LCA - Mustang Evolution
Old 03-02-2013, 11:47 AM   #1
Blu13stang's Avatar
LCA
I'm thinking about some of the Competition Eng. LCA's. my question is Adjustable with the solid Rod Ends, Or the Non Adj. with Polyurethane bushings?
Blu13stang is offline   Reply With Quote
Old 03-02-2013, 12:49 PM   #2
nosympathy's Avatar
Is your car a DD?
Solid rods are very stiff and will produce a lot of noise and make a very harsh ride.
Poly if it is a DD
Old 03-02-2013, 01:00 PM   #3
Blu13stang's Avatar
Originally Posted by nosympathy View Post
Is your car a DD?
Poly if it is a DD
Yes DD , I was thinking Poly.
Old 03-02-2013, 01:31 PM   #4
nosympathy's Avatar
Yeah I would say to do poly.
Old 03-02-2013, 01:41 PM   #5
jayman33's Avatar
Not only poly but non-adjustable as well. You don't need adjustable, trust me.
jayman33 is offline   Reply With Quote
Old 03-02-2013, 02:04 PM   #6
Blu13stang's Avatar
Thanks that's good to know !
Old 03-02-2013, 02:24 PM   #7
What's been said and...make your adjustability at the upper unless you like regular 4-wheel alignments.
Old 03-02-2013, 03:10 PM   #8
nosympathy's Avatar
Would you need to get an alignment after changing out the UCA with an adjustable one?
Your statement confuses me.
Old 03-02-2013, 03:15 PM   #9
Think on it for a sec....if you have one adjustment at the upper the direction the wheels are pointing is still the same. If you have 2 adjustments at the lowers, you'll have to be bang-on or the car will turn left or right. That's the "alignment" I mean. You'll definitely want the wheels all on the same thrust line, so the car doesn't dog track.
08:20 PM
