Drag Radial size - Mustang Evolution
Old 03-02-2013, 04:22 PM   #1
2013fiveO's Avatar
Drag Radial size
Looking at getting some drag radials and just 2 rims for the rear to switch out at the track. What is the biggest/widest tire/rim size I could put on a 2013 GT? Or can someone recommend the best size for the most traction? I've drag raced a few times but could never do well on the stock Pirrelis. (yes even launching around 1500-1800) Thanks for any help.
2013fiveO is offline   Reply With Quote
Old 03-02-2013, 04:27 PM   #2
tc x 4's Avatar
I have 15"x10", they require sway bar relocation brackets tho. The 15" rims will give you more sidewall flex.
Old 03-02-2013, 04:28 PM   #3
Rapinator126's Avatar
Mickey Thompson drag radial.
Rapinator126 is online now   Reply With Quote
Old 03-02-2013, 04:30 PM   #4
Grabber Blue5.0's Avatar
Wider doesn't mean better. a 15x10 wheel with a 28" tire works well. Is this for the track or the street? Are you a manual or an auto? What are your goals? You need to provide more information.
Old 03-02-2013, 04:33 PM   #5
tc x 4's Avatar
This is the tire size.
Old 03-02-2013, 04:36 PM   #6
2013fiveO's Avatar
Manual. Im gona put steeda chromoly LCAs on the rear and not looking at doing any other suspension mods. Thanks.
Old 03-02-2013, 05:15 PM   #7
Gear matters too. hard to recommend when you don't provide complete info.
However, with a manual, don't waste your time with drag radials. Get a real bias slick. Height needed is dependent on rear gear and intentions. Width is as much as you can stuff on the rims without mishaping the tire. 8" is max without mods to swaybar mounts so, that limits you to a 10-ish inch tread width max.
I've used both DRs (BFG) and Bias ETs. Bias is way easier to heat up and get to hook on a stick car. DRs require a heavy burnout to heat up and if you break traction, they don't come back.
I'm going full drag slick this time. Hoosier b/c it's the widest tire I can shove on my 8" rim and comes in my weird 16" size.
Old 03-05-2013, 04:56 PM   #8
Does anybody have an idea how the MT drag radials handle on wet streets?
El Fufi is offline   Reply With Quote
Old 03-05-2013, 05:24 PM   #9
I've been doing the same research I just want enough to pull a 1.6-1.7
Xtian85 is offline   Reply With Quote
Old 03-05-2013, 05:25 PM   #10
Not well at all...
Old 03-05-2013, 05:48 PM   #11
Real bad...My friend's 5.0 got turned into a banana when he got T-boned by a bread truck coming home from the track on DRs. Sudden shower, sudden tendency to loop on the freeway, ka-boom!
Old 03-05-2013, 06:23 PM   #12
He got Tboned bcause he started to spin and got hit?
---------- Post added at 01:23 AM ---------- Previous post was at 01:22 AM ----------
How about the nittos nt05? Any bettet on wet pavement?
Old 03-05-2013, 06:28 PM   #13
Black5.0's Avatar
I got stuck driving home 2 hours on the highway in the rain with mt et streets and had no problem what so ever.
Black5.0 is offline   Reply With Quote
Old 03-05-2013, 07:02 PM   #14
He hydro'd on the water, spun around, ended up crossways in the lanes and ka-pow, got hit by the truck. Road tires? Never would have happened. This is why I transport my drag tires/wheels to the track and install them there. 20 minutes well spent.
Old 03-05-2013, 07:10 PM   #15
Wow. Some say they are fine in wet pavement. Some say no. Im leaning towards your Tbone story. Other than medium rare, its not worth the risk.
Old 03-05-2013, 07:53 PM   #16
Krazy Horse's Avatar
You can try M&H cheater slicks if your running 15's, they do ok wet but not for shooting out in front of ppl. They heat up nice and a real sticky grip down the track and are legal in most states on street
Krazy Horse is offline   Reply With Quote
Old 03-05-2013, 08:09 PM   #17
I want a DR that I can use all the time. Wet and dry. I live in the tropics so no winter season.
---------- Post added at 03:09 AM ---------- Previous post was at 03:04 AM ----------
But the only acceptable 15" to go around the street are the weld racing since they have front wheels other than skinnies over 17". They are expensive though.
Old 03-05-2013, 08:11 PM   #18
Its not recommended to run any drag radial in daily conditions. Along with wet driving dangers you'll be lucky to get 2k miles out of a set.
Old 03-05-2013, 08:12 PM   #19
Ive heard the nittos 555r give about 6k. Is that right?
