Boss front splitter install - Mustang Evolution
Old 05-16-2013, 05:08 AM   #1
gtstyles2's Avatar
I've had it sitting in my garage for the past 2 weeks but I just haven't come around to installing it, but 1 thing that's very confusing is the instructions... Ford always does a lousy job of it by using cartoon images with no step by step description on how or what to do... Basically my first question is once its held by tape and getting ready to make the holes, should I mark the holes with the splitter on? Or just go ahead and make the pilot holes?? In the instruction, it looks like it shows to make the marks with a marker but I'm not sure since it shows zero description to what to do
Old 05-16-2013, 05:17 AM   #2
I taped/clamped mine on then drilled all holes and bolted/clipped it on.
WCatoe is offline   Reply With Quote
Old 05-16-2013, 05:30 AM   #3
gtstyles2's Avatar
Yea I figured it has to go that way but what exactly is this? A marker?? The lack of words kills me, since I dont wanna make a mistake
Old 05-16-2013, 05:35 AM   #4
You could mark all the holes, remove the splitter, then drill but it just seemed easier and made more sense to me to drill with the splitter as a template.
Old 05-16-2013, 05:48 AM   #5
It's not me, it's you.
primer2tone's Avatar
Yeah, I just taped mine up there and said, F the hardware! Blue painters tape is just as good!
Old 05-16-2013, 05:51 AM   #6
For the money to bad cant buy them as a kit with holes there already
Moto111 is offline   Reply With Quote
Old 05-16-2013, 06:31 AM   #7
nosympathy's Avatar
Hahahah. Should have used duct tape!!!!
Yeah I just taped my splitter down and drilled the holes.
Old 05-16-2013, 06:56 AM   #8
gtstyles2's Avatar
O ok, I tried to at least tape it up last night, since I saw my neighbor pass by and took advantage since I needed a second pair of hands to hold it up... Apparently the blue tape doesn't hold at all, maybe cuz the valence has a bit of Mothers Back to Black... So it's either remove it or find different tape
Old 05-16-2013, 07:02 AM   #9
Joyride's Avatar
I have some roush parts begging to be installed but roush keeps on adding time to the back order for LMR. It's been 4 weeks overtime now and still nothing has shipped.
Joyride is offline   Reply With Quote
Old 05-16-2013, 07:33 AM   #10
gtstyles2's Avatar
What did u get? The side splitters or front?? I also have the side splitters I have to install, I got it from AM about 2 weeks ago no problem
Old 05-16-2013, 08:13 AM   #11
Jetag93's Avatar
I hope u checked them for surface damage/scratches. My side splitters came from AM with severe scratches & had to send them back. Major bummer when u already have the driver side done & then realize the passenger side is screwed up! I had to drive around for a week with one splitter. Lol.
2013 DIB Premium GT/CS, 6MT, Cervinis Ram-Air Hood, RTR Charcoal 19X9.5s, BBK Cat Deletes & X-Pipe, DMH E-Cutouts, GT500 Rear Diffuser w/GT500 Quad-tip Axle-Backs, AED E85 Lope Tune, Boss 302 Intake, BBK 85mm TB, JLT CAI, Dynatech Alum DS, FRPP 3.73's, Eibach Pro-Springs and Pro-Struts/shocks, J&M Adj Panhard Bar, UPR Billet Alum LCA's, BMR UCA & Bracket & Relo Brackets, Eibach Adj Sway Bars, MGW Shifter, Brembo brake kit w/14" slotted 2 piece Boogie Full Tilt Racing Rotors, Llumar 30/5 Tint
Jetag93 is offline   Reply With Quote
Old 05-16-2013, 08:17 AM   #12
gtstyles2's Avatar
Yes!! That was the 1st thing I checked for, open the boxes as soon as I get em
Old 05-19-2013, 05:17 PM   #13
gtstyles2's Avatar
I'm installing the splitters as we speak, has anybody who installed the Roush side splitters had a problem with the rear section?? The part where it looks like a rear splash shield... It's not sitting right because of it
ID:	109103   Click image for larger version
Old 05-19-2013, 05:19 PM   #14
nosympathy's Avatar
Did you pull that piece off and cut it like the directions state?
Old 05-19-2013, 05:23 PM   #15
Being lowered, mine got torn off long before I installed my side splitters. Lop those *****es off and then party on!
Old 05-19-2013, 05:26 PM   #16
nosympathy's Avatar
They actually unbolt. Per the roush install instructions.
Old 05-19-2013, 05:34 PM   #17
F the bolts! I used pavement to remove mine!
Old 05-19-2013, 05:37 PM   #18
gtstyles2's Avatar
I didn't see that in the instructions
Old 05-19-2013, 05:38 PM   #19
nosympathy's Avatar
I'm at work now but I pulled them up on AM I believe and it said too do that.
Old 05-19-2013, 05:41 PM   #20
nosympathy's Avatar
Old 05-19-2013, 05:45 PM   #21
gtstyles2's Avatar
I had the crappy Ford instructions and it didn't show that... I don't see the bolt, I think it's under the actual splitter, I just ripped the dam thing off
Old 05-19-2013, 05:46 PM   #22
nosympathy's Avatar
Haha. Do what ya gotta do!
Old 05-19-2013, 07:09 PM   #23
Yup. Just pop them off.......this must be a good combo. I have the Foose Speed 20's, boss front/roush side splitters. At least we are different colors.
I saw another silver 5.0 with Foose speeds yesterday too.....looks like I need to order some more appearance mods.
Old 05-19-2013, 07:22 PM   #24
gtstyles2's Avatar
Yea I was kinda forced to rip them off since I already had the double sided tape that holds the splitter on... I kinda like how rare the Foose Speeds are
This was an all day thing for me, I did the front and side splitters and struggled to get clearance as I didn't have a lift trying to drill all the holes, I also was installing HIDs for the fogs 4500k 35w... I was a bit disappointed that it came out a bit bluer than the factory HIDs in the headlights
08:59 PM
