Bolt Pattern - Mustang Evolution
Old 05-23-2013, 06:24 AM   #1
Ravnus's Avatar
Bolt Pattern
Does anyone know if rims from a 2006 are 5x114mm? My buddy has a set of Drag Radials that i wanna put on my 2011.
Ravnus is offline   Reply With Quote
Old 05-23-2013, 07:00 AM   #2
Abominable Mustang
WhoDat's Avatar
Region: Alaska
The bolt pattern on both the 2006 and your 2011 is 5x114.3mm
2012 Kona Blue 3.7L V6:
Old 05-23-2013, 07:17 AM   #3
tc x 4's Avatar
Bolt patterns are the same, if the wheels are 15", you'll need swaybar relocation brackets.
Old 05-23-2013, 08:04 AM   #4
Not necessarily. Depends on the offset and width. If they went on the 06, they'll probably go on the 11 just fine. 8" rim on stock swaybar locations, no problemo.
Old 05-23-2013, 08:18 AM   #5
Ravnus's Avatar
they are 295/45/17. Should clear sway bar. i was just curious about bolt pattern.
Thanx
Old 05-23-2013, 08:19 AM   #6
tc x 4's Avatar
Thanx
Your good then.
08:55 PM
