Ford Racing Short Throw - Mustang Evolution
Old 04-03-2013, 04:53 AM   #1
BigP0314's Avatar
I have seen tons of posts about the Barton Short throw shifter and the MGW but I haven't seen anything on the Ford Racing short throw shifter. Does anyone have any info on the Ford Racing Short throw shifter?
BigP0314 is offline   Reply With Quote
Old 04-03-2013, 05:21 AM   #2
gtstyles2's Avatar
I think the price is what turns everybody off from it, looks exactly like a Barton clone... This shifter will probably never sell if its this expensive, for that u can get the complete MGW setup for cheaper and know your getting a solid product. I personally have the Barton shifter, with no complaints at all... If I could do all over again, I would've gotten the MGW setup since its been praised by many.
Old 04-03-2013, 07:39 AM   #3
Joey8's Avatar
I'm curious about this to. I was definitely leaning toward an MGW short throw but I don't have a lift or ramps and would have the dealership install it. With that said I was thinking it may void my warranty unless its a ford racing short throw? Any advice?
2014 Sterling Gray GT (Ordered1/24) (Built2/25) (ETA3/12) (Picked Up 3/21)l 443.9/417.8 l
l l 6 Spd l Prem Pkg l Nav l TP l LthrRecaros l AmericanRacing 1 7/8 LTs l O/R H l JLT CF CAI lVMP Tuned l BorlaS Quads w/ResDel. l GT500Valance l KoniStr.T l K-Springs l GT500 Mounts l BMR UCA&LCA l BMR Relos l BMR Panhard l SpeedDawg Knob l 5.0 LloydsMats l Redline HoodStrts l Bobs CF Oil Sep. l 15% Tint l CDC Grille l StrtScn2 ChinSpoiler l GT/CS Fogs w/4500k l RTR DeckLid l CF Engine/CoilCoversl
Joey8 is offline   Reply With Quote
Old 04-03-2013, 08:00 AM   #4
The Blue Dragon
GrabberBlue5.0's Avatar
It will only void your warranty if the dealer can prove that your modification caused part failure. With that said, some dealers will say or do anything they can to "prove" this.
I have an MGW and it's fantastic. I'm pretty sure the FRPP short shifter is the Barton, just a different color and logo
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 04-03-2013, 08:20 AM   #5
Joey8's Avatar
Ill talk to the dealer and see what he says. If he says ill be fine with the warranty if I go with the ford racing short throw then that's the route ill go, spending a little more coin for a piece of mind. If he says it will void my warranty regardless, ill go MGW. Does the ford racing have the reverse lock out still?
Old 04-03-2013, 08:27 AM   #6
The Blue Dragon
I can't say for sure, but anyone making shifters for an MT82 would be stupid to not have the reverse lockout
Old 04-03-2013, 08:34 AM   #7
Joey8's Avatar
Just checked. It still retains the reverse lock out.
Old 04-03-2013, 08:38 AM   #8
gtstyles2's Avatar
I think all shifters have the lockout except the Hurst I think
Old 04-03-2013, 09:38 AM   #9
nosympathy's Avatar
You mean like Hurst
Old 04-03-2013, 10:22 AM   #10
BIGHOSS5.0's Avatar
Have you guys noticed a big difference in the short through over stock? I just got my 2012 GT and it has the smoothest shift on any stock car I have ever driven. Plus my GT came with the factory billet shiftier, which I like a lot.
Do you still have that smooth transition when shifting with the ST or is it stiff like the 05-09 stangs?
BIGHOSS5.0 is offline   Reply With Quote
Old 04-03-2013, 10:59 AM   #11
gtstyles2's Avatar
The biggest problem is not so much the shortness of the gears, its fairly short from factory... The rubber bushing that holds the shifter is the biggest problem, under spirited high rpm shifting there's deflection from the rubber shift bracket which causes u to miss shifts... I changed both the shifter and bracket and notice a pretty big difference.
Old 04-03-2013, 11:13 AM   #12
nosympathy's Avatar
Grab the shifter when it is in a gear and push back and forth it wiggles a lot. The after market shifters won't have this much play. Less chance of missing a gear because of this.
Old 04-03-2013, 03:32 PM   #13
BigP0314's Avatar
I know in the photos it looks just like the Barton but just seeing if anyone has any first hand experience with it compared to other shifters.
Old 04-03-2013, 04:01 PM   #14
Joey8's Avatar
I would like to no this to
Old 04-06-2013, 02:24 PM   #15
Mig44's Avatar
I've ordered the ford racing hurst shifter, a little more expensive but you avoid any warranty issues, 2-3'shifting on my gt is really tough above 5000 rpm, I've heard this is common problem on these trannys
Mig44 is offline   Reply With Quote
Old 04-06-2013, 02:30 PM   #16
jayman33's Avatar
The FRPP shifter is a rebranded Barton shifter. Talked to barton about this and they confirmed. Levittown ford has them for 412 plus shipping, I know a company where they're pricing is around the same
I don't think there is a Ford racing Hurst shifter.
jayman33 is offline   Reply With Quote
Old 04-06-2013, 02:37 PM   #17
Mig44's Avatar
You are probably right , in the front of the 2013 ford racing cat they reference hurst but on the 2013 later in the catalog they do not
Old 04-06-2013, 03:12 PM   #18
Joey8's Avatar
Great. Thanks for the info. I heard great things about the Barton shifter. So if it means going frpp shifter to keep my warranty so be it. If its going to be voided regardless MGW here I come.
