Suspension Question - Mustang Evolution
Old 04-17-2013, 12:29 PM   #1
OzzyLiriano's Avatar
Suspension Question
Which components of the usual suspension upgrades are the ones that really cut down in the drag strip?
The lcas? The springs?
Usual Suspension Uprgrade:
Lca
Lca brackets
Panbard bar
Springs
Koni yellow
Steeda hd mount
I am asking to learn more about these cars and what really helps them be faster in a straight line while still be a dd, thanks
OzzyLiriano is offline   Reply With Quote
Old 04-17-2013, 05:00 PM   #2
The Blue Dragon
GrabberBlue5.0's Avatar
Lca brackets. They will help transfer weight to the rear wheels.
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 04-17-2013, 05:09 PM   #3
It seem the drag race guys are using the stock spring. I could be wrong.
I talked to Kelly at BMR and he said there lowering spring are great for drag racing.
I would suggest welding your axle tubes when using the Relocation brackets. I'm having my tubes welded in a couple days.
Change the gears Or TQ Conver
racksteris is offline   Reply With Quote
Old 04-17-2013, 11:23 PM   #4
Yes thats what i thought was the biggest factor, the lcas, thanks for the input guys
Old 04-18-2013, 08:32 AM   #5
Yup. The weight transfer helps with traction. BMR springs are very soft which is great for drag stripe like you said.
Mikeyt03 is offline   Reply With Quote
Old 04-18-2013, 01:22 PM   #6
tc x 4's Avatar
That's where you need to start. If you decide to get serious, different spring rates will help too.
07:43 AM
