Barton short throw shifter - Mustang Evolution
Old 04-07-2013, 05:34 PM   #1
2013mustang5.0's Avatar
Hey guys well my birthday Is coming up and I think my first upgrade is going to be a barton short throw shifter. The only thing I'm worrying about is will ford put it on for me and will it void my warrenty?
2013 mustang 5.0 track pack(first mustang)
2013mustang5.0 is offline   Reply With Quote
Old 04-07-2013, 05:39 PM   #2
gtstyles2's Avatar
Ford will find any minimal reason to void warranty, just make sure u a fair amount of miles and know your trans is solid before make the leap
Old 04-07-2013, 05:43 PM   #3
True thanks for the info. Also do you think they will install that for me. I don't have access to the lift
Old 04-07-2013, 05:51 PM   #4
gtstyles2's Avatar
Doubt Ford themselves will do it unless its a Ford Racing part, which I'm sure Barton is the same but they will never admit it... But I'm sure u can find a local speed shop that can do it for u. I would also highly recommend getting the bracket to add to the shifter, since the factory bracket is the biggest problem with our trannies... I went with the 2 post bracket and the shifts feel pretty solid now
Old 04-07-2013, 06:22 PM   #5
BIGHOSS5.0's Avatar
For it to void your warranty, Ford had to be able to prove whatever you installed caused the problem. I would recommend finding a speed shop to do it and just nit say anything to ford. PLUS, it is a HUGE improvement over stock and will help prevent you locking out you gears at high RPM.
BIGHOSS5.0 is offline   Reply With Quote
Old 04-07-2013, 07:43 PM   #6
Should i just get a bracket or should I get the whole short shifter
Old 04-07-2013, 08:31 PM   #7
gtstyles2's Avatar
All that has to come apart anyway, u might as well get the shifter... I think it's only gonna make the car easier and more satisfying to drive
Old 04-08-2013, 03:49 AM   #8
I wouldn't worry too much about your warranty with a shifter install ... but you're always rolling the dice if your dealer sucks. The sifter / bracket combo is the way to do ... and you don't need a lift, I did it on ramps in my garage. Was not too hard at all.
mmike87 is offline   Reply With Quote
Old 04-08-2013, 05:53 AM   #9
gtstyles2's Avatar
Yea I also did it on ramps in the rear, I also jacked up one side towards the front, just enough for me to slide under
Old 04-08-2013, 06:23 AM   #10
tc x 4's Avatar
Energy Suspension makes the shifter bushing for $13 that claims to solve the shifting issues. 5.0 Mustang & fast fords has an article on it this month. I like the way the stock shifter feels, I don't want a shorter throw than what I have now. It just wouldn't feel natural, if I did I'd just get an auto with a paddle shifter.
Old 04-08-2013, 06:59 AM   #11
I think that's what I'm goin to do only thing is the bracket is 75$ and the whole shifter is 350
Old 04-08-2013, 07:08 AM   #12
gtstyles2's Avatar
Well the thing is that the bracket is the biggest problem with the MT82, the factory throws are actually not bad at all... Adding the short shifter only, u will still get more missed shifts under spirited driving
Old 04-08-2013, 07:12 AM   #13
The Blue Dragon
GrabberBlue5.0's Avatar
Spend the $110 and get the Barton 2 post, the main difference between my stock shifter with the Barton two post and my MGW is that the MGW has shorter throws and wayyyy less nvh. But the Barton two post turns a seemingly garbage shifter into an amazing piece of equipment
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 04-08-2013, 08:40 AM   #14
How good is the 2 post vs the reg barton bracket
Old 04-08-2013, 10:07 AM   #15
I just installed the Barton short shifter and 2 post bracket on ramps and jack stands. I love it!!! I was worried at first because it seems to have moved first and second more towards the center and I thought I messed up but I guess this is normal??
To explain this more I can't hold left all the way to get either first or second which has made me miss second a couple of times at high rpm shifts.
As far as NVH. I honestly can't even tell anything has changed until I actually change gears, then I do get a mechanical sound but I enjoy it and do t believe it adds anything unwanted. Whatever you choice enjoy!
Kjdjr18 is offline   Reply With Quote
Old 04-08-2013, 10:12 AM   #16
What is NVH? Sorry I'm a noob a
Old 04-08-2013, 10:19 AM   #17
No worries, NVH= noise,vibration,harshness.
