Lca install question - Mustang Evolution
Old 05-08-2013, 07:27 PM   #1
I was wondering if the rear tires need to be removed to install lower control arms. I can't find my lug nut key. i will be performing the install on a drive on lift. Thanks in advance.
Mdazi is offline   Reply With Quote
Old 05-08-2013, 08:19 PM   #2
blackbeast12's Avatar
Region: Delaware
Yes its easier that way!
2016 Gt/Cs autowith 3:55', mbrp cat back and a n/a build on the way!...
blackbeast12 is offline   Reply With Quote
Old 05-08-2013, 08:21 PM   #3
gtstyles2's Avatar
Yes they need to come off, and u also have to remove the parking brake cable since its held in the original LCA
Old 05-08-2013, 08:24 PM   #4
The Blue Dragon
GrabberBlue5.0's Avatar
I've never tried installing lcas with tires still on, but if you can lift the car and work underneath of it freely I don't see why not. I would definitely recommend taking the wheels off though
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 05-08-2013, 09:23 PM   #5
nosympathy's Avatar
Yeah I think it could be done. Just a royal PITA.
Old 05-09-2013, 02:39 AM   #6
Thomas11CS5.0's Avatar
Yes you need to take them off also before you unbolt the stock lca loop a ratchet strap around the rear axial then run the hook to the front tighten it down if you don't when you unbolt it the rear end will spring backwards and then you have to fight the rear end to put the new one in
Thomas11CS5.0 is offline   Reply With Quote
Old 05-09-2013, 02:47 AM   #7
It's not me, it's you.
primer2tone's Avatar
Even if you only do one side at a time? I figured if the upper and other side were still connected they'd hold it enough from moving.
Old 05-09-2013, 04:56 AM   #8
The Blue Dragon
Yea, the axle will still shift enough to be a total pain
Old 05-09-2013, 08:29 AM   #9
Well, tits.
Old 05-09-2013, 08:34 AM   #10
tc x 4's Avatar
I just had my 12yr old push on the axle.
04:14 PM
