amp power - Mustang Evolution
Old 03-03-2013, 03:41 PM   #1
RhoudezGt's Avatar
Where do I go through the dash to get to the battery so I can power my amp?? On the 2013 GT
RhoudezGt is offline   Reply With Quote
Old 03-03-2013, 04:49 PM   #2
Jetag93's Avatar
Most people use the sound tube hole in the firewall.
2013 DIB Premium GT/CS, 6MT, Cervinis Ram-Air Hood, RTR Charcoal 19X9.5s, BBK Cat Deletes & X-Pipe, DMH E-Cutouts, GT500 Rear Diffuser w/GT500 Quad-tip Axle-Backs, AED E85 Lope Tune, Boss 302 Intake, BBK 85mm TB, JLT CAI, Dynatech Alum DS, FRPP 3.73's, Eibach Pro-Springs and Pro-Struts/shocks, J&M Adj Panhard Bar, UPR Billet Alum LCA's, BMR UCA & Bracket & Relo Brackets, Eibach Adj Sway Bars, MGW Shifter, Brembo brake kit w/14" slotted 2 piece Boogie Full Tilt Racing Rotors, Llumar 30/5 Tint
Jetag93 is offline   Reply With Quote
Old 03-03-2013, 05:12 PM   #3
jdavis96gt's Avatar
Region: West Virgina
Never seen 13 in person but u might be able to run it down inside fender. Then into door jamb. Just make sure it don't kink when u close door.
Old 03-04-2013, 09:27 AM   #4
CorDog009's Avatar
I'd use the sound tube hole. I had to run a trigger wire from the door lock through the bulkhead connector in the door jamb and it was a PITA. Couldn't get the grommet to seal right. Almost had to pull the fender.
'13 Deep Impact Blue GT, auto, BBK cat deletes, GT-500 A/B's, C&L tuned DiabloSport inTune, sound tube delete, BBK 85mm TB, JLT oil separator, NX plate kit.
CorDog009 is offline   Reply With Quote
Old 03-04-2013, 02:07 PM   #5
FOX21's Avatar
Hopefully this helps.
This is in my 13V6 but i think they r the same
On the last pic the blue power cable in going into the dash, there is a cap covering that hole just made a hole in it
ID:	94001   Click image for larger version
FOX21 is offline   Reply With Quote
03:38 PM
