Just some information on CAI's - Mustang Evolution
Old 05-24-2013, 09:27 PM   #1
Just wanted to let you guys know I logged the IAT for the stock 2014 mustang GT 5.0L. No aftermarket CAI. Temps were consistently within 1-3 degrees of the outside air temp.
Of course at a stop they were much higher, but they dropped back to 1-3 difference within about 60 feet after beginning to move.
Other than having a shorter intake, or less restrictive which can be achieved with a filter swap for 40 bucks there is no reason I see in my mind to pay 400-500 dollars for a pipe and filter other than show.
Also putting a less restrictive filter may net you more power but 50K miles down the road you will have WAY more dirt and grime build up in your engine. The stock filter is the best filter.
Anyways I thought I'd chime in, feel free to blast away.
GWraith is offline   Reply With Quote
Old 05-24-2013, 10:15 PM   #2
This has all been proven already and there are like 800 threads on it. I'm not trying to bust your balls or anything, but many people know when buying a CAI for our cars will do little, if anything.
All the real power comes from ways of cramming air down the engines throat. You'd be far better off running a boss manifold if you're looking to spend that kind of money, and the boss manifold helps alot. Combine that, with a decent exhaust and tune and you'll make some respectable N/A power.
Old 05-24-2013, 11:19 PM   #3
TommyV's Avatar
They actually allow you to have a more aggressive tune. But it's mostly for looks.
'13 5.0 PW Premium / E-Force Supercharger w/ Brenspeed tune / FRPP Recaro's / GT500 quad exhaust / DSS Aluminum / Stop Tech 6P 15" / 13" rears / LP over axels / MGW / Moroso separator / 3:73's / Forgestar F14's 20x9/20x11 w/ Nitto Invo's 275/35's & 315/35's / Steeda Sport springs / Koni STR.T's / Steeda PHB / GT500 Spoiler / Roush upper and lower grills / Stillen front splitter / Boss steering wheel
TommyV is offline   Reply With Quote
Old 05-25-2013, 07:23 AM   #4
Depack21's Avatar
What about the ones that have larger tubes than the stock? That has to be better than just a drop in filter?
Depack21 is offline   Reply With Quote
Old 05-25-2013, 08:51 AM   #5
Davey13GT's Avatar
If a CAI doesn't provide much beneficial gain, than why does a tune require that you have a CAI?
Davey13GT is offline   Reply With Quote
Old 05-25-2013, 09:08 AM   #6
Mine changed the sound of my car which is good enough for me
And with a sc I can run another pound of boost due to cai
Moto111 is offline   Reply With Quote
Old 05-25-2013, 09:27 AM   #7
doug5.0's Avatar
I don't think it's a requirement to have a CAI in order to tune your car. It is, usually, required to tune if you have a CAI. That's because, as it was explained to me, the Engine is very sensitive to changes in air volume, and although it delivers more air, (enough air to require a tune), it is not so much more efficient then stock to produce a large and noticeable difference in HP as it did in previous engines, (4.6). That being said I have a C&L CAI, because I assumed when I first got the car that this would be the most logical and best "bang for the buck" mod. Although I like it and it sounds great, I may have chosen otherwise when first starting to mod.
CURRENT: 2016 GTPP, Vortech, Ford/Borla cat back, 1" drop on Vogtland, 1" Hubcentric spacers, APR Front Splitter, RTR Upper Grille.
SOLD: 2011 5.0, Auto, C&L CAI, Dyno Tuned, 3.73s, Boss 302 Intake, Magnaflow Competition axlebacks, Stallion Suspension LCAs, Whiteline Sway Bars.
doug5.0 is offline   Reply With Quote
Old 05-25-2013, 10:26 AM   #8
There is no tune that requires a cold air intake.
Mikeyt03 is offline   Reply With Quote
Old 05-25-2013, 10:47 AM   #9
Kona Mike's Avatar
Will you benefit from a tune on a stock 5.0 without getting a cai?
Kona Mike is offline   Reply With Quote
Old 05-25-2013, 10:58 AM   #10
LovinmyGT's Avatar
So I'm better off keeping my stock Cai and getting a boss intake manifold and tune it? Sorry to thread jack just getting ready to buy the boss power pack soon
LovinmyGT is offline   Reply With Quote
Old 05-25-2013, 11:13 AM   #11
alrefire's Avatar
Like an o/r midpipe
---------- Post added at 12:13 PM ---------- Previous post was at 12:11 PM ----------
Yes
If I had a GT my first mods would be boss intake manifold and a tune
Old 05-25-2013, 11:16 AM   #12
LovinmyGT's Avatar
Ok cool I was planning that but wasn't sure if I should get an aftermarket Cai with it
Old 05-25-2013, 11:30 AM   #13
doug5.0's Avatar
Absolutely
Old 05-25-2013, 11:33 AM   #14
Tunes are custom tailored to your mods. You could have every single bolt on minus a CAI and have your car tuned and vice versa. The reason a tune is required for a cold air intake is because the engine is very sensitive to the volume of air entering the engine and more importantly, how it is metered. Most cold air intakes either relocate the mass air sensor OR they place it in a larger tube which changes the volume of the airflow it has the potential to meter. Either one of those changes can greatly affect the sensor. Even just a slight degree rotation of the sensor from stock placement can cause idle issues and bucking under acceleration.
