tire size - Mustang Evolution
Old 04-13-2013, 08:07 PM   #1
Bladezx's Avatar
tire size
So I bought the shelby cs1 rims instead of the Foose outcast and was wondering what size of tires I should be running. They say 255 for the front and 295 for the rear since they are 20x9 and 20x11 but I was thinking wider maybe 315 or 305 also what tires do you recommend that will last at least one summer.
Bladezx is offline   Reply With Quote
Old 04-13-2013, 08:18 PM   #2
Black on Boss's Avatar
275/315
Old 04-13-2013, 08:19 PM   #3
TooSlow4U's Avatar
I have the same size wheels as you and I run 255s up front and 275s on the rear. I have Nitto motivo tires and then when I drag I go 305 nitto nt05s on the rear.
TooSlow4U is offline   Reply With Quote
Old 04-13-2013, 08:21 PM   #4
I run 275's on the rear on my stock 19x8.5's.
Old 04-13-2013, 09:01 PM   #5
TooSlow4U's Avatar
What are you getting at? Don't know why you quoted me.
Old 04-13-2013, 09:05 PM   #6
DaBluedude's Avatar
275 is a little too small for a 11" wide rim. I run 275 on my 9" but if you can do a 255 or 265 on your front would look good. 295-305 or maybe 315 rear will be ok. Gonna be expensive rubber.
2003 Mach 1
Old 04-13-2013, 09:09 PM   #7
I was sayin 275's are too small for a 11" rim. I would do 275's on the 9" fronts and 305-315 on the 11" rears.
Old 04-13-2013, 09:22 PM   #8
TooSlow4U's Avatar
Aww I see, I must have read the OP post wrong. I have 10' rears
Old 04-14-2013, 01:45 AM   #9
Bladezx's Avatar
Yeah well the brembo package rims suck and the paint comes off to easily so I'm using those as winter rims since you can't get a winter rim bigger then 17 and that will fit over the brembos so the new rims I'm getting will just be for summer use. I'm just looking for the best tire set up without over killing it. I was thinking of moving up by 10 for front of rear for width
Old 04-14-2013, 07:09 AM   #10
Widest I would go on the front is 9-9.5 max
Old 04-14-2013, 06:50 PM   #11
nosympathy's Avatar
It can be done with the right offset. Will rub a little. The 10" that is.
9.5 is the safe size. I run 285 on 19x9.5 on all four corners and have zero rub.
Old 04-15-2013, 06:43 AM   #12
Yuckooo13's Avatar
20x9 and 20x10 i run 255 and 285 sumitomo htrz3 good tire not as high performance as some pirellis or nittos but a fair price at 200 bucks for a rear tire and does give very good cornering abilities and launches just fine.
Brembo Brake package, 3.73s, Roush axle-back exhaust, 20% tint all around, All lights and reflectors tinted gun smoke, 20X8.5 and 20x10 wheels and tires, Lowered 1.5" with Eibach pro springs, J&M panhard bar, BBK CAI, Bama 93R tune, JLT oil separator, Black "5.0" badge, Black billet shift knob
Yuckooo13 is offline   Reply With Quote
Old 04-15-2013, 07:05 AM   #13
The Blue Dragon
GrabberBlue5.0's Avatar
I have 19x9 with 275's and my rears are 19x10's with 305's. 295 is definitely on the small side for an 11" rim. Not that it won't work but you could easily go up to 325/335, but like mentioned above, they will be very expensive. My 305's I got a decent deal on at $760 out the door (mounted, road force balanced, and sales tax) for the pair. They are michelin pilot super sports on the rear
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 04-15-2013, 08:19 AM   #14
OzzyLiriano's Avatar
I just put on Invo 275/35/20 front 295/35/20 rear, and that is on a 9 inch rim upfront and 10.5 rear
With that being said i suggest 275/35/20 front
315/35/20 rear
OzzyLiriano is offline   Reply With Quote
Old 04-15-2013, 08:24 AM   #15
Michelen are the best!
Old 04-15-2013, 08:58 AM   #16
The Blue Dragon
Agreed
Old 04-16-2013, 03:49 AM   #17
tc x 4's Avatar
I always liked Goodyears, guy at discount tire talked me into the michelens, I'll never run anything else.
10:20 AM