Old 03-05-2013, 08:26 PM   #20
Mweigt07's Avatar
Region: North Dakota
I ran 555r 305/35r18 last year and got about 7000 miles with alot of track passes with lots of burn outs but I ran them bald almost. Did great in the rain. I'm buying another set for the street and buying slicks for the track. The nittos got me to an 8 flat in the eighth mile while other 5.0's with the same mods couldn't go lower than 8.6.
Mweigt07 is offline   Reply With Quote
Old 03-05-2013, 08:47 PM   #21
I have a piggy back question I'm interested is drag radials as well. If I get a 15x10 rim for rear what do I run up front? Sorry for thread jack
Moto111 is offline   Reply With Quote
Old 03-05-2013, 09:33 PM   #22
we get ALOT of frickin' rain where I am...hence lots of experience with wet-weather running.
You just can't mix DR grip with rain performance, plus DRs typically don't work unless heated up with a good healthy burnout so, you're better off with a sticky road tire, on the road.
Old 03-06-2013, 01:19 PM   #23
Stang8psi's Avatar
Region: Delaware
M&H 275/45/18 fits stock 18" wheel. i have been running it for a few months. Hooks incredible and I have 640 rwhp
Stang8psi is offline   Reply With Quote
Old 03-06-2013, 02:55 PM   #24
I would run a 17" skinny up front. You could use a 15" but that requires some brake work. I'm going to run a 17x4 up front and a 15x10 in the rear. Remember a 15" wheel out back requires you to run the sway bar relocation brackets.
Old 03-06-2013, 03:08 PM   #25
Thank you could I just keep my stock 17s up front and run the radials on back ?
Old 03-06-2013, 03:21 PM   #26
Yes that wouldn't be a problem.
Old 03-06-2013, 05:29 PM   #27
Thanks sery about hijack op
Old 03-06-2013, 06:07 PM   #28
avengnd's Avatar
I went the following setup on my 2012 5.0...I'll use them for the first time this April.
Race Star Mustang Drag Wheel Polished - 17x9.5 (05-13 GT, V6) 92-795353P - Free Shipping!
Mickey Thompson ET Street Radial II - 295/45-17 3745R - Free Shipping!
~ Alan Mustang Livin' and www.mustanglivin.com
2014 Shelby GT500
avengnd is offline   Reply With Quote
Old 05-06-2013, 08:45 PM   #29
tarupert's Avatar
Region: Nevada
I have been looking into a drag radial setup and every where I have looked most people recommend a 15 inch wheel in back, it has to do with rotating mass. At the track out here the tires must be DOT approved to run. I have a 2013 GT/CS Convertible, Auto, CAI with tune, 85mm throttle body, and axle backs. What would you recommend, currently best I can do through 60' is 2.06.
tarupert is offline   Reply With Quote
Old 05-06-2013, 08:59 PM   #30
tc x 4's Avatar
I have p295/55r/15 MT ET streets. If you go with a 15" wheel, you'll need sway bar relocation brackets. Cutting is required just so you know, It's not noticeable, bout 3/8" off the bracket if I remember rite.
Old 05-06-2013, 09:01 PM   #31
tc x 4's Avatar
The 15" wheel allows for more sidewall flex for better traction is why ppl run them.
Old 05-06-2013, 09:04 PM   #32
tarupert's Avatar
Region: Nevada
Thanks, and is there anything too the weight thing?
Old 05-06-2013, 09:08 PM   #33
tc x 4's Avatar
I just realized I already posted this info in this same thread. I could care less about your discount, but your starting to piss ppl off. Your gonna end up needing real help/info someday and ppl are gonna blow you off.
Old 05-06-2013, 09:16 PM   #34
nosympathy's Avatar
+1
Old 05-06-2013, 09:22 PM   #35
tarupert's Avatar
Region: Nevada
Wow, people are touchy on here. I read the whole thread again and no where does it reference weight or a suggestion as to what weight for a 15 inch wheel is good and what is bad. I also saw where grabber told the original poster that more information on vehicle would help with suggestions, so I posted with all current information on my vehicle looking for suggestions. I finally get what you guys are saying about the discount but once again I found out late. I just placed two orders with AM for the following:
Eibach R2 Suspension
BMR adjustable Panhard Bar
Eibach Pro Alignment rear lower control arms.
Eibach Adjustable Anti-Roll Sway bar kit front and rear
Camber Plates.
So once again I missed out.
If I would of asked some of these questions earlier I wouldn't have wasted money on a BBK 85mm throttle body.
Sorry to upset anyone, I just don't want to buy anything that really isn't going to give me any bang for the buck.
04:54 PM
