Gear or tire swap - Mustang Evolution
Old 04-16-2013, 10:45 AM   #1
2011's Avatar
Gear or tire swap
I'm hitting the drag strip this year with my 2011 mustang gt with 3:31 manual. I was thinking about putting 17" tires in the rear that are shorter or changing gears. I'm trying to run faster than 12.9 in 1/4. If I did change gears I would prob put 3:55 since it is my daily driver.
2011 is offline   Reply With Quote
Old 04-16-2013, 10:54 AM   #2
1lowGT's Avatar
Get some light 17in wheels
Old 04-16-2013, 11:57 AM   #3
3.31 to 3.55 won't do much. 3.73 isn't bad at all for a daily driver.
Mikeyt03 is offline   Reply With Quote
Old 04-16-2013, 12:07 PM   #4
1lowGT's Avatar
Yeah thats not much of an increase. I would go with 3.73s or get you a lightweight wheel set up. Drag lites or something
Old 04-16-2013, 12:13 PM   #5
Smoke's Avatar
I swapped my 31s for 73s. night and day difference when its a lil cold outside u can forget about traction lol
Smoke is offline   Reply With Quote
Old 04-16-2013, 12:34 PM   #6
tc x 4's Avatar
I'm probably the only person on this fourm that will agree with your choice of gear. The car needs just a little more gear to get you in the power band down low.
Old 04-16-2013, 12:39 PM   #7
tc x 4's Avatar
[QUOTE="2011"]I'm hitting the drag strip this year with my 2011 mustang gt with 3:31 manual. I was thinking about putting 17" tires in the rear that are shorter or changing gears. I'm trying to run faster than 12.9 in 1/4. If I did change gears I would prob put 3:55 since it is my daily driver.
Old 04-16-2013, 12:42 PM   #8
2011's Avatar
What tires do you have that you lose traction. I test drove a mustang with 3:73 and did not like it because first gear was two low. If I did put 3:73's on and it was cold would I have to worry about putting it sideways at the drag strip with the traction control off?
Old 04-16-2013, 05:00 PM   #9
nosympathy's Avatar
I have 3.73 gears and summer tires with suspension work done and thought she fights to hold the ground a little when it is cold I've never lost control of her and that is with the TC off. We are talking upper 30s. Now if it is 55+ she grips like a champ through every gear.
3.73 are perfect gears. 3.55 isn't enough of a change haha.
Old 04-16-2013, 06:53 PM   #10
Smoke's Avatar
Excatly .I dont have suspension work done but under 50 degrees 1 and 2 is hell .over 50 degrees she do grip well but I have a tune also
---------- Post added at 07:53 PM ---------- Previous post was at 07:48 PM ----------
Yea its a bit low but I just take off in second most of us do . But wit some good tires and a tune that thing will b a rocket out the hole
Old 04-16-2013, 10:12 PM   #11
Evil2014GT's Avatar
+1 my car is my daily driver as well, and I love the 3.73s. I do spin quite a bit though but thats mainly due to the sstock suspension. Hoping that changes soon with my recent purchases.
2014 Mustang GT Base MT82 -Stock 3.73s, Roush axleback, Steeda 93R tune, Steeda Hi-flow X-pipe, 19" Charcoal AMR's, smoked front and rear side markers, 20% tint, quarter window louvers, Steeda Ultralite springs, Koni Str.t shocks/struts, MM camber plates, J&M adjustable panhard bar, BMR LCAs and relo brackets, Barton shifter and 2-post bracket, Black Modern Billet Grilles
Evil2014GT is offline   Reply With Quote
Old 04-17-2013, 06:38 AM   #12
hobo1's Avatar
3.73 gears, stock PZeroes and just had a susp change to frpp FR3 handling kit with adjustable shocks and dampers. I used to lose the rear in cold weather but now it's too warm to see how suspension change will help. It can be scary when u need to pull out quick to merge or beat the car coming from your left. A mustang looks fast, then seems to just sit after pulling into traffic (wheel spin!)
hobo1 is offline   Reply With Quote
Old 04-17-2013, 07:04 AM   #13
Smoke's Avatar
My girl gets pissed at me because I dont pull out in traffic quick .I try to explain to her I caint or do u want to do dougnuts but like u say warmer weather she grips alot better
Old 04-17-2013, 11:43 AM   #14
Quick fix...wait until no cars are coming, go ahead and pull out fast, let it fish tale a bit and she will never say a word again.
Old 04-17-2013, 11:47 AM   #15
Rosco's Avatar
+1
1998 Bright Atlantic Cobra - 3:73's, BBK ls, Pro 5.0, 96 Cobra STB, Borla XR-1 Catback, Custom Catch Can, Spec clutch, MM Firewall adj, FRPP wires, RSD, Spoiler delete, 245/275 BF Goodrich g sports on chrome 95 cobra r's
1998 V6 Mustang : SOLD!
Rosco is offline   Reply With Quote
Old 04-17-2013, 11:47 AM   #16
The Blue Dragon
GrabberBlue5.0's Avatar
I would change tires over gears, if you get a 26" slick with the 3.31 gears if will keep you in 4th gear through the 1/4, not to mention slicks will cut times down much better than gears. I would do gears also but if its one or the other do tires.
Also keep in mind that if you do change to 26" slick then change to 3.73's you will need to upgrade to a 28" slick to stay in 4th.
And if you go FI you will want those 3.31's back... It's give and take really
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 04-17-2013, 11:48 AM   #17
Smoke's Avatar
+ 2
Old 04-17-2013, 11:57 AM   #18
tc x 4's Avatar
That's some good advice
Old 04-17-2013, 12:16 PM   #19
JG5.0's Avatar
Really is best advice on here. I bought mine with 373s and it was good, no complaints. Now with FI it's a highway car, not a bad thing, but the gears go too fast down low and I wish I had 331s now. I'd do the tire option especially if boost is a possibility down the road.
JG5.0 is offline   Reply With Quote
Old 04-17-2013, 02:18 PM   #20
I have 4.10's and its a d/d, lots of suspension work and in my op 4.10's are fun as hell, you never lose on the line and once you hit third or forth your in the power band and its a beast...but I like my cars set up that way...just my op
Boss IM, with Araid cai, bama 93 race tune, GT500 cat back, jba off-road x-pipe & longtubes, mgw shifter,4.10 gears, Aluminum Flywheel & driveshaft, Adjustable Panhard Rod, BMR adj. uca & lca, BMR relo. brackets, BMR Springs with 1.5" drop, BMR adj. swaybar, BMR tubular K member 1/2 drop motor mounts & BMR tubular A arms, steeda alu. rad. support, aluminum water pump pully, 85mm BBK TB, Rear seat delete. Boss oil cooler, Battery in trunk. AC delete, Evap delete
brianw64 is offline   Reply With Quote
Old 04-17-2013, 02:49 PM   #21
Blu13stang's Avatar
Do tires first , then gears if its necessary . I did 12.90 in Oklahoma with an Auto & 3:15 gears , I do have Tuner. Borlas, Drag Radials 275x 18's and the stuck good when properly heated
Blu13stang is offline   Reply With Quote
Old 04-19-2013, 07:08 PM   #22
hobo1's Avatar
All good points. But the car came with this setup, so i need to wait till its time to replace rubber. Anyway warm weather is here!
06:52 PM
