Oil Separators - Mustang Evolution
Old 05-02-2013, 11:42 AM   #1
Jgray24's Avatar
Oil Separators
Well, I've got a pretty good idea of what they do, but how effective are they? And are they worth the money? Any info would be appreciated!
- J
Jgray24 is offline   Reply With Quote
Old 05-02-2013, 12:46 PM   #2
Evil2014GT's Avatar
- J
From what ive seen they are pretty effective. Most ive seen are collecting about a teaspoon or more between oil changes. I personally have not had much of a problem with mine yet, it barely collects anything at all, but i only have 3k on the car and have only performed 1 oil change so far.
As far as are they worth it? I say absolutely. $115 for a JLT isnt bad considering how much it could end up saving you further down the line.
2014 Mustang GT Base MT82 -Stock 3.73s, Roush axleback, Steeda 93R tune, Steeda Hi-flow X-pipe, 19" Charcoal AMR's, smoked front and rear side markers, 20% tint, quarter window louvers, Steeda Ultralite springs, Koni Str.t shocks/struts, MM camber plates, J&M adjustable panhard bar, BMR LCAs and relo brackets, Barton shifter and 2-post bracket, Black Modern Billet Grilles
Evil2014GT is offline   Reply With Quote
Old 05-02-2013, 01:41 PM   #3
nosympathy's Avatar
How about breathers instead? Oil seperators still let oil through, breathers do not! And 60$ for both sides instead of 120$ per side.
Old 05-02-2013, 01:44 PM   #4
Jgray24's Avatar
Never heard of breathers. How exactly do they work?
Old 05-02-2013, 01:59 PM   #5
Jetag93's Avatar
Yes on the breathers. When I checked my jlt seperator the line behind the catch can still had oil in it so they dont catch all of it. The breathers filters catch the oil and u just clean them once in a while without risk of oil into the intake.
2013 DIB Premium GT/CS, 6MT, Cervinis Ram-Air Hood, RTR Charcoal 19X9.5s, BBK Cat Deletes & X-Pipe, DMH E-Cutouts, GT500 Rear Diffuser w/GT500 Quad-tip Axle-Backs, AED E85 Lope Tune, Boss 302 Intake, BBK 85mm TB, JLT CAI, Dynatech Alum DS, FRPP 3.73's, Eibach Pro-Springs and Pro-Struts/shocks, J&M Adj Panhard Bar, UPR Billet Alum LCA's, BMR UCA & Bracket & Relo Brackets, Eibach Adj Sway Bars, MGW Shifter, Brembo brake kit w/14" slotted 2 piece Boogie Full Tilt Racing Rotors, Llumar 30/5 Tint
Jetag93 is offline   Reply With Quote
Old 05-02-2013, 02:03 PM   #6
Jgray24's Avatar
Can't seem to find them on american muscle or stage 3. Where did you order yours?
Old 05-02-2013, 02:11 PM   #7
nosympathy's Avatar
JPC racing. Lemme find the link.
http://www.jpcracing.com/2011-gt-boss-breather-package/
Old 05-02-2013, 02:17 PM   #8
Jgray24's Avatar
Now, these essentially work the same way an oil separator does (by allowing the gas built up by combustion to escape, while trapping the oil that is associated with this) but traps all of the oil instead of just a majority of it? Why don't more people use these? Cheaper and seems as though it does a better job. Also, what is the maintenance like? I'm sure the oil is trapped in the filter but do you replace it or just clean it out?
Old 05-02-2013, 02:23 PM   #9
nosympathy's Avatar
Yeah because the air doesn't get cycled through and you plug off the ends you'll have zero oil go through. Also they are just a standard K&N type filter. So cleaned with water, let dry, and then put them back on. Good to go!
They are not used a lot because they are technically not smog legal. Lol.
Old 05-02-2013, 02:26 PM   #10
Rosco's Avatar
My husky unit works very well for catch can unit. Doesn't let any oil through so far and has caught alot of oil since its been on for about 3k. Either way you go will be beneficial.
1998 Bright Atlantic Cobra - 3:73's, BBK ls, Pro 5.0, 96 Cobra STB, Borla XR-1 Catback, Custom Catch Can, Spec clutch, MM Firewall adj, FRPP wires, RSD, Spoiler delete, 245/275 BF Goodrich g sports on chrome 95 cobra r's
1998 V6 Mustang : SOLD!
Rosco is offline   Reply With Quote
Old 05-02-2013, 02:27 PM   #11
Jgray24's Avatar
Interesting, I've never heard of breathers but they seem to be the way to go. Any effect on performance? I wouldn't imagine so, but figured I'd ask. These seem to be more of a preventative measure, that way you won't get all of that excess oil all over the engine
Old 05-02-2013, 02:33 PM   #12
nosympathy's Avatar
No sir been running them maybe 2 months now with zero issues. I just don't see the point in $240 in oil seperators when you can get breathers for $60.
Old 05-02-2013, 02:35 PM   #13
Jgray24's Avatar
That's exactly what I'm saying...especially if they're more effective? Separators would just be a waste of money. Ford Racing Makes them as well at $20 a piece through AM. They look the same to me
Here's the link:
Ford Racing Open Element Mustang Breather Cap (79-14) M-6766-J302 - Free Shipping!
