Barton shifter and bracket installed - Mustang Evolution
Old 04-08-2013, 02:31 PM   #1
ARfirefighter's Avatar
Region: Arkansas
Tackled this today. Took maybe an hour total. Car was in driveway on jack stands.
New parts
Tools
Removed console
Removed old bracket
Really Ford?!?! I mean really?!?!
Old shifter ready for removal
Removed
Cup transferred to new shifter
New shifter installed
New bracket installed
Ready to instal console
PITA boot put back on
Everything put back together and ready for a test drive
Test drive was freakin awesome! I love it. Goes into second smooth as butter now. Love the feel it has going into all gears.
ARfirefighter is offline   Reply With Quote
Old 04-08-2013, 04:32 PM   #2
Joey8's Avatar
How was the install? Any problems getting that rubber sleeve around the shifter??
2014 Sterling Gray GT (Ordered1/24) (Built2/25) (ETA3/12) (Picked Up 3/21)l 443.9/417.8 l
l l 6 Spd l Prem Pkg l Nav l TP l LthrRecaros l AmericanRacing 1 7/8 LTs l O/R H l JLT CF CAI lVMP Tuned l BorlaS Quads w/ResDel. l GT500Valance l KoniStr.T l K-Springs l GT500 Mounts l BMR UCA&LCA l BMR Relos l BMR Panhard l SpeedDawg Knob l 5.0 LloydsMats l Redline HoodStrts l Bobs CF Oil Sep. l 15% Tint l CDC Grille l StrtScn2 ChinSpoiler l GT/CS Fogs w/4500k l RTR DeckLid l CF Engine/CoilCoversl
Joey8 is offline   Reply With Quote
Old 04-08-2013, 05:07 PM   #3
Region: Arkansas
Instal wasn't bad, a little tight but I have large hands too. The 2 post bracket has no rubber sleeve, it's all metal. I had to use a wrench to tighten the bolts on the bottom part but it wasn't bad. It would've been easier with the drive shaft out and if I didn't have a 3" cat-back, but wasn't bad. If by rubber sleeve you mean the shift boot, yeah it was a PITA. I wound up getting the inner part over the shifter base, then used a small pry bar to get the outer part around the metal hole.
Old 04-12-2013, 07:50 PM   #4
When installing the shifter bracket, I've read you have to be "really careful" to not over tighten the nuts or you risk shearing off the bolts. How tight do they really need to be? My initial thought was that if I don't tighten them enough, they will get loose over time, but maybe they really don't need to be very tight? I'm probably over thinking this, but I really don't wanna shear those bolts off (I've read of a couple people who have accidentally done just that...)
matt6589 is offline   Reply With Quote
Old 04-12-2013, 07:55 PM   #5
Joey8's Avatar
I would use your best judgement. Also if you're worried about them coming out, just use some blu loctite and that'll hold them in securely.
Old 04-12-2013, 07:59 PM   #6
I guess my main concern was that these nuts/bolts holding on the bracket would be subject to large forces from the torque of the engine since the bracket is meant to hold the shifter in place and prevent movement.
Old 04-12-2013, 08:49 PM   #7
gtstyles2's Avatar
The screws holding the bracket on the underside are supposed to be tightened carefully, switching from one side to the other as u tighten so the bolt won't snap. Also, it should come with blue locktite
Old 04-12-2013, 09:19 PM   #8
tgmeyer's Avatar
Is the bracket there to make shifts precise and is the shifter there to make the shifts shorter? I feel like just the bracket will do me just fine and save me $200+.
tgmeyer is offline   Reply With Quote
Old 04-12-2013, 11:02 PM   #9
nosympathy's Avatar
The bracket will take some of the play out of the shifter. It won't be nearly the same as replacing the shifter too but will be an improvement. The aftermarket shifter doesn't just make the shifts shorter. It makes them even more mechanical and precise.
10:45 AM
