more parts ... obviously - Mustang Evolution
Old 06-01-2013, 10:03 AM   #1
acornsmoke's Avatar
Boss Intake + JBA o/r H going on + a dyno at the shop right now. I'll take a clip and some pics after aswell as some numbers!
acornsmoke is offline   Reply With Quote
Old 06-01-2013, 12:05 PM   #2
acornsmoke's Avatar
Old 06-01-2013, 01:11 PM   #3
Charlie_santos's Avatar
Originally Posted by acornsmoke View Post
What was the numbers it put down?
Old 06-01-2013, 01:22 PM   #4
nosympathy's Avatar
did they run it in 3rd gear......what it sounds like...also golly did it run forever through the rpm range....guessing because of what gear they ran it in. Even with an auto still should be 4th or 5th and I think they usually do 4th.
maybe I'm just thrown off but that was my car, in 4th (manual) because cincy speed is retarded spooling up to 7300rpm, and it does that way quicker than your car. Like I said guessing because of what gear they ran it in.
Old 06-01-2013, 01:34 PM   #5
acornsmoke's Avatar
put down 430 twice
---------- Post added at 03:34 PM ---------- Previous post was at 03:32 PM ----------
funny.... I'm not sure but it sounds like 3rd. they had a 2012 same everything but with long tubes and it only but out 430. they are confused as to why mine puts out as much HP as a car with Longtubes
Old 06-01-2013, 01:35 PM   #6
nosympathy's Avatar
put down 430 twice
do you have a manual or an auto?
Old 06-01-2013, 01:36 PM   #7
acornsmoke's Avatar
6speed
Old 06-01-2013, 01:38 PM   #8
nosympathy's Avatar
6speed
auto and manual are both 6 speed...lol...I assume you mean manual...your results are dramatically skewed if they don't run it in 5th, which is the 1:1 ratio.
Not that it really matters, but the results are still skewed.
Old 06-01-2013, 01:40 PM   #9
acornsmoke's Avatar
I'm going back Monday to get the papers for the dyno, and I should have just wrote manual but I figured you would get it. it was done at blow by racing and they've been there for yeaaaars so I assume they would do it correct but ill figure out what gear they pulled it in on Monday
Old 06-01-2013, 01:45 PM   #10
The Blue Dragon
GrabberBlue5.0's Avatar
You might be surprised
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 06-01-2013, 01:46 PM   #11
nosympathy's Avatar
I mean it really won't matter too much, it is just dyno numbers and yours don't really sound far fetched from your mods at all, but just one of those things that if you were too make any other changes later on down the road and redyno to see the changes made and they run it in 5th that time, your going to end up with badly corrupted data that can make you feel like you either made no improvement, made things worse, etc. depending on what 5th shows for numbers. I know for me 4th produced much lower numbers than 5th. Almost 40HP and 40 TQ difference same day about an hour apart. No idea what 3rd would do haha.
exactly why I made the shop that ran mine in 4th rerun it in 5th. I wanted to have a realistic number to attempt to compare too down the road when I make changes. So like when I add the Boss Mani here shortly I can roughly see how it affected my car. Different day/weather/etc. will still mess with the numbers but I can still see a rough change.
Old 06-01-2013, 01:49 PM   #12
acornsmoke's Avatar
gotcha. well they only made 2 runs and I get 3 so maybe on Monday ill get them to do another run( 5th ) and see what happens. numbers don't seem to far off tho, another buddy has a 13 same mods but with Longtubes and is pushing 450 from the same shop same dyno
Old 06-01-2013, 01:51 PM   #13
nosympathy's Avatar
Hopefully they are not running everyone's cars in 3rd . But I seriously think the numbers sound in line. I pulled 411HP with just o/r x and tune/cai.
Old 06-01-2013, 04:38 PM   #14
WadeC's Avatar
Not tring to thread jack but. I dont wanna start a thread for dumb question. Can anybody tell me what gear is recommended to dyno an auto?
WadeC is offline   Reply With Quote
Old 06-01-2013, 04:41 PM   #15
nosympathy's Avatar
Probably 4th since it is a little taller than a 1:1 and 5th is a .86:1 I think? I know 5th is less than a 1:1.
Edit:
4th is a 1.14:1 and 5th is a .87:1
Old 06-01-2013, 05:06 PM   #16
WadeC's Avatar
Edit:
My car was dynod in 3rd.
---------- Post added at 05:06 PM ---------- Previous post was at 05:03 PM ----------
How can i get it in 4th and lock it in to dyno it? Or is that done by computer?
Old 06-01-2013, 05:09 PM   #17
nosympathy's Avatar
You'd just keep accelerating the car like driving on the road until your car shifts into 4th then floor it from there.
Old 06-01-2013, 05:14 PM   #18
WadeC's Avatar
So put in drive and when it gets to 4th floor it?
Old 06-01-2013, 05:19 PM   #19
nosympathy's Avatar
Yeah I think you can back off a little to let it get to as low an rpm in 4th as possible then floor it.
Old 06-01-2013, 05:26 PM   #20
WadeC's Avatar
I will give this a try. Thank you sir
Old 06-01-2013, 07:19 PM   #21
The Blue Dragon
V6 gearing is longer than v8 gearing, 4th may be the proper gear for you
Old 06-01-2013, 07:31 PM   #22
nosympathy's Avatar
Old 06-01-2013, 08:58 PM   #23
The Blue Dragon
Weird, I'd never looked at the specs, 4th gear is shorter but 5th gear is proportionately longer. With that said 5th gear is closer to 1:1 than 4th
EDIT: I thought we were talking about a v6 on a dyno, that's why I was confused lol, either way 5th is still closer than 4th is to 1:1. Dyno in 5th, you want it as close to 1:1 as possible
Old 06-01-2013, 09:09 PM   #24
nosympathy's Avatar
Except everyone always wants to run them in 4th. I'd actually be interested to see an auto run in 4th and then in 5th and see what the numbers would be like.
Old 06-02-2013, 05:54 AM   #25
Grabber Blue5.0's Avatar
The autos get run in 4th gear and it needs to be locked there in a tune to keep it from shifting out.
Old 06-02-2013, 06:33 AM   #26
The Blue Dragon
Why would you run it in 4th if 5th is closer to 1:1? Is it because you don't want to use overdrive gears?
Old 06-02-2013, 06:55 AM   #27
OzzyLiriano's Avatar
Are you in Florida? Most likely you are..how much are they charging per pulls?
OzzyLiriano is offline   Reply With Quote
Old 06-02-2013, 08:14 AM   #28
4th gear is 1.14 and 5th is 0.87 so they are essentially even but yes 5th is an overdrive gear and it would be going 180 mph on the dyno and the numbers would really be skewed. Some tuners will actually dyno in 3rd because they cannot lock it in 4th with a tune.
Old 06-02-2013, 08:21 AM   #29
nosympathy's Avatar
4th gear is 0.87 and 5th is 1.14 so they are essentially even but yes 5th is an overdrive gear and it would be going 180 mph on the dyno and the numbers would really be skewed. Some tuners will actually dyno in 3rd because they cannot lock it in 4th with a tune.
Your 4th and 5th are backwards.
Old 06-02-2013, 08:48 AM   #30
Edited my post. That's what I get for not paying attention. Thanks.
Old 06-02-2013, 11:39 AM   #31
acornsmoke's Avatar
South Fl to be exact. and they charge 75$ per 3 pulls
Old 06-02-2013, 01:21 PM   #32
Not worth the drive, im in west kendall and i found a place down here, 100 for 3 pulls
04:50 AM
