Will factory 18 wheels 2012 GT clear Brembo's? - Mustang Evolution
Old 03-29-2013, 04:11 PM   #1
So I have a couple of deals I can jump on:
  1. Brembo fronts off gt500 Includes calipers, pads, hoses, rotors and a set of splash shields less than 500 miles
  2. 19 inch brembo wheels with Pzeros Summers and sensors. Tires are front 80% rears60-50% tread
I can get one or the other hence the question. I have the factory non brembo gt 18 wheels, I just do not know if they will clear the brembos. Each deal is about the same price @1200
Thanks for helping
hddcrrasher is offline   Reply With Quote
Old 03-29-2013, 04:33 PM   #2
I do not believe that they will clear the larger Brembo calipers.
mmike87 is offline   Reply With Quote
Old 03-29-2013, 04:46 PM   #3
They'll clear with spacers if you want to take that risk.
Old 03-29-2013, 09:00 PM   #4
Raf63's Avatar
I know for a fact that the factory 2013 GT 18" rims will NOT clear the Brembos. Dunno about the 2012 rims but I doubt it...
Raf63 is offline   Reply With Quote
Old 03-30-2013, 09:10 AM   #5
will not fit, i tried the factory 19" rims and not even close
Boss IM, with Araid cai, bama 93 race tune, GT500 cat back, jba off-road x-pipe & longtubes, mgw shifter,4.10 gears, Aluminum Flywheel & driveshaft, Adjustable Panhard Rod, BMR adj. uca & lca, BMR relo. brackets, BMR Springs with 1.5" drop, BMR adj. swaybar, BMR tubular K member 1/2 drop motor mounts & BMR tubular A arms, steeda alu. rad. support, aluminum water pump pully, 85mm BBK TB, Rear seat delete. Boss oil cooler, Battery in trunk. AC delete, Evap delete
brianw64 is offline   Reply With Quote
2012 gt
06:36 AM
