Random Traction Control - Mustang Evolution
Old 03-08-2013, 06:29 AM   #1
KARgt13's Avatar
I was accelerating at a grandmother like pace on a dry, straight road and was at 40 mph when the traction control light started blinking. I couldn't accelerate so it was definitely acting like traction control should, and then it turned off. However, for a few seconds after it turned off it still seemed like it was on because you could feel it kind of like, pulsing on and off because the car felt like it was pulling to the side ever so slightly then would go straight a couple times repeatedly..seemed like it was coming from the passenger side rear wheel. Really weird, definitely did not lose traction so it had to be a malfunction. Has this happened to anyone else?
KARgt13 is offline   Reply With Quote
Old 03-08-2013, 11:29 AM   #2
Jetag93's Avatar
I just got this today while driving at medium acceleration. Traction control off light & low traction light cane on and stated on til I turned her off and restarted.
2013 DIB Premium GT/CS, 6MT, Cervinis Ram-Air Hood, RTR Charcoal 19X9.5s, BBK Cat Deletes & X-Pipe, DMH E-Cutouts, GT500 Rear Diffuser w/GT500 Quad-tip Axle-Backs, AED E85 Lope Tune, Boss 302 Intake, BBK 85mm TB, JLT CAI, Dynatech Alum DS, FRPP 3.73's, Eibach Pro-Springs and Pro-Struts/shocks, J&M Adj Panhard Bar, UPR Billet Alum LCA's, BMR UCA & Bracket & Relo Brackets, Eibach Adj Sway Bars, MGW Shifter, Brembo brake kit w/14" slotted 2 piece Boogie Full Tilt Racing Rotors, Llumar 30/5 Tint
Jetag93 is offline   Reply With Quote
Old 03-08-2013, 02:14 PM   #3
KARgt13's Avatar
Oh good. We have the same yet different problem haha. My off light didn't come on just the low traction blinked and clearly affected the ability to drive.
Old 06-18-2014, 06:46 PM   #4
I've had the same exact issue - twice now. As a matter of fact, I just picked up my car from service because of it. However, I was told there is nothing wrong with the car as the issue cannot be reproduced. Both occurrences were at speeds under 30mph, while traveling in a straight line, under very light accelleration. In my case, the traction control light was flashing as well. If feels very unsafe; I came close to being rear-ended the second time.
jwynsen is offline   Reply With Quote
Old 06-18-2014, 07:21 PM   #5
lilediselec's Avatar
Yay that was my issue I posted a couple days ago. Mines only on turns but same effect
lilediselec is offline   Reply With Quote
Old 06-18-2014, 09:38 PM   #6
To turn traction, and advance off completely hold down the traction button with the brake pressed for about 5 seconds. You will be prompted "advance track off." To put it in advancetrac sport mode double tap the button quickly with brake pressed.
yacob454 is offline   Reply With Quote
Old 06-18-2014, 10:54 PM   #7
Try doing a search. I know this issue has come up on all the forums a few times. I think usually ford ends up replacing the steering column or the abs/traction computer.
SecretAgent is offline   Reply With Quote
Old 06-19-2014, 06:49 AM   #8
Abominable Mustang
WhoDat's Avatar
Region: Alaska
So if one of my headlights goes out at night, do I just turn my lights off and ignore it? There is an actually problem going on with these guys' traction control systems activating when they shouldn't. If you have actual good info that can contribute to fixing the problem, do so.
Yeah, what comes to mind when I read through the thread, is either the steering rack (it has been a known issue) or ABS module. What doesn't help is that it sounds like it's intermittent, which makes it hard for the dealership/mechanic to diagnose since it may not happen while they have the vehicle.
2012 Kona Blue 3.7L V6:
Old 06-19-2014, 07:12 AM   #9
So I think with my issue I just changed my rear tires to a wider but shorter tread being a 265 40 18 vs 235 45 18 so it's picking up the difference
Old 06-19-2014, 07:34 AM   #10
No need to get roudy man. I apologize for my rudeness of misreading the problem, I should be punished. It will never happen again.
Old 06-19-2014, 07:53 AM   #11
Abominable Mustang
WhoDat's Avatar
Region: Alaska
That really shouldn't be your issue because those two tire sizes are the same overall height at just over 26", meaning their revolutions per mile are almost identical.
Old 06-19-2014, 07:55 AM   #12
Tires sizes wouldn't do that. It does sound like a speed sensor or something electrical/computer controlled.
Old 06-19-2014, 09:31 AM   #13
Guy at Ford told me smaller rears are 1/4" difference so they spin faster then fronts causing the traction control to kick on will be buying new tires Friday so I'll update Saturday to see if it fixes the problem or not
Old 06-19-2014, 10:05 AM   #14
nhcowboy's Avatar
OP might want to get under the car, unbolt the abs sensors and clean then. Mine did some bad things as well randomly simply because dirt/mud had caked over it. Haven't had an issue since.
