Difficulty shifting into 3rd - Mustang Evolution
Old 04-17-2013, 06:29 PM   #1
Davey13GT's Avatar
If I am accelerating quickly, sometimes the car doesn't want to do a hard shift into 3rd gear. It's almost like the shifter gets blocked. It's the only gear that does this to me. This isn't my first manual Mustang, but I never had problems with my older one. Could it be because the car is so new, the gear box needs to loosen up a bit? I'm worried this is gonna screw me at the track. I can do a smooth shift into 3rd every time under normal acceleration, but if I'm racing through the gears, I get this jam in 3rd almost every time. Any ideas?
Davey13GT is offline   Reply With Quote
Old 04-17-2013, 07:03 PM   #2
gtstyles2's Avatar
Yea that's normal, the factory shifter bracket is garbage and under high rpm it's pretty likely you can miss gears. If u do a search on MT82 transmissions u will find a long list off ppls experience with these transmissions with solutions. Google will be your best friend in this particular situation, u will have hours of reading material so get comfortable
Old 04-17-2013, 07:07 PM   #3
DWC_SmOziLLa's Avatar
Welcome to the wonderful world of the mt82 transmission and its sorry excuse for a shifter. This is a very common problem with the stock assembly. It's due to the crappy remote linkage and bracket. But your problems can be solved with 3 letters...
MGW
End of story. Pull the trigger, you will not regret it. And this will all be a thing of the past. Good luck!
Old 04-17-2013, 07:42 PM   #4
ThinBlueLine's Avatar
MGW
I concur.
BAMA TUNED
LETHAL O/R H, GEN2 OVER AXLE PIPES & GT500's
DRIVESHAFT SHOP ALUMINUM DS W/ BMR LOOP
MGW SHORT SHIFTER
CDC CHIN SPOILER W/ BLACK BILLET GRILLS
BLACK JLT OIL SEPARATOR
ThinBlueLine is offline   Reply With Quote
Old 04-17-2013, 07:51 PM   #5
The Blue Dragon
GrabberBlue5.0's Avatar
Yup, MGW is completely worth it. Or at the very least get the Barton 2 post shift bracket. I've had both, I'd pay the money for the MGW all over again
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 04-17-2013, 08:03 PM   #6
I don't have your same car or transmission but i do have an MGW, its an amazing shifter. Get it and don't look back.
Old 04-17-2013, 08:27 PM   #7
TooSlow4U's Avatar
MGW for the motherflippin win!!!
But I don't have one lol
TooSlow4U is offline   Reply With Quote
Old 04-17-2013, 08:33 PM   #8
Joey8's Avatar
I agree with the MGW from what ive read being that I dont have the MGW i cannot speak from experience. I am still using the stock shifter and bracket (only have 650 miles on my mustang) and although i maybe really got on it 4 or 5 times i find that if you kind of guide it into 3rd it helps. I go from 1 to 2 going straight down no problem then 2nd to 3rd i kind of go in at a slight angle kind of like 4 to 5 and find that helps a bit. I never found myself in 5th instead of 3rd and this method seems to be working at least till i go with the MGW. Try it out.
2014 Sterling Gray GT (Ordered1/24) (Built2/25) (ETA3/12) (Picked Up 3/21)l 443.9/417.8 l
l l 6 Spd l Prem Pkg l Nav l TP l LthrRecaros l AmericanRacing 1 7/8 LTs l O/R H l JLT CF CAI lVMP Tuned l BorlaS Quads w/ResDel. l GT500Valance l KoniStr.T l K-Springs l GT500 Mounts l BMR UCA&LCA l BMR Relos l BMR Panhard l SpeedDawg Knob l 5.0 LloydsMats l Redline HoodStrts l Bobs CF Oil Sep. l 15% Tint l CDC Grille l StrtScn2 ChinSpoiler l GT/CS Fogs w/4500k l RTR DeckLid l CF Engine/CoilCoversl
Joey8 is offline   Reply With Quote
Old 04-17-2013, 08:35 PM   #9
BlackBetty5.0's Avatar
Another vote for the MGW I was having the same issues I installed the MGW 3 months ago and haven't missed third since.
BlackBetty5.0 is offline   Reply With Quote
Old 04-18-2013, 12:46 AM   #10
BUSHGUTS's Avatar
I went with barton. Havent missed a shift since. Heres why this problem arises. The gum rubber bushing is held in by zip ties. And the housing is made of crappy thin metal that doesnt give any solidity. The rubber just keeps moving around which mis aligns 3rd gear
shifter bracket (stock vs aftermarket)
BUSHGUTS is offline   Reply With Quote
Old 04-18-2013, 06:25 AM   #11
Davey13GT's Avatar
You've got to be kidding me right? A $35-37,000 performance car, the bushing looks like that? Now I'm not happy.
Old 04-18-2013, 06:42 AM   #12
The Blue Dragon
I think ford had comfort in mind a little too much when they designed this car. If you're not a hard core enthusiast then this car is great because from the factory it's pretty quiet and comfortable, but once you start to push it you really begin to see some of its performance oriented flaws
Old 04-18-2013, 06:44 AM   #13
tc x 4's Avatar
Energy Suspension sells a poly bushing for $13.99, thats supposed to solve the issue. That POS is fine when driven like a normal car. But I see your point, who drives a 420hp car normal.