Point of the whole story is, the engine will only suck in so much air. I forget the formula, but I'm sure google would show you how to plug in the numbers and show the volumetric efficiency of the coyote motor. Allowing those numbers to increase, given any variable, would be what increases horsepower. A cold air intake could possibly increase the efficiency of the motor in higher rpms, and that will be where your gain is. But $ for $, you can find many other mods that get you the gain you seek.
Old 05-25-2013, 11:37 AM   #15
doug5.0's Avatar
Originally Posted by alrefire View Post
Like an o/r midpipe
Yes
That's my next mod too, however... Based on the posts I've seen performance from mods like the Boss IM, (or throttle body if you we're so inclined), is maximized with a CAI.
Old 05-25-2013, 11:50 AM   #16
My tuner told me I'll get an extra 10 ponies w/ a CAI. But the sound it added was the missing link in my setup. I ran a stock cai tune, and the aftermarket cai tune feels a bit stronger.
fun4me is offline   Reply With Quote
Old 05-25-2013, 11:57 AM   #17
doug5.0's Avatar
Possibly, I dyno tuned stock at 360rwhp, and added a C&L CAI and dyno tune and ended with 383rwhp. So a net 23 total for the tune and CAI. (2011 auto).
Old 05-25-2013, 12:09 PM   #18
tc x 4's Avatar
Was that on the same day, same dyno. And was the car tuned on the first run.
Old 05-25-2013, 12:20 PM   #19
doug5.0's Avatar
Next day, same dyno, 100% stock on 1st run. I realize there might be a small discrepancy due to weather, but its close enough for me.
Old 05-25-2013, 12:23 PM   #20
tc x 4's Avatar
The tune is where you picked up the majority of your gains.
Old 05-25-2013, 12:32 PM   #21
Whose tune?
Old 05-25-2013, 12:40 PM   #22
doug5.0's Avatar
Definitely, which is why I am not confirming or denying how much could be gained with a CAI. It would be interesting to see a base dyno run, against a no tune required CAI, against a tune required CAI. My guess is that max gain from a CAI falls between 5-10 rwhp. I would also wonder how much is gained with a Boss IM with and without a CAI.
---------- Post added at 11:40 AM ---------- Previous post was at 11:38 AM ----------
Whose tune?
The tune was done by GTR in Rancho Cucamonga, Ca. http://www.gtrhipo.com/
Old 05-25-2013, 12:45 PM   #23
Rynarok's Avatar
For funs, I started mine up in stock configuration while between bama tunes with the JLT CAI still installed. She ran like complete *****. ZLwhat is correct, the aftermarket CAI changes the location of the sensor, and you are introducing the engine to a larger volume of air - which requires a tune for it to account for.
All things considered, I do not believe that I wasted money on my CAI, especially since mine came as a combo deal with the SF3 tuner and free bama tunes for life. I think it would be more of a waste to buy one of the CAI kits that do NOT require a tune, because that's been shown to not be an increase over the stock airbox at all.
...If I had to do it over again, I'd have bought upper and lower control arms first though. These cars have plenty of power in stock trim, and controlling that wheelhop should've been my first priority.
Marcie; Black 2013 GT. MT82, .373, track + brembo, JLT CF CAI, Boss Manifold, MGW StS, Blowfish Trans Bracket & Driveshaft Loop, Whiteline trans bushing, RP motor & tranny oils, Flowmaster Outlaws, BMR UCA w/ mount, LCA w/ relo brackets, panhard, SR springs, KONI oranges, J&M CC plates, staggered leguna secas, MT street comps
***A good driver is the best method to get more performance out of any car. ***
AXLEBACKS THREADS =
Rynarok is offline   Reply With Quote
Old 05-25-2013, 01:02 PM   #24
doug5.0's Avatar
+1
Old 05-25-2013, 10:40 PM   #25
blackbeast12's Avatar
Region: Delaware
Peanut butter alone on a piece of bread is boring, doesn't do anything for me, add jelly and now you got something.
2016 Gt/Cs autowith 3:55', mbrp cat back and a n/a build on the way!...
blackbeast12 is offline   Reply With Quote
Old 05-26-2013, 12:14 AM   #26
Old 05-26-2013, 04:03 AM   #27
LovinmyGT's Avatar
Pp&j is good... But lunchables are better!
Old 09-13-2013, 12:13 AM   #28
DallasStang77's Avatar
I think all this talk about CAI being useful or not kinda loses focus on at which point of the project does it start showing compounded improvements.
What I mean is a CAI alone with even just exhaust and tune would probably be a waste of money because only so much air is able to be sucked in and exhausted by the engine. So the freer flow of the open filter is lost and unrealized.
However, if you start adding headers and straight pipes and upgrade to the Boss manifold, TB, and/or turbo/supercharge applications then no stock air box will provide the necessary flow.
So for relatively lightly modified cars the primary benefit of CAI is the under hood look and louder intake sound (which I absolutely love).
Old 09-14-2013, 12:50 PM   #29
Maverick2004054's Avatar
I believe this horse has been beaten to death, but once again the tune will be the reason why you pick up more HP. But with that being said, a tuner will have more freedom to produce more power with a CAI over the stock intake. Especially ones that are larger in diameter, this reduces turbulence in the pipe work, reduces velocity of air as well as increases volume to the next restriction I.e TB or Intake Mani. So if your goal is to combine the whole system to produce power, you will see a gain but it may not be noticeable until everything else is added to the mix! Laminar Flow + Volume - Velocity will always free up the ability to tune in more ponies!
Maverick2004054 is offline   Reply With Quote
04:36 AM
