Upgrade!!! - Mustang Evolution
Old 04-23-2013, 10:50 PM   #1
a_duha_1023's Avatar
Upgrade!!!
does anyone have any picture of a 5.0 with 20 inch roush rims?
a_duha_1023 is offline   Reply With Quote
Old 04-23-2013, 10:50 PM   #2
Venomouz831's Avatar
It's definitely an upgrade! Post pics!
)02 Gt, Founder of WE2G
Old 04-24-2013, 07:57 AM   #3
Sharkkk's Avatar
Anyone? I'm looking at 20's also. But read somewhere on here that it's only for looks? Not to thread jack, but what are the wheel sizes you guys recommend and why? And what kind of rubber? Thanks in advance!
Sharkkk is offline   Reply With Quote
Old 04-24-2013, 08:28 AM   #4
Evil2014GT's Avatar
20" rims are not recommended for track use, because of the added weight, and smaller, but firmer side wall of the tire. Its obvious why the extra weight will slow you down, but the reason why a smaller sidewall is bad is because it will cause you to spin and loose traction more. The smaller the sidewall, the firmer it will be, decreasing your traction, and your 60' times. Added width will help your plant the power, but a 20" rim will take it back away... Im new to the 5.0 mustang, so im not sure what the ideal tire size is for the track., but im sure someone will chime in soon.
2014 Mustang GT Base MT82 -Stock 3.73s, Roush axleback, Steeda 93R tune, Steeda Hi-flow X-pipe, 19" Charcoal AMR's, smoked front and rear side markers, 20% tint, quarter window louvers, Steeda Ultralite springs, Koni Str.t shocks/struts, MM camber plates, J&M adjustable panhard bar, BMR LCAs and relo brackets, Barton shifter and 2-post bracket, Black Modern Billet Grilles
Evil2014GT is offline   Reply With Quote
Old 04-24-2013, 08:54 AM   #5
nosympathy's Avatar
I run 19X9.5 on all four corners with 285-35-19s on all four corners. She hugs turns like a pro.
Personally I think a 19" rim is best for this car. Ford thinks so too. The Boss 302, the track car, runs 19X9 fronts and 19X9.5 rears. If that tells you anything.
If you are really worried about weight you can do wheels that are forged which will make them lighter. Forgestar is a well recommended brand for this. You'll be looking about 2500 bucks minimum for rims and tires to start.
Old 04-24-2013, 08:58 AM   #6
Rapinator126's Avatar
Boss wheels are 19x10 for the back. I have the original Ford racing Laguna seca ones on my car.
Old 04-24-2013, 09:00 AM   #7
nosympathy's Avatar
Yeah, sorry, should have been more clear. Stock Boss 302 is 19X9.5 rears and the Laguna Seca is 19X10 rears.
Old 04-24-2013, 09:01 AM   #8
Evil2014GT's Avatar
Im happy with my setup too. 19x8.5s front, 19x10 rear, with 275/40/19. I would have preferred a bit wider tire, but i got them as a package from AM.
Old 04-24-2013, 09:10 AM   #9
You aren't rubbing at all with the 285/35's up front?
Old 04-24-2013, 09:16 AM   #10
nosympathy's Avatar
not even a little. There is a guy on a different forum that is running 305 tires up front and he only rubs a little if that tells you anything.
Old 04-24-2013, 09:56 AM   #11
92mustang2.3's Avatar
I've ran a 12.7 @ 111 on 20x9 up front and 20x10 shelby razor wheels
92mustang2.3 is offline   Reply With Quote
Old 04-24-2013, 10:01 AM   #12
Evil2014GT's Avatar
But with what mods??
Old 04-24-2013, 10:04 AM   #13
Just bassani mufflers and 3in X pipe from pypes
---------- Post added at 10:04 AM ---------- Previous post was at 10:03 AM ----------
All i have are bassani mufflers and X pipe no tune yet
Old 04-24-2013, 01:40 PM   #14
tc x 4's Avatar
This is the interweb, without a slip, it didn't happen.
Old 04-24-2013, 01:59 PM   #15
Alright I'll try and load it when I get off work
Old 04-24-2013, 02:27 PM   #16
Evil2014GT's Avatar
Lol
Old 04-24-2013, 08:13 PM   #17
Lol
Old 04-24-2013, 08:43 PM   #18
Well tc x 4 here's the slip
Old 04-24-2013, 08:53 PM   #19
Evil2014GT's Avatar
What were the track conditions like? Also what tires are were running?
Old 04-24-2013, 08:58 PM   #20
tc x 4's Avatar
Good deal
Old 04-24-2013, 08:58 PM   #21
I'm running the Nittos 555 and had 40 psi , plus I wanted to be the first one to run that night knowing the track was prep and ready. Can't remember what the temps were that night.
Old 04-24-2013, 09:03 PM   #22
Evil2014GT's Avatar
Was gonna say your 60 foot times are pretty good for a street tire. Those 555s def helped you out. Auto or manual and what gears?
---------- Post added at 11:03 PM ---------- Previous post was at 11:02 PM ----------
No suspension work either?
Old 04-24-2013, 09:04 PM   #23
6 speed manual with 355 gears
Old 04-24-2013, 09:04 PM   #24
Evil2014GT's Avatar
Old 04-24-2013, 09:05 PM   #25
Sr lowering springs
Old 04-24-2013, 09:07 PM   #26
tc x 4's Avatar
3.55s is what I'm thinking my car needs. Car needs just a little more down low, HP will do the rest.
Old 04-24-2013, 09:11 PM   #27
Evil2014GT's Avatar
What are you running now?
Old 04-24-2013, 09:12 PM   #28
tc x 4's Avatar
Stock 3.31s
Old 04-24-2013, 09:16 PM   #29
Evil2014GT's Avatar
Stock 3.31s
Yeah they should definitely help you out. I can't wait to get out and see what mine will do. After seeing a 12.7 on 20's, with just springs, exhaust and 3.55s, Im pretty pumped to see what mine can do once i get some lcas and a better rear tire lol.
Old 04-24-2013, 09:22 PM   #30
Plus I'm running 93 octane
Old 04-24-2013, 09:28 PM   #31
Evil2014GT's Avatar
I always run 93.
Old 04-26-2013, 12:32 AM   #32
Got the 20 inch roush rims on the 5.0 going to the track this weekend i'll let you know how it goes
Old 04-26-2013, 05:23 AM   #33
Evil2014GT's Avatar
Looks good man! Have fun at the track, and yeah please let us know how you do!
---------- Post added at 07:23 AM ---------- Previous post was at 07:22 AM ----------
Btw what tires are on there?
01:36 AM
