Wheel off set - Mustang Evolution
Old 05-14-2013, 12:13 AM   #1
Davestanged's Avatar
Wheel off set
Ok so I'm looking to buy some wheels. Problem I'm having is off sets. What will fit and what won't. I have a 2011 gt and the wheels I'm looking at are 19x9.5 front with 41mm os, and 19x10.5 rear with 27mm os. Will these fit? And is it proper fitment?
Ps I did try looking this up first... All I came up with is preference.
I don't want much if any stick out
Davestanged is offline   Reply With Quote
Old 05-14-2013, 12:23 AM   #2
MELLOWYELLOW06's Avatar
your fronts should be ok
but rears will be out way too far
you need a +45 for the rears
Old 05-14-2013, 12:24 AM   #3
tc x 4's Avatar
Not sure on off set, but the max back spacing is 7.5"
Old 05-14-2013, 12:24 AM   #4
I can hook you up with some nice 19" avant garde or mrr rims
I have a guy that can get them to you at s great price
Old 05-14-2013, 12:25 AM   #5
Even with 10.5" rear?
Old 05-14-2013, 12:28 AM   #6
I have 20x10 1/2 +45 with 305/30/20
sits perfect
Old 05-14-2013, 12:35 AM   #7
Ok sweet.... Thanks
Old 05-14-2013, 07:10 AM   #8
jayman33's Avatar
Vossen's set up is great with their 20x10.5 in the rear however, I ran a 305/35 and I rub slightly but mellow would be right in the 305/30, it wouldn't stick out as much. Hankook makes a good set of tires at 255/35 for the front and 305/30 in the rear.
We run Avant Garde on our 13 Boss but its a square 19x9.5 setup, AG is still getting into the Domestic scene so their offsets, colors and sizing are a bit limited... but they're getting there, I've talked to them a few times and they plan on doing more. Take a look at acealloywheels.com and look at their new 2013 lineup both the Mesh 7's and convex are pretty nice. I test fitted the 19x10 square setup for them to make sure they fit the brembos and they fit perfectly. With the new Ace wheels this year I've sold a bunch of sets, they're very nice. Here are a couple pics of the AG's, Vossens, Forge stars and Ace wheels. I did this in hopes that Mellow yellow shows you some of his pics, lol. But hopefully this will help you out a little on some choices.
ID:	108028   Click image for larger version
ID:	108030   Click image for larger version
ID:	108032   Click image for larger version
ID:	108034   Click image for larger version
A boss.....
jayman33 is offline   Reply With Quote
Old 05-14-2013, 07:39 AM   #9
GE3G's Avatar
I just added Vossen 20" CV2 wheels.... 20x10.5 in the rear with 275/35ZR20 Hankooks and 20x9.5 in the front with 255/35ZR20 Hankooks
GE3G is offline   Reply With Quote
Old 05-15-2013, 01:40 AM   #10
How do 20's ride? My car is lowered a little.
Could I run 20x10 at all 4?
Old 05-15-2013, 07:45 AM   #11
jayman33's Avatar
You could run 20x10 on all four it just depends on offset, backspacing and wheel design. A concave wheel will not fit in the front without throwing some heavy camber and small tires.
A boss.....
Old 05-15-2013, 01:47 PM   #12
Would you know the specs by chance?
Old 05-15-2013, 11:48 PM   #13
Ok so rims: 20x10 with 40mm offset and 7.1in back spacing... Will these fit at all 4 corners?
Old 05-16-2013, 10:08 AM   #14
GE3G's Avatar
The 20s ride great... Although they are a tad rougher then the 19" Brembo wheels I had but the look of my new ones are ao much better...you could do a 10"
Old 05-16-2013, 11:02 PM   #15
Ok cool... What wheels are you running? (You should update your photos with your new rims)
11:23 AM
