Ford Racing handling pack - Mustang Evolution
Old 05-19-2013, 07:35 AM   #1
BigP0314's Avatar
So if you buy the ford racing handling package will it require you to get new uca's and lca's like many people suggest when lowering your car?
BigP0314 is offline   Reply With Quote
Old 05-19-2013, 07:43 AM   #2
No...you don't need them. They are nice to have and serve a purpose, but not needed. The uca will fix pinion angle but unless your dropped super low your pinion angle should be fine. The cv joint in the drive shaft is able to accommodate minor adjustments.
Mikeyt03 is offline   Reply With Quote
Old 05-19-2013, 07:47 AM   #3
Jetag93's Avatar
Not required but a Uca w/bracket & lca's will eliminate wheel hop & help with traction.
2013 DIB Premium GT/CS, 6MT, Cervinis Ram-Air Hood, RTR Charcoal 19X9.5s, BBK Cat Deletes & X-Pipe, DMH E-Cutouts, GT500 Rear Diffuser w/GT500 Quad-tip Axle-Backs, AED E85 Lope Tune, Boss 302 Intake, BBK 85mm TB, JLT CAI, Dynatech Alum DS, FRPP 3.73's, Eibach Pro-Springs and Pro-Struts/shocks, J&M Adj Panhard Bar, UPR Billet Alum LCA's, BMR UCA & Bracket & Relo Brackets, Eibach Adj Sway Bars, MGW Shifter, Brembo brake kit w/14" slotted 2 piece Boogie Full Tilt Racing Rotors, Llumar 30/5 Tint
Jetag93 is offline   Reply With Quote
Old 05-19-2013, 07:52 AM   #4
jayman33's Avatar
OP I sent you a PM. The FRPP kits are pretty bad, they come with sway bars that are the same ones that they use for the 2005-2010 models and the dampers in the can't really handle the higher spring rate. There are much better options out there for about the same price if not possibly cheaper.
A boss.....
jayman33 is offline   Reply With Quote
Old 05-19-2013, 10:22 AM   #5
nosympathy's Avatar
+1
10:44 PM
