Do i need a Wheel alignment after installing new wheels - Mustang Evolution
Old 05-28-2013, 02:50 PM   #1
About a month ago I swapped out my wheels. I had the stock 18's, and I switched to a staggered setup with 245 40 19 up front and 285 35 19 in the rear. The car isn't pulling but I was wondering if I should get a alignment, Since i installed larger wheel and tires? Thanks
Mdazi is offline   Reply With Quote
Old 05-28-2013, 02:58 PM   #2
Napoleon85's Avatar
Do you need it BECAUSE you swapped wheels, no. Should you have gotten an alignment with your new tires to ensure proper wear, yes.
Old 05-28-2013, 06:49 PM   #3
blackbeast12's Avatar
Region: Delaware
I got the same sizes you did, if it was good with the previous set its good with the new set!
2016 Gt/Cs autowith 3:55', mbrp cat back and a n/a build on the way!...
blackbeast12 is offline   Reply With Quote
Old 05-29-2013, 09:36 AM   #4
Napoleon85's Avatar
Yes, if you are 100% sure your alignment was correct, and that your tires were wearing properly, you could skip getting one.
Old 05-29-2013, 10:31 AM   #5
acornsmoke's Avatar
I've heard from a shop if you keep the same size rim you'll be fine but if you get bigger or smaller rims you would be better off getting one. I don't know anything just by word of mouth.
acornsmoke is offline   Reply With Quote
Old 05-29-2013, 01:20 PM   #6
tc x 4's Avatar
Changing rim/tire sizes will not change a thing with your alignment. But as Napoleon said, a fresh alignment will protect your investment.
Old 05-29-2013, 02:21 PM   #7
DWC_SmOziLLa's Avatar
Investment, ha. I throw money at this car like its a stripper with a drug addition. I make it rain up in this biotch!
Old 05-29-2013, 02:24 PM   #8
Jetag93's Avatar
Ha ha. Mine seems like a high-dollar call girl!
2013 DIB Premium GT/CS, 6MT, Cervinis Ram-Air Hood, RTR Charcoal 19X9.5s, BBK Cat Deletes & X-Pipe, DMH E-Cutouts, GT500 Rear Diffuser w/GT500 Quad-tip Axle-Backs, AED E85 Lope Tune, Boss 302 Intake, BBK 85mm TB, JLT CAI, Dynatech Alum DS, FRPP 3.73's, Eibach Pro-Springs and Pro-Struts/shocks, J&M Adj Panhard Bar, UPR Billet Alum LCA's, BMR UCA & Bracket & Relo Brackets, Eibach Adj Sway Bars, MGW Shifter, Brembo brake kit w/14" slotted 2 piece Boogie Full Tilt Racing Rotors, Llumar 30/5 Tint
Jetag93 is offline   Reply With Quote
Old 05-29-2013, 02:50 PM   #9
MELLOWYELLOW06's Avatar
You shouldnt have to but if you feel alignment is off, it doesnt hurt to spens a few bucks of insurance to protect your new tires.
06:16 PM
