo
Roush axle backs
MGW short throw shifter
Srohda is offline   Reply With Quote
Old 02-25-2013, 12:55 PM   #11
wheelman's Avatar
Ive heard everything from 4:1 to 10:1
wheelman is offline   Reply With Quote
Old 02-25-2013, 12:55 PM   #12
The Blue Dragon
This lol
Old 02-25-2013, 02:54 PM   #13
Srohda's Avatar
That's a big difference
Roush axle backs
Old 02-25-2013, 03:47 PM   #14
Any idea on what too do with the factory two piece driveshaft. Lol. I cannot believe Ford would use this for their 305 HP vehicle let alone a two piece for the 5.0. What a huge difference in quality between the one piece and two. Heck, look at the middle of it, no wonder its way weaker.
Old 02-25-2013, 05:03 PM   #15
The Blue Dragon
Not sure what the difference is between the v6 and GT DS. Yours looks a little different. But they're both still garbage lol
I suppose you could cut it with a cutting torch and weld it back together just for practice... Other than that it's just a big idle paper weight...
Maybe you could do some curls
Old 02-25-2013, 05:33 PM   #16
Lol. Too funny. My wife looked at me when I was loading the factory two piece driveshaft into our mini van and said what the hell are we keeping that thing for. I have no clue. I love the black plastic piece in the middle. Yikes. So does the GT driveshaft look different. Mine is from a 11 V6. Not sure if the 13 is different.
Old 02-25-2013, 06:22 PM   #17
The Blue Dragon
Mines an 11 GT. the only difference really is the pillow style carrier bearing instead of that black flex plastic
Old 02-25-2013, 06:43 PM   #18
I'm not saying my car is a 5.0 but with this aluminum driveshaft and the 3:73 gears I had installed today, the car is totally different. The off line acceleration is great now and what it should be in a car with that power. I can't believe Ford would use that two piece. No reason they cant use a lighter one piece. You Gt folks are paying darn good money and no reason to cut corners on the driveshaft.
Old 02-25-2013, 07:16 PM   #19
The Blue Dragon
Agreed. But so much money went into the block they had to cut corners somewhere to keep it an "affordable" sports car. I just installed my DS on Saturday and can tell a huge difference... I did mine on jack stands though lol
Old 02-25-2013, 07:23 PM   #20
Hey, the jack stands worked. What ever it takes. Lol. The mechanic who installed my gears also put the aluminum driveshaft on for me. He didnt even charge me for the driveshaft install. I paid 277 dollars for the gears and driveshaft to be installed. No whine in my gears. He did a great job. Great price. What a huge difference the 3:73 gears make. Almost no tire spin. Maybe a little chirp but shoots off fast from a dead stop.
Old 02-25-2013, 09:57 PM   #21
Whippled5.0's Avatar
where have ya'll been purchasing the alum ds from? tools/tips/any new tune(s) req for R2?
2011 5.0 Whipple 2.3
2001 Lightning (sold)
Whippled5.0 is offline   Reply With Quote
Old 02-25-2013, 10:00 PM   #22
The Blue Dragon
What's R2?
Old 02-25-2013, 10:04 PM   #23
McNassty's Avatar
D2's babies momma, sorry couldn't help it lol (R2-D2)
McNassty is offline   Reply With Quote
Old 02-25-2013, 10:41 PM   #24
American Musscle last week. They were in stock then.
Old 02-26-2013, 06:41 AM   #25
ptwhital's Avatar
anyone had a clunking noise from the alluminum ddriveshaft
ptwhital is offline   Reply With Quote
Old 02-26-2013, 07:29 AM   #26
The Blue Dragon
Not nearly as bad as the stock pos 2-piece
Old 02-26-2013, 07:54 AM   #27
IanM's Avatar
There is a guy that had a used driveshaft for sale a week or two ago on this Facebook page i'm part of:
https://www.facebook.com/groups/2632...group_activity
It's from the Driveshaft Shop, which is the same one I have in my car now and I can attest to the quality of, he pulled it from a wrecked car, had it rebalanced by the DSS, and has it up for sale at $500. It's a heck of a deal for someone, couldn't let it just sit there, thought maybe one of us would need it. If I didn't have the same one already, i'd have bought it already.
Old 02-26-2013, 08:23 AM   #28
That's a great deal. They cost around 700 so 500 is a steal (steel). Well aluminum . Lol
Old 02-26-2013, 08:31 AM   #29
Send a message via AIM to Borii
On my 06 the stock shaft and u joint was 41 lbs and the aluminum is 16 lbs.
It is good for a tenth and a half for most people. Makes driving with the cam much easier.
SOLD - 06 GT 371WHP/332WTQ
Sold - 1998 Camaro SS
Sold - 2001 Audi S4
Borii is offline   Reply With Quote
Old 02-26-2013, 08:16 PM   #30
Jetag93's Avatar
I just ordered a Dynatech alum DS from Brenspeed today. If its good enough for the NHRA it's good enough for me.
2013 DIB Premium GT/CS, 6MT, Cervinis Ram-Air Hood, RTR Charcoal 19X9.5s, BBK Cat Deletes & X-Pipe, DMH E-Cutouts, GT500 Rear Diffuser w/GT500 Quad-tip Axle-Backs, AED E85 Lope Tune, Boss 302 Intake, BBK 85mm TB, JLT CAI, Dynatech Alum DS, FRPP 3.73's, Eibach Pro-Springs and Pro-Struts/shocks, J&M Adj Panhard Bar, UPR Billet Alum LCA's, BMR UCA & Bracket & Relo Brackets, Eibach Adj Sway Bars, MGW Shifter, Brembo brake kit w/14" slotted 2 piece Boogie Full Tilt Racing Rotors, Llumar 30/5 Tint
Jetag93 is offline   Reply With Quote
Old 02-26-2013, 08:18 PM   #31
I was looking at the driveshaft from brenspeed. Please let me know how it works.
Old 02-26-2013, 08:26 PM   #32
Jetag93's Avatar
Will do.
Old 02-26-2013, 08:40 PM   #33
nosympathy's Avatar
Hmm kinda confused here. That thing saves you 1 LB? Other ones on the market have the same ratings and save you more weight.
Old 02-26-2013, 09:00 PM   #34
Jetag93's Avatar
No it comes with an alum flange that saves 1 add pound compared to a steel flange.. The shaft itself is 19 lbs.
Old 02-26-2013, 09:00 PM   #35
UltArc's Avatar
on the other forum I am that is strictly on aerodynamics and the physics of making vehicles more efficient, the accepted and always declared value of rotating mass is 4 pounds for 1 rotating. I do not know for fact, realistically it is a variable, depending on how far away the mass is from the center rotation point. The value of 1 lb one foot away from the center point is less than the value of 1 lb three feet away. So on a drive shaft, probably closer to 4. A wheel/tire? Maybe closer to 10.
But I am no scientist...lol
I love reading up and following these threads.
2012 Mustang EPA: 19/29
2012 AeroStang: 40/46
My sponsor, Tokkyo Nutrition, offers 50% off your entire order with the code "PowerHouse"
UltArc is offline   Reply With Quote
06:56 AM