Old 04-18-2013, 06:58 AM   #14
Defiant 5.0's Avatar
Not trying to thread jack, so I apologize in advance. I too am having occasional troubles with shifting into third. However, when I'm in 2nd, I'll go to shift out of 2nd and it won't let me. It locks into 2nd gear. I will then try again a half a beat later (clutch still engaged) and it shifts smooth as silk. It seems to happen most after a bit of spirited driving. I took it to the dealer yesterday and we couldn't recreate it. It only happens sometimes.
I could really use some help because I'm less than 10k miles until my warranty expires.
2011 Mustang GT 6mt
Mod List: H&R Super Sport Springs, Eibach Camber Bolts, Steeda Panhard Bar, BBK Cold Air Intake, Stack Racing Chrome Strut Tower Bar, Boss 302 Coil Pack Covers, Barton Shifter, Barton 2 Post Bracket, 4.10 Gear, 2013 Track Pack Wheels, QA1 Single Adjustable Rear Shocks, Roush Axle-back exhaust, CDC Chin Spoiler, Saleen Grille,
Defiant 5.0 is offline   Reply With Quote
Old 04-18-2013, 07:06 AM   #15
Napoleon85's Avatar
Originally Posted by gtstyles2 View Post
Yea that's normal, the MT82 is garbage and under high rpm it's pretty likely you can miss gears.
Fixed that for ya.
Old 04-18-2013, 07:08 AM   #16
tc x 4's Avatar
Originally Posted by Napoleon85
Fixed that for ya.
Nice job
Old 04-18-2013, 07:09 AM   #17
KARgt13's Avatar
I think the rubber shrinks when it's cold and you get a lot of deflection, whereas I seem to have less issues when it's hot outside.
When you say it won't let you, do you mean that the clutch pedal gets really difficult to push in? Because occasionally I have that problem.
KARgt13 is offline   Reply With Quote
Old 04-18-2013, 07:34 AM   #18
The clutch pedal seems to work fine, the shifter just won't move out of 2nd. But it always goes on the second try every time.
2011 Mustang GT 6mt
Old 04-20-2013, 11:02 AM   #19
Get the MGW & never look back.
graystone2013 is offline   Reply With Quote
Old 04-20-2013, 11:20 AM   #20
I just put the Barton in this morning. I love it! I got a great deal on it.
2011 Mustang GT 6mt
Old 04-20-2013, 01:49 PM   #21
Steeda bracket and a traditional ball knob do wonders for the stock shifter.
However, you need to rethink shifting on this thing. It's not a toploader. Guide the shifts in positively but, with minimal force and it works pretty well.
Old 04-21-2013, 09:03 AM   #22
BUSHGUTS's Avatar
Problem is that this bracket is completely exposed to the outside elements. Hot cold snow rain salt etc. it will dryrot in no time and then you will have serious problems.
Old 04-21-2013, 01:29 PM   #23
Joyride's Avatar
Once I installe the MGW an broke it in, the 1-2-3 shifts were so much easier and smoother. Still can't seem to get 4th to go in easy though, still locks me out sometimes.
---------- Post added at 01:29 PM ---------- Previous post was at 01:26 PM ----------
Same thing about the clutch to. Sometimes it gets sucked in and feels really weird. Does anyone know a fix for this?
Joyride is offline   Reply With Quote
Old 04-22-2013, 08:01 AM   #24
The Blue Dragon
Joyride, what year is your mustang?
Also with the 4th gear lockout that sounds more like bad synchros than anything
Old 04-22-2013, 11:30 AM   #25
tc x 4's Avatar
Gonna say, that's the first review I've ever heard anything bad about.
Old 04-22-2013, 01:18 PM   #26
Same, I never hear anything bad about them
Old 04-22-2013, 05:24 PM   #27
Srohda's Avatar
Yep, we all got got! I swapped mine out a few months ago with MGW and I love it.
2012 GT Premium w/Brembo
Roush axle backs
MGW short throw shifter
Srohda is offline   Reply With Quote
Old 04-22-2013, 09:15 PM   #28
Joyride's Avatar
2013, it feels like it doesn't want me going in at certain rpms.
Old 04-24-2013, 06:32 AM   #29
2013mustang5.0's Avatar
Do any of you guys have the clutch stick down after a high rpm shift? It seems like every once in a wile When I take it to redline and shift real fast the clutch sticks like past midway to the floor. Should I be worried about this?
2013 mustang 5.0 track pack(first mustang)
2013mustang5.0 is offline   Reply With Quote
Old 04-24-2013, 06:52 AM   #30
I would be. Take it to Ford and tell them it's sticking. They'll probably give you a new clutch. There's a whole stickied thread about it over at SVTPerformance.
2011 Mustang GT 6mt
Old 04-24-2013, 07:11 AM   #31
Sounds like this is pretty common had the same problem
Bakiebruno5 is offline   Reply With Quote
12:13 AM
