Fuel Injection Systems - Mustang Evolution
Old 06-05-2013, 08:35 PM   #1
80 LB/HR FUEL INJECTOR SET - Justin's Performance Center
Accel Super Mustang Coil On Plug Kit (11-14 GT) 140060-8 - Free Shipping!
So I was looking at changing the stock injectors and have done some searches on the forum and internet. From what i can tell you can expect 10-15 HP by adding new injectors. Then I was reading if you change the injectors you have to change the MAF, Is this the case? Also, there a direct way to figure out how much HP the injectors add.
For example on the 80lb/hr does that equal 8HP so a 10:1 ratio. Does anyone have experience with changing the stock injectors? is there really a noticable improvement? Of the above two which would be better?
5.0 2012 Mustang, Performance White, Rear Sensor Package, Roush Axle Back Exhaust, K&N Drop In Air Filter, JPC Breather Package
Tytus is offline   Reply With Quote
Old 06-05-2013, 08:48 PM   #2
Jetag93's Avatar
U won't see a benefit from larger injectors unless u go with E85 or FI. I installed the super coils but didn't notice much of a HP bump.
2013 DIB Premium GT/CS, 6MT, Cervinis Ram-Air Hood, RTR Charcoal 19X9.5s, BBK Cat Deletes & X-Pipe, DMH E-Cutouts, GT500 Rear Diffuser w/GT500 Quad-tip Axle-Backs, AED E85 Lope Tune, Boss 302 Intake, BBK 85mm TB, JLT CAI, Dynatech Alum DS, FRPP 3.73's, Eibach Pro-Springs and Pro-Struts/shocks, J&M Adj Panhard Bar, UPR Billet Alum LCA's, BMR UCA & Bracket & Relo Brackets, Eibach Adj Sway Bars, MGW Shifter, Brembo brake kit w/14" slotted 2 piece Boogie Full Tilt Racing Rotors, Llumar 30/5 Tint
Jetag93 is offline   Reply With Quote
Old 06-05-2013, 08:48 PM   #3
The Blue Dragon
GrabberBlue5.0's Avatar
Upgrading injectors without upgrading anything else will not yield any power gains. The stock 39# injectors are more than enough for any NA, bolt on, gasoline car. If you switch to E85 then upgrade to 47# injectors or if you get head work done and more aggressive cams I would look into slightly bigger injectors. The 2013 gt500 only has 55# injectors, trust me, those 80's will do absolutely nothin for you unless you go FI... And lots of boost at that.
New quick exhaust video
AUGUST 2012 MOTM!!!!
07:02 AM