Old 04-06-2013, 03:27 PM   #19
BIGHOSS5.0's Avatar
So I just watched some videos on installation of short through shifters and the stock components are CRAP! Looked like a big hunk of rubber and stamped piece of tin...
Old 04-06-2013, 03:28 PM   #20
The Blue Dragon
^ you are absolutely correct, the Barton 2 post bracket worked wonders, but my MGW is even better with a shorter throw and wayyyy less nvh
Old 04-06-2013, 07:24 PM   #21
Joyride's Avatar
Funny thing is, I have the mgw and the only shift that is a pain is 4th. It should be the easiest but I have to slam that b**** in for it to let it in
Joyride is offline   Reply With Quote
Old 04-06-2013, 08:26 PM   #22
The Blue Dragon
Makes me wonder if something is wrong with your synchros because my 4th gear is smooth as butter
Old 04-06-2013, 08:40 PM   #23
Jetag93's Avatar
Yea all my shifts are smooth with mgw once warmed up.
2013 DIB Premium GT/CS, 6MT, Cervinis Ram-Air Hood, RTR Charcoal 19X9.5s, BBK Cat Deletes & X-Pipe, DMH E-Cutouts, GT500 Rear Diffuser w/GT500 Quad-tip Axle-Backs, AED E85 Lope Tune, Boss 302 Intake, BBK 85mm TB, JLT CAI, Dynatech Alum DS, FRPP 3.73's, Eibach Pro-Springs and Pro-Struts/shocks, J&M Adj Panhard Bar, UPR Billet Alum LCA's, BMR UCA & Bracket & Relo Brackets, Eibach Adj Sway Bars, MGW Shifter, Brembo brake kit w/14" slotted 2 piece Boogie Full Tilt Racing Rotors, Llumar 30/5 Tint
Jetag93 is offline   Reply With Quote
Old 04-07-2013, 02:27 AM   #24
BigP0314's Avatar
Thanks for all the info guys!!!
Old 09-04-2013, 10:14 PM   #25
got a 14 GT and got frpp short throw shifter installed. it feels nice, smooth. no problem going through gears. its a lil noisy but i was told its normal. i had a 13 GT dude go through gears and he liked it. he even said it was shorter than his MGW. im happy with it. yes its expensive but i got it for free lol but i heard barton makes it and its cheaper.
vlamison5.0 is offline   Reply With Quote
Old 09-04-2013, 11:05 PM   #26
Missouri Hoss's Avatar
Looks to me like a long electrical conduit clamp with a spongy rubber center. Extremely poor design.
Missouri Hoss is offline   Reply With Quote
Old 09-05-2013, 12:58 PM   #27
K2Steeda's Avatar
I have the FRPP shifter and I love it.
K2Steeda
2014 GT 5.0 Brembo's and 3.73's. FRPP Shifter, Steeda Intake Bama V2 Tune, Accufab 84.5 TB, Borla S-Type, Lethal Over Axel, JBA X, DSS Shaft, Steeda Panhard, Steeda LCA, Koni Streets, K Springs, GT500 Mounts.
2004 Maxima SE Daily Driver
K2Steeda is offline   Reply With Quote
Old 09-05-2013, 03:09 PM   #28
ddtmoto's Avatar
Region: Utah
The Hurst has a good system to keep a competent driver in the gear for the direction he wants. It works just fine. If a driver is not sure what gear he is engaging, he should be driving an automatic...just sayin
ddtmoto is offline   Reply With Quote
Old 09-06-2013, 07:31 AM   #29
ddtmoto's Avatar
Region: Utah
It is quiet tho.....only good thing I can think of with the stock sponge bracket.
Old 09-06-2013, 12:00 PM   #30
i c u have k springs by frpp right? im also thinking about getting those springs or stedda 1.25 in drop on front and 1.5 rear. are k springs bouncy? any pics?
SLP Loud mouth axle back, Frpp x pipe, tune, Frpp short throw shifter, K&n drop in filter, JLT Oil separator.
Old 09-06-2013, 12:03 PM   #31
2013 FiveO's Avatar
hahaha!! straight up
2013 FiveO is offline   Reply With Quote
Old 09-06-2013, 01:17 PM   #32
K2Steeda's Avatar
Not bouncy at all. Ride is a little stiffer then stock and drop is perfect. Pair them with a good strut and shock and you should be golden. Also I didn't need camber adj in the front. I was within ford specs with the gt500 strut mounts. No poping noise no squeaks just a better balanced car. See my other posts or profile for pics
K2Steeda
Old 09-07-2013, 12:44 AM   #33
xxPIKExx's Avatar
I'm looking all over for that knob. Expensive as all hell from Ford and rarely seen on EBay? What package did it come with?
xxPIKExx is offline   Reply With Quote
Old 09-08-2013, 06:50 AM   #34
ddtmoto's Avatar
Region: Utah
Mine came in my 401a interior package. Its a 'billet knob', same shifter just a much better/different knob IMO. I didn't like the temperature extremes of the metal knob, didn't mind the looks. But, I wanted the retro look of a cue ball style. I will keep the billet ball around in the event the car is sold someday.
Do yourself a favor, if you haven't already, change to an after market shifter mount bushing/bracket. That alone will make any shifter even better.
Old 09-16-2013, 10:32 PM   #35
DallasStang77's Avatar
If you be careful when working on the shifter install and don't scratch it up I'm sure you can reinstall the stock shifter no problem.
Unless they have one of those tamper stickers on so if you bust the seal...
04:18 AM
