Going up from a 9x19 wheel to a 9.5x19 worth it? - Mustang Evolution
Old 06-03-2013, 08:44 PM   #1
M3hunter's Avatar
Question Going up from a 9x19 wheel to a 9.5x19 worth it?
Is there any real benefit from upgrading from a 9x19 to a 9.5x19 wheel?
2011 GT Premium, Brembo, 3.73, KONI STRT, Steeda Sport springs, GT500 strut mounts, Strano's adjustable swaybars, 275/40R19 Michelin Pilot Super Sport, HAWK HPS, ATE DOT 4, CS style rear pedestal spoiler, AM Eleanor side scoops, "C style" side decals, Black BOSS style roof vinyl, black custom hood vinyl & Black pony.
M3hunter is offline   Reply With Quote
Old 06-03-2013, 08:46 PM   #2
im assuming the rear tire? if so yes, better looks and traction, 19x10 would be better, imo,..
Boss IM, with Araid cai, bama 93 race tune, GT500 cat back, jba off-road x-pipe & longtubes, mgw shifter,4.10 gears, Aluminum Flywheel & driveshaft, Adjustable Panhard Rod, BMR adj. uca & lca, BMR relo. brackets, BMR Springs with 1.5" drop, BMR adj. swaybar, BMR tubular K member 1/2 drop motor mounts & BMR tubular A arms, steeda alu. rad. support, aluminum water pump pully, 85mm BBK TB, Rear seat delete. Boss oil cooler, Battery in trunk. AC delete, Evap delete
brianw64 is offline   Reply With Quote
Old 06-03-2013, 08:52 PM   #3
M3hunter's Avatar
All tires same size
Old 06-03-2013, 08:55 PM   #4
currently I have 19x9 in front and 19x10 in rear, the rear needs the 10 for all the traction u can get for these cars, but i would like 9.5 in front, i like the look of a wider tire up frunt too
Old 06-04-2013, 07:02 AM   #5
The Blue Dragon
GrabberBlue5.0's Avatar
Originally Posted by M3hunter View Post
All tires same size
If you're keeping the same tire sizes you will see no performance benefit u less you're getting lighter wheels.
If you like the looks of the wider wheels more then you should upgrade, but have a wider wheel won't do anything for you by itself
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 06-04-2013, 07:51 AM   #6
KARgt13's Avatar
I just put on 9.5s all around with 275/40s and don't notice much of a difference. Probably will grip a little better. Haven't really paced the car though.
KARgt13 is offline   Reply With Quote
10:28 AM
