How much in gains? - Mustang Evolution
Old 04-21-2013, 05:41 PM   #1
Joyride's Avatar
How much in gains?
How much lb ft and hp should I expect to gain with kooks 1 7/8 LTH, boss catted H w/ boss side dump exhaust, a Torq tune, Steeda CAI, and boss IM? I was told 500ish at the crank. I already have Borla mufflers. Thanks
Joyride is offline   Reply With Quote
Old 04-21-2013, 05:43 PM   #2
Rapinator126's Avatar
Probably 430ish at tires. Maybe a little more
Old 04-21-2013, 05:47 PM   #3
Joyride's Avatar
Thanks, just wanting to make sure.
Old 04-21-2013, 05:47 PM   #4
nosympathy's Avatar
Ehh maybe about that. Depends on the dyno and your car too.
Old 04-21-2013, 05:53 PM   #5
If its a good tune and they spin it to 7600 rpms then you should see about 430 on a dyno jet. Will read lower on a mustang dyno
Old 04-21-2013, 07:17 PM   #6
Joyride's Avatar
They have a mustang dyno and are raising the rev limiter to 7300
Old 04-21-2013, 07:22 PM   #7
nosympathy's Avatar
only 7300? lol...my stock manifold lets me go that high. You need to spin higher to make that boss mani worth while.
Old 04-21-2013, 07:32 PM   #8
Of they are only going to 7300 then you might as well not even have the boss mani.
---------- Post added at 08:31 PM ---------- Previous post was at 08:31 PM ----------
*if
---------- Post added at 08:32 PM ---------- Previous post was at 08:31 PM ----------
76-7800 is where it really shines and you are using it to its advantage.
Old 04-21-2013, 08:50 PM   #9
Joyride's Avatar
I'll ask about the tuning once all the parts come in. I have to wait a second extra week because of some stuff being on back order or whatever. Ugh
Old 04-21-2013, 09:37 PM   #10
Definitely interested in what they can do
kornflake7 is offline   Reply With Quote
Old 05-01-2013, 05:26 PM   #11
Joyride's Avatar
Just left the stang at Torq to have the parts installed. Should be done by Saturday.
Old 05-01-2013, 05:31 PM   #12
Redstang1's Avatar
Well I put down 430 whp with just cat deletes and exhaust with a really good tune and BBK intake so I would guess around 450+whp
Redstang1 is offline   Reply With Quote
Old 05-01-2013, 06:06 PM   #13
Spinning regularly to 7600-7800 rpms is a bit overkill to justify a manifold. I will shift my car right at 7000-7200 and it never wants to go straight at that rpm. I can only imagine alot of bolt ons and shifting that high must be crazy. My buddies procharged 5.0 is down right scary on the highway but I've never driven it.
Old 05-01-2013, 06:43 PM   #14
nosympathy's Avatar
My car with full suspension work and big wide beefy summer tires has zero issue staying straight through 7200ish RPM with 3.73 gears and I bet spinning to 7800 would be zero issue either.
Old 05-02-2013, 09:55 AM   #15
I have 4.10's and Boss man. with every bolt on I can get and it regularly see's 7600rpm and it loves it...! Once you hit 7 grand the Boss is a beast
Boss IM, with Araid cai, bama 93 race tune, GT500 cat back, jba off-road x-pipe & longtubes, mgw shifter,4.10 gears, Aluminum Flywheel & driveshaft, Adjustable Panhard Rod, BMR adj. uca & lca, BMR relo. brackets, BMR Springs with 1.5" drop, BMR adj. swaybar, BMR tubular K member 1/2 drop motor mounts & BMR tubular A arms, steeda alu. rad. support, aluminum water pump pully, 85mm BBK TB, Rear seat delete. Boss oil cooler, Battery in trunk. AC delete, Evap delete
brianw64 is offline   Reply With Quote
Old 05-08-2013, 12:29 PM   #16
Joyride's Avatar
Finally, the stang is ready. Leaving now to pick her up and get a dyno sheet. Will upload an exhaust vid once I get the chance! dde0e
Old 05-08-2013, 05:05 PM   #17
Joyride's Avatar
And now she's done. Rev limiter is set to 7600. Stock power was 366 now 418 so 50 rwhp increase. Power is planted really well now. Night and day difference when cutouts flip open. I notice the CAI is always hot. It was 88 out and the inlet air never went below 100. Heats up real fast to 150 in stop and go traffic. The stock air box was A better cai than aftermarket, strange. I Didn't actually feel more powerful, I guess because of the heat soak and suspension?
ID:	106750   Click image for larger version
ID:	106752   Click image for larger version
Old 05-08-2013, 08:44 PM   #18
Joyride's Avatar
Here's a teaser. Will try to get some quality stuff when I can.
Old 05-08-2013, 09:04 PM   #19
Very nice hp curve! I think most of those gains are boss intake and tune related, but if you match factory redline for the 2nd run there is a good 30+rwhp difference which is impressive. You immediately made more torque and you have a nice somewhat flat torque curve, but I'm suprised peak torque remained unchanged. If anything, the headers just made you peak rwtq sooner and kept a little more consistency over the curve. Either way, pretty cool for bolt on modifications.
11:55 AM
