hood scoop, please help lol. - Mustang Evolution
Old 04-26-2013, 10:40 PM   #1
so i got this hood scoop used, and now i have problems.
this hood scoop requires holes to be drilled in the hood, 4 holes to be exact, I am scared to death to do this..lol...it did not come with the templets..just the scoop....is there some were i can download the templete
? or buy one? any help would be greatly apreciated..hod scoop shown below.
bugsy is offline   Reply With Quote
Old 04-26-2013, 10:41 PM   #2
Old 04-26-2013, 10:43 PM   #3
Black on Boss's Avatar
I would 3m tape it.
Old 04-26-2013, 10:45 PM   #4
cant just use 3m tape, holes must be made for the scoop to site flush because of the studs that stick out the bottom.
Old 04-26-2013, 10:58 PM   #5
Ah that sucks. Maybe you could grind off the studs. I definitely wouldn't go drilling holes in my hood.
Old 04-26-2013, 11:02 PM   #6
Contact AM because they have them and use a body shop to install it
Old 04-26-2013, 11:06 PM   #7
nosympathy's Avatar
Yeah I'd never put a hood scoop like that with just 3M tape. You are just asking for it to break free and bust your windshield.
Normally most things held by 3M tape don't have the wind force against them the hood scoop does.
Also OP you could buy the stuff to make the template. Just two long strips of paper. Run them across the hood scoop and mark the holes then with them stuck onto the hoodscoop stick it to the hood and pull the paper tight and tape it down pull the hood scoop off leaving the paper on the hood and you have your holes to make and drill.
Old 04-27-2013, 05:28 AM   #8
tc x 4's Avatar
Yes, make your own template from paper or cardboard. If you can't do that, maybe "you" shouldn't be drilling holes in your hood.
Old 04-27-2013, 06:56 AM   #9
Davey13GT's Avatar
Doesn't the Roush hood scoop mount with just 3m? I wouldn't want to drill holes in my hood either, not for a non functional hood scoop. What if you don't like the look? You'd have to get the holes repaired.
Davey13GT is offline   Reply With Quote
Old 04-27-2013, 10:18 AM   #10
Yes the roush installs with 3M tape only. It was the aftermarket companies that started doing the drilling in the hood because they are mimicking a factory part and not going to get it to work like the roush piece. These hood scoops like to peel around the edges because of warping from heat/cold and the hikes drilled are supposed to help it stay planted
Old 04-27-2013, 10:21 AM   #11
DWC_SmOziLLa's Avatar
The roush hood scoop for the '13's require drilling.
Old 04-27-2013, 10:39 AM   #12
nosympathy's Avatar
Yup
Old 04-27-2013, 12:34 PM   #13
That's not a 13 hood scoop....
Old 04-27-2013, 02:29 PM   #14
no mine is for a 12. but i did make a templete. out of cardboard, what call me crazy, buy there seems to be a slight dip in the scoop. and a dip in the hood, wo nder if theis will makje a diffrence come time to drill? because the screws are level. but scoop and hood have a curve? i just am realy uncomfortable drilling holes in my car.
Old 04-27-2013, 02:34 PM   #15
I would make a body shop install it. Make sure you use an alcohol pad and clean the hell out of that cowl otherwise that new 3M tape won't adhere properly. Also, if you do decide to drill. Do not, and I repeat DON'T touch the metal shavings from the drill bit. Get something that blows compressed air and spray them off or spray them off with a water hose but don't touch them. They with scratch your paint very badly.
Old 04-27-2013, 02:50 PM   #16
nosympathy's Avatar
Not a full piece of cardboard? OK...so for example. AMs template is two long thin pieces of paper. Maybe 2" wide by 30" long. You stick these tow the hood scoop and then the hood scoop on the hood and pull them tight and tape them down to the hood. Then you have your spot to drill. I also recommend before drilling to tape newspaper or whatever all over the spot you are drilling instead of just blasting the shavings off. Even doing that they can still scrape the paint.
Old 04-27-2013, 03:43 PM   #17
Top tip #17, always tape the area where you plan on drilling. This will help prevent the paint from chipping off when the bit starts to bite thru.
Top tip #18, measure twice and cut once.
Top tip #19, let someone else do it.
Old 04-28-2013, 11:39 AM   #18
Musskao's Avatar
If you have to drill, mine as well go all the way, and make it a functional scoop.. Just my 2 Pennies..
Musskao is offline   Reply With Quote
Old 05-01-2013, 01:53 AM   #19
Finished... Not as hard as I thought, but must be carful when making a stencil ..... Any comments? Or question ?
ID:	105376   Click image for larger version
Old 05-01-2013, 04:11 AM   #20
I love it! Makes it look mean. Performance white is the best color also.. Just my .02. Maybe you should slap a CDC chin on it. Here's what mine looked like when I had it and it would look even meaner with your hood scoop
Old 05-01-2013, 04:23 AM   #21
tc x 4's Avatar
Came out nice. Good job.
Old 05-01-2013, 07:31 AM   #22
Musskao's Avatar
Very nice.. Much more aggressive look... Good job..
Old 05-01-2013, 11:02 AM   #23
Evil2014GT's Avatar
Looks good
2014 Mustang GT Base MT82 -Stock 3.73s, Roush axleback, Steeda 93R tune, Steeda Hi-flow X-pipe, 19" Charcoal AMR's, smoked front and rear side markers, 20% tint, quarter window louvers, Steeda Ultralite springs, Koni Str.t shocks/struts, MM camber plates, J&M adjustable panhard bar, BMR LCAs and relo brackets, Barton shifter and 2-post bracket, Black Modern Billet Grilles
Evil2014GT is offline   Reply With Quote
Old 05-01-2013, 11:41 AM   #24
Thanks for the compliments everyone , that's the response I hoped for, ya I think the chin spoiler is next , but I do have a roush front chin a friend gave it to me , and was thing of saving up some cash and getting the roush front fasia and that on, but bumper alone untainted is like 599.99
Old 05-01-2013, 01:00 PM   #25
The roush front fascia is awesome looking. Stage 3 motorsports has the painted option ready to go with foglights for 780 something I believe. I would have purchased the roush fascia, but that's deep coin for just a front bumper. I ended up getting the boss fascia with fog lights and the splitter to go with it for half that price and love it!
Old 05-01-2013, 03:05 PM   #26
Boss facia is hott
Old 05-01-2013, 05:08 PM   #27
Rtr!
Moto111 is offline   Reply With Quote
Old 05-04-2013, 06:25 PM   #28
Rtr?
Old 05-04-2013, 07:51 PM   #29
RTR¿¡¥€¢£₩§
Old 05-04-2013, 08:01 PM   #30
MidnightBlueGT's Avatar
RTR¿¡¥€¢£₩§
I don't think that clarified lol
Old 05-04-2013, 08:03 PM   #31
Blogger
99ford's Avatar
Good job!! That looks awesome!!
Old 05-04-2013, 08:05 PM   #32
1lowGT's Avatar
Heck yeah that's awesome.
Old 05-05-2013, 10:56 AM   #33
CorDog009's Avatar
It looks good. I'm just not a big fan of non-functional scoops though. They just cause drag IMO.
'13 Deep Impact Blue GT, auto, BBK cat deletes, GT-500 A/B's, C&L tuned DiabloSport inTune, sound tube delete, BBK 85mm TB, JLT oil separator, NX plate kit.
CorDog009 is offline   Reply With Quote
02:24 PM
