JBA Modular Offroad XPipe Leaks - Mustang Evolution
Old 04-03-2013, 10:13 AM   #1
OzzyLiriano's Avatar
Just got it, where should i be checking for exhaust leaks? Or where should i weld? Have heard some storys, but anything anyone can share before i install the offroad xpipe that could save me from redoing this type of job?
I dont mind welding a couple spots because niether im i getting anything for the next year nor do i have state regulations.
Thanks in advance for any inputs!
OzzyLiriano is offline   Reply With Quote
Old 04-03-2013, 11:30 AM   #2
I've heard good reviews about the JBA x-pipes as far as fitment goes. I have the H-pipe myself but I have kept the cats to be removed at a later time so the cat deletes are in the shed for now. I had zero leaks and haven't had any since install about 800 miles ago, but I made sure it was on right before I did the final clamp down. I think if you make sure you have it on right you'll be fine and you can always adjust it if you find a leak... Shouldn't need to weld anything.
Old 04-03-2013, 11:39 AM   #3
Alright thanks man!
Old 04-03-2013, 07:39 PM   #4
nosympathy's Avatar
I have the JBA o/x and figment was perfect with no leaks...
Old 04-04-2013, 11:12 AM   #5
I checked online and there was a couple threads talking about leaks, ill just make sure its tight and ill put just a couple spots with my welder to be sure. Thanks though
Old 04-04-2013, 11:29 AM   #6
tc x 4's Avatar
Unless you weld it 100%, I wouldn't weld it at all. The tacks will keep the outer pipe from collapsing around the inner pipe to make a good seal.
Old 04-04-2013, 02:22 PM   #7
Well i the only reason why i said this becuase the best muffler shop here, they do exotic cars etc... Told me to do this, ill have to look more into that then, they were charging me 75 to do the o/r xpipe, i rather do it myself.
Old 04-04-2013, 04:27 PM   #8
tc x 4's Avatar
It should seal up fine. Just get everything together first hand tight, then tighten everything at once. Use common sense when you do it, you don't want to over tighten. $75 for 15min labor is a little steep.
Old 04-04-2013, 04:49 PM   #9
Lmfao yup, i rather do it myself and take my girl out to dinner or something, miami is getting expensive by the min
Old 04-04-2013, 07:11 PM   #10
Heartless's Avatar
Mine leaked on the driver side where it mates up to the down pipe. I had to force it over since it did not fit 100% perfect which shouldn't be expected anyways. Being that the Ford factory clamps are not a full 360 seal it leaked no matter what I did. I ended up getting a torqtite easy seal clamp from NAPA and added some high heat rtv this time around. Leak is gone. I don't believe it's a common problem for these to leak but if so from one of the front clamps then there's your fix. Oh and I used the 3" clamp to accommodate the hump.
Heartless is offline   Reply With Quote
Old 04-11-2013, 01:05 PM   #11
Hey man i got a leak, its also lof and annoying, does advance auto parts have those clamps
Old 04-11-2013, 01:21 PM   #12
nosympathy's Avatar
Nope. I had checked for something else and looked for clamps like that. They only have those bent metal rod clamps that don't apply to our exhaust type at all.
Old 04-11-2013, 01:41 PM   #13
Thanks, theres no napa around here, i might have to google it
Old 04-11-2013, 01:41 PM   #14
I saw this posted on a forum
Old 04-11-2013, 01:43 PM   #15
They are from orielys
Old 04-11-2013, 01:43 PM   #16
nosympathy's Avatar
Those would be the best IMHO for getting rid of leaks. Would need to be 3" clamps and are what I was looking at getting. I don't have a leak but I feel like my exhaust would seem sturdier with those.
Old 04-11-2013, 01:52 PM   #17
Yeah im going to get them, thanks
Old 04-11-2013, 02:23 PM   #18
Man i dont have any store nearby, you think you can help find it on the site, atleast the right one becuase i see a couple
Old 04-11-2013, 02:47 PM   #19
nosympathy's Avatar
Give me a few minutes as I'm driving I'll take a look when I get the chance
Old 04-11-2013, 03:21 PM   #20
nosympathy's Avatar
http://m.oreillyauto.com/mt/www.orei...0082&ppt=C0022
Is what the other guy was talking about
Is the one from the pictures you have.
Old 04-11-2013, 03:29 PM   #21
I just called, he said its the walker 3 in lap joint, is that what your looking at? For some reason ur links throw me to nothing
Old 04-11-2013, 03:31 PM   #22
nosympathy's Avatar
Yep exactly it.
Old 04-11-2013, 03:45 PM   #23
Yep exactly it.
That shyt is $47, i have to pay extra for shipping, this sucks
---------- Post added at 03:45 PM ---------- Previous post was at 03:44 PM ----------
I think im going to weld it, thats free vs 47
Old 04-11-2013, 05:23 PM   #24
Where is it leaking? I JUST installed a pypes x-pipe about ten minutes ago for a friend and I had to play with those band clamps almost 30 minutes until they didn't leak. It also helps if you have someone push on the x-pipe as if they were forcing it towards the front of the car once you have it hooked up to the mids.
Like I said, I have the JBA h-pipe and it doesn't leak either. Those factory clamps are a PITA but they do work.
Old 04-11-2013, 05:40 PM   #25
I just bought some clamps, i tried to play with it a bit but nothing man
Old 04-11-2013, 06:20 PM   #26
tc x 4's Avatar
Those are the ones that seal, they may not be purdy, but they work the best.
Old 04-11-2013, 10:54 PM   #27
Heartless's Avatar
Get the 3" Walker torqtite clamps. You can get them from summit for $9. Don't forget to add some high heat rtv in the joint then put the clamp on
---------- Post added at 11:54 PM ---------- Previous post was at 11:51 PM ----------
http://m.summitracing.com/parts/wlk-33222
This one
Old 04-11-2013, 11:04 PM   #28
This one
As a matter fact i found some exactly like that in design for 12 bucks from rol exhaust, should i return them for those?
Old 04-11-2013, 11:07 PM   #29
This one
These right
Old 04-11-2013, 11:10 PM   #30
Heartless's Avatar
As long as they are stainless, 3" diameter, 2" wide, have a 360 seal, and most importantly the metal seems thin enough to mold itself around the piping when tightened. The design I'm talking about would come flattened out in the package. Like a straight piece of thin stainless with attachments om either end. If they are like that then use them. Don't forget rtv
---------- Post added at 12:10 AM ---------- Previous post was at 12:09 AM ----------
These right
Yes
Old 04-11-2013, 11:21 PM   #31
Yes
Yeah these came the same as you described.
---------- Post added at 11:19 PM ---------- Previous post was at 11:18 PM ----------
Its these
---------- Post added at 11:21 PM ---------- Previous post was at 11:19 PM ----------
Yes
Thanks btw
Old 04-13-2013, 09:02 PM   #32
I used the pictured band clamp on mine and it still manages to leak. It sounds terrible I'm very annoyed with the JBA X. Issue is that it isn't straight to begin with no matter what you can't fix that with any clamp I'm going to weld mine whenever I take it off.
Xtian85 is offline   Reply With Quote
Old 04-13-2013, 09:29 PM   #33
Yeah man so am i, hopefully it goes away
Old 04-15-2013, 08:14 AM   #34
Supposedly the guy thats lending me the lift told me that the clamps wont work there...i guess theres only one way to find out
08:17 PM