Old 05-02-2013, 02:38 PM   #14
nosympathy's Avatar
Here's the link:
I got the JPC ones because it is a complete kit. Comes with both breathers and both plugs for the manifold and CAI tube. Was just easier to do that then go to Lowes or where ever and search for correct sized ones.
Old 05-02-2013, 02:54 PM   #15
Ubnbit's Avatar
Sorry for the rookie question but what do they do? Could someone please explain it to me?
Old 05-02-2013, 03:02 PM   #16
nosympathy's Avatar
Long story short they keep oil from getting into your manifold and CAI tube/throttle body.
The stock PCV systems recycle air from the crank case and it often times has oil in it and this just goes straight into your manifold etc.
It won't make you more power or anything but is a preventive measure for the engine.
Old 05-02-2013, 03:09 PM   #17
Ubnbit's Avatar
Makes sense. Makes one wonder why they are not stock.
Old 05-02-2013, 03:18 PM   #18
Originally Posted by nosympathy View Post
Thanks for the link. Going to order this.
You got any pic's installed on your car. I would like to see how they look. With both of them.
racksteris is offline   Reply With Quote
Old 05-02-2013, 03:20 PM   #19
nosympathy's Avatar
Breathers for smog reasons but the seperators could be used. Good question to ask Ford haha.
---------- Post added at 05:19 PM ---------- Previous post was at 05:19 PM ----------
No problem! You'll be happy with them.
---------- Post added at 05:20 PM ---------- Previous post was at 05:19 PM ----------
Just saw you edited. Let me go take one. Since I don't have a full engine bay picture.
Old 05-02-2013, 03:28 PM   #20
Grabber Blue5.0's Avatar
I was one of the first to get them. They work better than the oil separators.
Name:	JPC Breather.jpg
Old 05-02-2013, 03:29 PM   #21
nosympathy's Avatar
Old 05-02-2013, 03:34 PM   #22
Nice
Thanks man I'm going to order it now.
---------- Post added at 05:34 PM ---------- Previous post was at 05:32 PM ----------
You should take out your sound tube, It will clean up you engine bay some more.
Old 05-02-2013, 03:43 PM   #23
nosympathy's Avatar
Yeah I am going too. I have saved what I need to get just haven't gotten around too it. Its on the list!
Old 05-02-2013, 03:55 PM   #24
I used rubber pads that go on large table foot to protect floors, To seal the firewall. There black and have a very strong stick on tap on the backside. I used 2. one on the inside and one on the out side.
BTW I just order the breathers. Thanks for that link.
Old 05-02-2013, 04:01 PM   #25
nosympathy's Avatar
No problem man! I have this saved and was gonna get these.
Old 05-02-2013, 06:31 PM   #26
By installing the breathers won't the filter get saturated with oil and leak onto the engine? Also you no longer have any type of suction valve to valve wouldn't that cause issues?
Mdazi is offline   Reply With Quote
Old 05-02-2013, 06:39 PM   #27
No to the first part, no idea what you're talking about on the second part.
Old 05-02-2013, 07:53 PM   #28
Lol, I meant to say vacuum, u no longer have a vacuum
Old 05-02-2013, 08:36 PM   #29
nosympathy's Avatar
Which isn't an issue. Me and grabber both been running them for a while, him longer than me and the car doesn't drive any different.
Old 05-03-2013, 11:31 AM   #30
Jgray24's Avatar
I'm going to order them as well. What's the smog issue with them?
Old 05-03-2013, 12:16 PM   #31
nosympathy's Avatar
If you live in an area that does testing. Just like removing the cats you can fail because of using them. I say can because I don't live in an area that tests so I don't know how much they pay attention.
Old 05-03-2013, 12:26 PM   #32
Tpost08's Avatar
I order mine the same time nosympathy order his. And put them on the weekend I got them. And have not had any issues either.
Tpost08 is offline   Reply With Quote
Old 05-03-2013, 01:27 PM   #33
Jgray24's Avatar
Ah I gotcha. I'm in sc so that shouldn't be a problem. And they really don't drop oil all over the engine compartment?
---------- Post added at 03:26 PM ---------- Previous post was at 03:22 PM ----------
Ah I gotcha. I'm in South Carolina and they don't do emissions inspections here. These things really don't drip or throw oil all over the engine?
---------- Post added at 03:26 PM ---------- Previous post was at 03:26 PM ----------
Ah I gotcha. I'm in South Carolina and they don't emissions inspections here. These things really don't drip or throw oil all over the engine?[/QUOTE]
---------- Post added at 03:27 PM ---------- Previous post was at 03:26 PM ----------
Ignore those other two edits, not sure what the app did there haha
Old 05-03-2013, 01:32 PM   #34
nosympathy's Avatar
Ignore those other two edits, not sure what the app did there haha[/QUOTE]
nope hasn't leaked oil anywhere at all.
Old 05-03-2013, 02:03 PM   #35
Napoleon85's Avatar
They can under certain conditions ... JPC all but talked me out of buying these from them for a street car for that exact reason.
01:31 AM