Old 04-08-2013, 10:37 AM   #18
The Blue Dragon
Yea as far as nvh it's only on start up (sounds like the starter is in the passenger seat) and upon shifting, but the MGW has very little of either of those, mostly thanks to the dynamat
Old 04-09-2013, 06:50 AM   #19
I can deal with that. I was actually thinking about the MGW shifter but I heard it takes a wile to ship and its a more expensive.
Old 04-09-2013, 07:03 AM   #20
Jetag93's Avatar
The mgw is worth the wait & extra few $s.
2013 DIB Premium GT/CS, 6MT, Cervinis Ram-Air Hood, RTR Charcoal 19X9.5s, BBK Cat Deletes & X-Pipe, DMH E-Cutouts, GT500 Rear Diffuser w/GT500 Quad-tip Axle-Backs, AED E85 Lope Tune, Boss 302 Intake, BBK 85mm TB, JLT CAI, Dynatech Alum DS, FRPP 3.73's, Eibach Pro-Springs and Pro-Struts/shocks, J&M Adj Panhard Bar, UPR Billet Alum LCA's, BMR UCA & Bracket & Relo Brackets, Eibach Adj Sway Bars, MGW Shifter, Brembo brake kit w/14" slotted 2 piece Boogie Full Tilt Racing Rotors, Llumar 30/5 Tint
Jetag93 is offline   Reply With Quote
Old 04-09-2013, 07:24 AM   #21
How much more is the MGW
Old 04-09-2013, 07:32 AM   #22
tgmeyer's Avatar
+1 Would like to know this as well!
---------- Post added at 08:32 AM ---------- Previous post was at 08:30 AM ----------
Also- I'm always afraid of accidentally shifting into reverse and dropping my transmission. Is there a way I can stiffen up the spring that has me push down? Do you guys worry about this?
tgmeyer is offline   Reply With Quote
Old 04-09-2013, 07:39 AM   #23
Great question - I have the original Barton bracket ... what does the two-post do that the original doesn't? Is upgrading worth it?
Old 04-09-2013, 07:40 AM   #24
Defiant 5.0's Avatar
My Barton should be getting here either this weekend or early next week. I'm pretty stoked!
2011 Mustang GT 6mt
Mod List: H&R Super Sport Springs, Eibach Camber Bolts, Steeda Panhard Bar, BBK Cold Air Intake, Stack Racing Chrome Strut Tower Bar, Boss 302 Coil Pack Covers, Barton Shifter, Barton 2 Post Bracket, 4.10 Gear, 2013 Track Pack Wheels, QA1 Single Adjustable Rear Shocks, Roush Axle-back exhaust, CDC Chin Spoiler, Saleen Grille,
Defiant 5.0 is offline   Reply With Quote
Old 04-09-2013, 08:38 AM   #25
Not sure. I would like to find out....
Old 04-09-2013, 08:45 AM   #26
The Blue Dragon
Fully optioned they are about $425-450. Some people wait up to 6 weeks, I bought mine used and had it in a few days
Old 04-09-2013, 08:46 AM   #27
Hmmmm I don't think I'm going to do MGW. I think I'm going to do barton 2 post bracket or just the whole shifter
Old 04-09-2013, 08:46 AM   #28
The Blue Dragon
Honestly I don't know, I've never used the original piece, but their two post largely imitates the MGW shift bracket
Old 04-09-2013, 08:48 AM   #29
The Blue Dragon
The includes shifter, jam nut, and shift knob. It's very comparable up the Barton as far as price
Old 04-09-2013, 08:02 PM   #30
BlackSunshine50's Avatar
What y'all think about the hurst. I love the look. I have a 2post bracket now.
BlackSunshine50 is offline   Reply With Quote
Old 04-09-2013, 08:47 PM   #31
Check out the reviews on American Muscle.
2011 Mustang GT 6mt
Old 04-09-2013, 09:12 PM   #32
nosympathy's Avatar
Garbage doesn't begin to describe it. Buy the MGW or the Barton.
Old 04-09-2013, 10:21 PM   #33
Really?? What makes it so bad lol
Old 04-10-2013, 12:21 AM   #34
nosympathy's Avatar
Well no reverse lockout for starters. Though if you are good with a manual you shouldn't really *need* this but it is something you grow used too.
The hurst shifter is sloppier than the stock shifter. I'd take the stock shifter with just an after market bracket long before the Hurst.
Old 04-10-2013, 04:48 AM   #35
Yeah I Deff need the reverse lockout on my shifter.... I hope the barton keeps that
12:29 AM