2011 Black Mustang GT Premium
Corsa XO & Sport AB/Airaid/Bama 93R
Best 1/4 mile to date 60' 2.009
12.538 ET @112.33
100+ Deg 85 Hum RPR 3PM 1/2 tank street tires
nhcowboy is offline   Reply With Quote
Old 06-19-2014, 12:08 PM   #15
Try that first always good to save money thanks for tip
Old 06-19-2014, 02:55 PM   #16
Where is the sensor at anybody know by chance
Old 06-19-2014, 03:12 PM   #17
On other vehicles, I have seen low air pressure in 1 tire trigger strange events. I doubt that's your case, but pretty easy to check, along with cleaning the sensor. My dealership experience has been, "there is nothing wrong with your car. Ever. It's just how they are" - so, try the easy stuff at home
jd864 is offline   Reply With Quote
Old 06-19-2014, 06:48 PM   #18
nhcowboy's Avatar
Follow the only wires that end up near the hubs/axles. You will have brake lines and abs sensor. That's about it. If you want a Better view, find the exploded view of the online service manual... http://iihs.net/fsm/?dir=499. If I recall that is for the 2011 but it should be relevant for much of the 2011-14.
A set of ramps will make it easy.
12.538 ET @112.33
Old 06-19-2014, 08:55 PM   #19
Compstall's Avatar
Thanks for saving me $50. Again. I win.
Sent from The Prophecy
- Brent
'11 GT Kona Blue Brembo
"Measure with micrometers, mark with a scribe, chop with an axe"
"I'm not new to driving. I've been doing it for a couple of years now." - Aphex
Compstall is offline   Reply With Quote
Old 06-20-2014, 04:05 AM   #20
So cleaned it all up works like a champ again thanks boys
Old 06-21-2014, 10:34 AM   #21
noldevin's Avatar
I've had this happen ONCE after the dealership did their free wash on the car. I think a wet or dirty sensor can cause it.
noldevin is offline   Reply With Quote
Old 06-21-2014, 10:43 AM   #22
Laquisha's Avatar
I had this happen once when I was on like 9 miles to empty. I think it's so the car could roll further and get more roll rather than with it on to get to a gas station quicker. Call me stupid idgaf
Old 06-21-2014, 02:48 PM   #23
You're joking right?
Old 07-17-2014, 04:02 PM   #24
Jaylg86's Avatar
Man this just happened to me..I bought this car with 0 miles and now has 16k on it and this is the first time I experience this.. I literally thought my tune broke my car.. Had loss of power and the brake felt like it was being applied.. Felt horrible.. Bout to clean my sensors.. This can seriously cause a bad accident
Jaylg86 is offline   Reply With Quote
Old 07-17-2014, 04:45 PM   #25
im a v6 accidentally stumbeled on this post .... were discussing the same thing in the 2011+ v6 forum .... alot of ppl are gettig this problem ... and there isnt a true answer why it is happening the car isnt throwing a code for almost anyone and even when the service turns it off it comes on later .... someone is speculating .. havent been tested yet but alot of ppl are saying this happenes when the ca gets lowered ... and that the abs sensor needs to be cleaned and that solved this issue ... idk how true it is but i thought maybe it could help some of you dont ask me why abs sensor would mess up your traction control i am having the same exact issue as we speak both the traction control light off and loss of traction lights are both on .... and mine even says advancetrack needs service .... idk whats wrong with it but i would love for ford to come up with a solution and quickly .....
dozer 13 is offline   Reply With Quote
Old 07-17-2014, 04:46 PM   #26
Jaylg86's Avatar
Now I have this weird clicking noise when I hit the brake in park and only in park.. http://youtu.be/PzmcavxI9aU
This blows
Old 03-09-2015, 04:24 PM   #27
It acted up while I was driving and spun me around about 6 times until I stopped while facing incoming traffic. Not only did it almost cost some lives but I just found out it will cost about $1800 to fix at Midas (a cheaper option than the dealer). I can't believe there's not a recall on this! Sadly, my next car won't be a Ford.
30something is offline   Reply With Quote
Old 03-09-2015, 09:20 PM   #28
Compstall's Avatar
Yep, ALL Ford products do this. You should stay away from them
- Brent
Old 03-09-2015, 11:15 PM   #29
oxford5pointoh's Avatar
I know this is like 9 months ago...but I'm pretty sure that's not the case bud. But I won't call you stupid.
Old 03-09-2015, 11:56 PM   #30
Morgue's Avatar
I just started having the same issue. Traction control light comes on as well as ABS. I cleaned the ABS censors and still have the issue.
Morgue is offline   Reply With Quote
Old 04-22-2015, 10:13 PM   #31
infamousw3's Avatar
Sure am glad for being on this site. I just had this problem today. Traction light comes on and it felt like the car was trying to break while i was accelerating.
infamousw3 is offline   Reply With Quote
Old 04-23-2015, 04:59 AM   #32
OX1
I have the opposite problem (or maybe I should consider myself blessed). Mine won't come on no matter how much I spin the tires, or what all else I do with the car.
86 Capri, turbo, 3.27's-12.66 @ 107.75
14 GT-Roush Phs 3, VMP 93 tune, Whiteline Sway Bars, Roush U/L Rear Control Arms, Street 18 X 9/10 Bullits with 295/255 NT05/555's-Track 18 X 8/10 Bullit's on 305/35R18 MT ET STR SS and 235/50ZR-18 Michelin PSS
OX1 is offline   Reply With Quote
10:43 AM
