2012 gt with a gt 500 blower - Mustang Evolution
Old 05-22-2013, 03:06 PM   #1
White_coyote5.0's Avatar
Do any of you guys know if I can just add a stock gt 500 blower on my gt ? The kit come with
Blower
Throttle body
Injectors
Fuel rail
Pulley
Elbow.
Stock air box.
White_coyote5.0 is offline   Reply With Quote
Old 05-22-2013, 03:08 PM   #2
Joey8's Avatar
You can probably make it fit but it'll probably cost a bunch of money. That's coming off a 5.4 and you have a 5.0.
2014 Sterling Gray GT (Ordered1/24) (Built2/25) (ETA3/12) (Picked Up 3/21)l 443.9/417.8 l
l l 6 Spd l Prem Pkg l Nav l TP l LthrRecaros l AmericanRacing 1 7/8 LTs l O/R H l JLT CF CAI lVMP Tuned l BorlaS Quads w/ResDel. l GT500Valance l KoniStr.T l K-Springs l GT500 Mounts l BMR UCA&LCA l BMR Relos l BMR Panhard l SpeedDawg Knob l 5.0 LloydsMats l Redline HoodStrts l Bobs CF Oil Sep. l 15% Tint l CDC Grille l StrtScn2 ChinSpoiler l GT/CS Fogs w/4500k l RTR DeckLid l CF Engine/CoilCoversl
Joey8 is offline   Reply With Quote
Old 05-22-2013, 03:09 PM   #3
Very true
The guy is selling me everything for 700 shipped
So I thought it was a deal
Old 05-22-2013, 03:20 PM   #4
nosympathy's Avatar
Originally Posted by White_coyote5.0 View Post
Very true
Nope gonna cost you a fortune making it work for the 5.0 and we've had others ask the same thing. Not worth it.
Old 05-22-2013, 03:51 PM   #5
Davey13GT's Avatar
I've heard the Coyote can actually make more power with a blower than the GT500. Is that true?
Davey13GT is offline   Reply With Quote
Old 05-22-2013, 03:57 PM   #6
Venomouz831's Avatar
Which gt500? And depends on blower
)02 Gt, Founder of WE2G
Old 05-22-2013, 03:58 PM   #7
nosympathy's Avatar
well depending on which GT500 and it can safetly. The older GT500s werent as high revving as the 5.0 is. Most redlining at 6 and pushing past that was considered dangerous and a ticking time bomb. Where as we can push little over 7000rpm somewhat safetly.
Old 05-22-2013, 04:14 PM   #8
Napoleon85's Avatar
You can push a lot higher than that safely IMO.
Old 05-22-2013, 04:20 PM   #9
nosympathy's Avatar
you talking our 5.0 engine? honestly that isn't something I looked at. I assume a vortech or procharger with a boss intake could push to 7800RPMish no real trouble.
could a roush/whipple/etc. do so?
Old 05-22-2013, 04:48 PM   #10
The Blue Dragon
GrabberBlue5.0's Avatar
It would take a different lower intake manifold as the runners on the heads are different between the 5.0 and the 5.4. Check out departmentofboost.com if you're really serious about making it work. They specialize in making intake manifolds so the GT500 blower will fit on a 4.6, they may have something for the 5.0
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 05-22-2013, 04:49 PM   #11
The Blue Dragon
Mostly due to the compression ratio, the higher compression of the 5.0 produces more power per psi of boost than the lower compression of the 5.4
Old 05-23-2013, 07:02 AM   #12
Napoleon85's Avatar
What sits on top doesn't have much to do with how high you can rev safely. The issue you run into much over 7500RPM is that the oil pump gear can fail and the valve springs aren't quite heavy enough.
I guess it all depends on what you consider "safe" though.
10:44 AM
