Shaking Feeling while driving - Mustang Evolution
Old 05-05-2013, 04:22 PM   #1
92mustang2.3's Avatar
Any ideas on this I've balance the wheels a couple times already. And it's not all the time either. I have the shelby razor 245 35 20 in the front and 285 30 20 in the rears with Nittos 555 all around.
92mustang2.3 is offline   Reply With Quote
Old 05-05-2013, 04:27 PM   #2
nosympathy's Avatar
Are you lowered? Does it happen anywhere or just certain roads?
Old 05-05-2013, 04:31 PM   #3
Yes sir it's lowered with sr lowering springs
---------- Post added at 05:31 PM ---------- Previous post was at 05:28 PM ----------
Well i notice it at the track as well around 80 to 115
Old 05-05-2013, 04:34 PM   #4
nosympathy's Avatar
Ehh that's not enough of a lowering for what I was gonna suggest haha. I am lower and my car loves to pull all which kind of ways. I run bigger front tires than you to.
Could be the electronic steering control.
I mean mine does what your saying yours does, but only on certain sections of highway. Usually ones that have been worn down by semis real bad.
Old 05-05-2013, 04:36 PM   #5
And it's the hole car shaking not just the steering wheel just weird, I mean it could be the road but its newly paved.
Old 05-05-2013, 04:37 PM   #6
nosympathy's Avatar
The whole car, that is weird. I had a badly miss worn tire on my 2007 tundra do that. You don't have any flat spots on your tires do you?
Old 05-05-2013, 04:40 PM   #7
Not that I know of but it's weird that I'm going down the road and it will shake and then go away and them come back
Old 05-05-2013, 04:45 PM   #8
nosympathy's Avatar
Next thought, recheck all the bolts you took apart for the springs. Struts bolts, make sure the strut mounts and spring perches are snug. Etc.
Old 05-05-2013, 04:52 PM   #9
Alright will do, thanks for the help
Old 05-05-2013, 04:53 PM   #10
nosympathy's Avatar
Sure, doing what I can. If anyone else has any thoughts feel free to chime in!
Old 05-05-2013, 05:09 PM   #11
Stangfan21's Avatar
This is a long shot but you might have a bad u joint on your driveshaft those can cause intermittent shakes and it will shake the whole car
Stangfan21 is offline   Reply With Quote
Old 05-05-2013, 05:12 PM   #12
You know it has cross my mind that it could be driveshaft. I would love to have the one piece but that's out of my price range lol
Old 05-05-2013, 05:15 PM   #13
Stangfan21's Avatar
Ya add a little bit more torque with the one piece maybe your current one is unbalanced or something shakes like that are hard to track
Old 05-05-2013, 05:24 PM   #14
nosympathy's Avatar
Good call I wasnt even thinking that.
Old 05-05-2013, 08:20 PM   #15
Tinman124's Avatar
In my younger years I got a new set of tires. When I got home I checked the tire pressure "those jerks didn't fill the tires correctly" I thought to myself. Over the next few days at highway speeds the car shook like crazy. I took the car back to the shop told them what was going on. 10min. later he told me the tires were over filled. I then explained to him I filled them to what the tire said they be at. He informed me that that was the MAX pressure for that tire not the recommended pressure. Anyway, check your pressure I was amazed at the difference this made.
---------- Post added at 09:20 PM ---------- Previous post was at 09:18 PM ----------
Also if the lugs have been over tightened it can warp the rotors and cause a vibration.
Tinman124 is offline   Reply With Quote
Old 05-05-2013, 08:23 PM   #16
nosympathy's Avatar
Yes, the pressure listed on the side of the tire is the max pressure. I've had people on here try and tell me otherwise. Not many people but a few did.
Old 05-05-2013, 10:27 PM   #17
Evil2014GT's Avatar
Exactly what i was thinking. Had a similar problem with one of my f-bodies. Drove me crazy until i upgraded to an aluminum drive shaft and new u joints. After that problem solved.
2014 Mustang GT Base MT82 -Stock 3.73s, Roush axleback, Steeda 93R tune, Steeda Hi-flow X-pipe, 19" Charcoal AMR's, smoked front and rear side markers, 20% tint, quarter window louvers, Steeda Ultralite springs, Koni Str.t shocks/struts, MM camber plates, J&M adjustable panhard bar, BMR LCAs and relo brackets, Barton shifter and 2-post bracket, Black Modern Billet Grilles
Evil2014GT is offline   Reply With Quote
02:53 AM
