Help with header qustion - Mustang Evolution
Old 03-04-2013, 09:38 PM   #1
Well I'm looking into headers now specifically long tubes. I have flow master outlaws right now I would like to do 1 7/8 headers with a o/r pipe what do I buy to know it will work with my outlaws thanks
Moto111 is offline   Reply With Quote
Old 03-05-2013, 07:06 AM   #2
The Blue Dragon
GrabberBlue5.0's Avatar
Afaik any set of LT's will work, just make sure you buy the midpipe that goes along with it. Just be prepared for LOUD when you do your exhaust with LT's, offroad midpipe and outlaws.
I personally will be going with stainless power here soon (basically its stainless works' "economy" brand)
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 03-05-2013, 10:48 AM   #3
JBA longtubes and off road hpipe is pretty cool
Boss IM, with Araid cai, bama 93 race tune, GT500 cat back, jba off-road x-pipe & longtubes, mgw shifter,4.10 gears, Aluminum Flywheel & driveshaft, Adjustable Panhard Rod, BMR adj. uca & lca, BMR relo. brackets, BMR Springs with 1.5" drop, BMR adj. swaybar, BMR tubular K member 1/2 drop motor mounts & BMR tubular A arms, steeda alu. rad. support, aluminum water pump pully, 85mm BBK TB, Rear seat delete. Boss oil cooler, Battery in trunk. AC delete, Evap delete
brianw64 is offline   Reply With Quote
Old 03-05-2013, 12:14 PM   #4
I was looking to do a over axle pipe but doesn't look like I have a option for that with my outlaws so jba lt more then likely
Old 03-05-2013, 01:29 PM   #5
jayman33's Avatar
Stainless works is a great brand, we've installed a few sets with zero fitment issues. Stainless Power is the same design except Stainless works outsources that specific brand out of state.
jayman33 is offline   Reply With Quote
Old 03-05-2013, 05:00 PM   #6
Have you installed the 7/8" on the 2011-12 gt? How tight is the fit?
El Fufi is offline   Reply With Quote
Old 03-05-2013, 06:03 PM   #7
The Blue Dragon
OTA pipes will do absolutely nothing for you except delete resonators, but you can get those cut out. I think JPC has OTA pipes that will work though
Old 03-05-2013, 08:50 PM   #8
O ok didn't know that so just headers with a h pipe will work and will probably be damn loud lol ok well know what I'm ordering first stripes are getting put on sat and I really need some summer tires/ wheels
Old 03-07-2013, 06:41 AM   #9
Blairnr's Avatar
Excellent choice. I have stainless works and it is awesome!!!!!
Blairnr is offline   Reply With Quote
Old 03-07-2013, 07:41 AM   #10
Ya outlaws plus offload pipe plus long tubes may set off car alarms lmao
Old 03-07-2013, 08:30 PM   #11
jayman33's Avatar
Installed a few, fit was perfect.
Old 03-07-2013, 11:30 PM   #12
tc x 4's Avatar
Is the install pretty much the same as on the 4.6, I know it couldn't be any worse.
Old 03-08-2013, 07:15 PM   #13
jayman33's Avatar
Its not bad, if you're doing it on jacks. You need to lift the engine, remove the engine brackets and starter to give you room.
01:33 PM
