Best Bang for Buck Brake Upgrade? - Mustang Evolution
Old 05-28-2013, 01:08 PM   #1
Sup fellow stangers,
What do you guys use for brake upgrades for non brembo cars, non track driven?
JayblesStang is offline   Reply With Quote
Old 05-28-2013, 01:10 PM   #2
Tmenzz's Avatar
Start with better pads, brake fluid, and maybe stainless steel lines. Then see how it goes. If you still get brake fade with that on the way you drive, get slotted rotors
Tmenzz is offline   Reply With Quote
Old 05-28-2013, 01:23 PM   #3
So which is a good pad and fluid to change to?
Old 05-28-2013, 01:34 PM   #4
Tmenzz's Avatar
Based on what you said you could try HPS brake pads and Amsoil series 600 dot 4 fluid
Old 05-28-2013, 01:41 PM   #5
Is it easy to bleed the brakes yourself?
Old 05-28-2013, 02:36 PM   #6
Blu13stang's Avatar
Fairly easy with a bleeder kit.
Blu13stang is offline   Reply With Quote
Old 05-28-2013, 07:56 PM   #7
BlackBetty5.0's Avatar
Getting the car and the wheels off is the hardest part of bleeding brakes, other than that its just kinda time consuming. Bleeder kits are ok but unless you are going to spend $50-100 on a pressure bleeder I would just used some tubing from home depot that will fit over the bleeder valves and an empty gatorade bottle.
BlackBetty5.0 is offline   Reply With Quote
Old 05-29-2013, 10:19 AM   #8
The Blue Dragon
GrabberBlue5.0's Avatar
Upgraded pads, SS brake lines and brake duct cooling kit as well as upgraded rotors. Should run about $7-800 if you do the work yourself.
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 05-29-2013, 12:27 PM   #9
Napoleon85's Avatar
Be careful with some of the higher end brake fluid. A lot of this DOT4 stuff is extremely hygroscopic and will need to be completely flushed (not just bled) every 6-8 months. It's also major overkill since it's unlikely you would be able to boil DOT3 on the street.
That said - HPS pads are a great choice for a daily driven car.
Not too bad from what I've heard. I just picked up a set of these to make things a bit easier.
Speed Bleeder Bleeding Brakes Bleeding Motorcycle Brakes Automotive Bleeder Screw Brake Bleeder
Old 05-29-2013, 03:08 PM   #10
tc x 4's Avatar
Do the front brakes on the 11+ cars need the compression tool, like on the 05-09s do.
Old 05-29-2013, 03:24 PM   #11
So the HPS are better than the ceramics for daily use?
Old 05-29-2013, 03:38 PM   #12
Napoleon85's Avatar
The fronts don't need it, but the rears do. I used the compression tool with an old pad to push in the twin calipers up front though ... it's a bit tough to do otherwise.
Old 05-29-2013, 03:50 PM   #13
tc x 4's Avatar
Thanks, guess I had it backwards.
Old 05-29-2013, 05:16 PM   #14
Blu13stang's Avatar
The kit you can get a Harbour Freight. Is good to have for the rear brake job. Otherwise you have to ratchet yourself silly to get the rear piston in far enough for pads to clear. Just my ¢.02
Old 05-29-2013, 05:34 PM   #15
nosympathy's Avatar
Have a link? I am gonna give my calipers a second coat and would like to take them off the car to really paint them perfectly. Didn't do it because of the pistons.
Old 05-29-2013, 08:41 PM   #16
Blu13stang's Avatar
This is the one I bought, it's got all the different stuff to fit different makes of cars.
http://www.harborfreight.com/18-piec...kit-69053.html
Old 05-29-2013, 08:48 PM   #17
nosympathy's Avatar
Sweet! Thanks man. 40 bucks ain't bad. Specially since I could use it on my truck too more than likely.
Old 05-30-2013, 06:06 AM   #18
Blu13stang's Avatar
Well worth the $40. No prob
Old 05-30-2013, 06:31 AM   #19
DWC_SmOziLLa's Avatar
I have this. It works great and it's under $10. I've used it on many different makes and models.
http://www.tooltopia.com/lisle-28600...FcqZ4AodO3wA9Q
Old 05-30-2013, 06:52 AM   #20
Napoleon85's Avatar
Well just keep in mind, it's from Hazard Fraught Tools so it will only work once - if that.
Old 05-30-2013, 07:49 AM   #21
Blu13stang's Avatar
That thing sucks. It didn't even fit the notches correctly luckily I had a grinder to modify the spikes on it. LOL it's a hazard to the knuckles.
Old 05-30-2013, 09:22 AM   #22
I've never had a problem with it. Lol
Old 05-30-2013, 10:07 AM   #23
Blu13stang's Avatar
Maybe I got the Chinese version. Lol
05:53 PM
