Just ordered my suspension stuff! - Mustang Evolution
Old 04-11-2013, 09:01 AM   #1
Evil2014GT's Avatar
Cant wait to get it on the car! I went with the Koni Str.t shocks/struts, steeda ultralite springs, j&m camber plates, and j&m adjustable panhard bar. Wanted to knock everything out at once instead of buying the shocks or camber plates later.
Evil2014GT is offline   Reply With Quote
Old 04-11-2013, 09:24 AM   #2
fastmustangs1's Avatar
Wonder if youll need a bump steer kit??
fastmustangs1 is offline   Reply With Quote
Old 04-11-2013, 09:44 AM   #3
Evil2014GT's Avatar
I think i will be ok for now, as the car is my daily driver and wont see the track at all. Mainly doing it just for a nice mean stance. I do plan on adding some adjustable LCAs, probably later this year.
Old 04-11-2013, 09:52 AM   #4
tc x 4's Avatar
You might want to add an uca to your list to correct the drive shaft pinion angle.
Old 04-11-2013, 09:57 AM   #5
Evil2014GT's Avatar
Another item i do plan on adding. Will i be causing alot of damage to the car in the meantime without the ucas?
Old 04-11-2013, 10:06 AM   #6
nosympathy's Avatar
Nope. I am dropped lower than you will be and still haven't gotten around to the UCA. Doing that soon though. Soon as my tax refund hits.
You just don't want to do that forever.
Old 04-11-2013, 10:10 AM   #7
Evil2014GT's Avatar
Great thanks for the quick answer. And i hear ya, this was my bonus check haha.
Old 04-11-2013, 10:29 AM   #8
tc x 4's Avatar
Won't really hurt anything, just cause some undo wear.
Old 04-11-2013, 10:50 AM   #9
Napoleon85's Avatar
Depends how much and how hard you drive it. I would do it sooner than later. While you're down there you might as well replace the mount too, since it's stamped steel as well and every bit as bad as the UCA itself.
Old 04-11-2013, 11:31 AM   #10
The Blue Dragon
GrabberBlue5.0's Avatar
Agreed with everyone on here. Replace the uca with an adjustable one and replace the stamped steel mount. Shortly after (or at the same time) I would replace the lcas and get some lca relocation brackets.
Uca with help correct pinion angle, proper angle for a street car is -2.5 to -3*
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 04-11-2013, 11:38 AM   #11
Evil2014GT's Avatar
Thanks for the info. It looks like a set of ucas will be my next mod. Hopefully i dont hurt anything driving it like this for a few months, until the fiancé lets me spend some more money on it haha.
Old 04-11-2013, 12:44 PM   #12
Napoleon85's Avatar
There is only one UCA, it's three-link suspension. I doubt you'll hurt anything unless you're repeatedly hammering on it over and over.
Old 04-11-2013, 01:40 PM   #13
Evil2014GT's Avatar
Good deal, thanks again! Ill just try and take it easy for the next few months
Old 04-11-2013, 02:35 PM   #14
Napoleon85's Avatar
I wouldn't even worry about it too much. If you flog it here and there you'll be fine. I just wouldn't let it go any longer than I have to. BTW - stock up on booze when you order the UCA and mount. You're going to need it.
Old 04-11-2013, 05:21 PM   #15
Evil2014GT's Avatar
Is it really that bad of an install? My good buddy used to be a diesel tech for ford, so he usually helps me out with my bigger projects. Unforutnalty he is working for a landscaping company now, working on all their equipment so I wont have access to a lift anymore, but I will atleast be able to use his air tools.
Whats the worst part of the install? Just getting everything to line up? Do you still need to drop the gas tank a bit to get to the mount?
Old 04-11-2013, 06:14 PM   #16
The Blue Dragon
The biggest pain is tightening the mount bolts in the tiny space of the driveshaft tunnel
Old 04-11-2013, 06:18 PM   #17
Evil2014GT's Avatar
Gotcha. I read through the Steeda install guide. Doesnt look to incredibly difficult. Seems the space is the biggest challenge. Might have to get the lady down in the garage and borrow her tiny hands for a bit to atleast get the bolts started lol.....on second though, nevermind, Id be paying that favor back for a year. Rather take the scrapes/cuts on my hands
2014 Mustang GT Base MT82 -Stock 3.73s, Roush axleback, Steeda 93R tune, Steeda Hi-flow X-pipe, 19" Charcoal AMR's, smoked front and rear side markers, 20% tint, quarter window louvers, Steeda Ultralite springs, Koni Str.t shocks/struts, MM camber plates, J&M adjustable panhard bar, BMR LCAs and relo brackets, Barton shifter and 2-post bracket, Black Modern Billet Grilles
Old 04-11-2013, 08:26 PM   #18
jayman33's Avatar
Get a whiteline UCA, easy to adjust, quiet and the least expensive of the bunch. I've installed a few WL, super easy.
jayman33 is offline   Reply With Quote
Old 04-12-2013, 11:03 AM   #19
Napoleon85's Avatar
How is it easier to install? I agree with Grabber that the only tough part was the bolts on the bottom of the mount in the driveshaft tunnel. I did mine with the over-axle pipes loose (I was replacing my mid-pipe at the same time), and that helped a lot. I think it would be a lot harder with the whole exhaust connected.
Old 04-12-2013, 11:08 AM   #20
nosympathy's Avatar
Yeah I don't see how either. Gonna stick with BMR myself.
Old 04-12-2013, 01:24 PM   #21
Napoleon85's Avatar
I run UPR myself. I didn't think BMR made a replacement mount?
Not trying to call Jay out - he's a stand up guy and I've ordered stuff from him before. Just curious how anyone could make that easier.
Old 04-12-2013, 01:37 PM   #22
nosympathy's Avatar
They sure do make a replacement mount. Plus all my other stuff is BMR.
04:55 AM
