2012 LCA's - Mustang Evolution
Old 06-09-2013, 07:54 PM   #1
Tominkc's Avatar
Send a message via Yahoo to Tominkc
2012 LCA's
I hope I'm not overdoing this tread . But hot a question!! I have a 2012 GT, I've had it lowered about 1.25 " in the rear!! When I'm driving about 50mphs and down shift and step on. It the rear rand squats down and it takes off like a rocket. But after it Squats , it takes off but than the tires break lose than the RPM's shoot up real quick!! I Do still have the stock LCA's on.. Would install new LCA's and relocating brackets help out wit traction?
Tominkc is offline   Reply With Quote
Old 06-09-2013, 07:56 PM   #2
YES!!
Boss IM, with Araid cai, bama 93 race tune, GT500 cat back, jba off-road x-pipe & longtubes, mgw shifter,4.10 gears, Aluminum Flywheel & driveshaft, Adjustable Panhard Rod, BMR adj. uca & lca, BMR relo. brackets, BMR Springs with 1.5" drop, BMR adj. swaybar, BMR tubular K member 1/2 drop motor mounts & BMR tubular A arms, steeda alu. rad. support, aluminum water pump pully, 85mm BBK TB, Rear seat delete. Boss oil cooler, Battery in trunk. AC delete, Evap delete
brianw64 is offline   Reply With Quote
Old 06-09-2013, 07:56 PM   #3
It's not me, it's you.
primer2tone's Avatar
No. What kind of tires do you have?
Old 06-09-2013, 07:59 PM   #4
Aftermarket lca's reduce wheel hop at launch. Your problem isn't wheel hop, it's breaking traction at 50mph. Are you jumping off the clutch?
Old 06-09-2013, 08:11 PM   #5
Tominkc's Avatar
Originally Posted by primer2tone View Post
Aftermarket lca's reduce wheel hop at launch. Your problem isn't wheel hop, it's breaking traction at 50mph. Is your mustang auto or manual?
It's manual , and the stock tires, but it's been doing it ever since I lowerd it!! With new tires!!
---------- Post added at 09:08 PM ---------- Previous post was at 09:06 PM ----------
I am planning on getting wider tires for the back like 285's
---------- Post added at 09:11 PM ---------- Previous post was at 09:08 PM ----------
And no, I let the clutch out first than punch it!!! Like I said, the rear end squats down and it takes off but it's like I hit the power band, than that's it. No traction!!!
Old 06-09-2013, 08:19 PM   #6
Lca's & relocation brackets would be a good investment but it won't solve your problem as well as a nice fatter set of tires would. It looks like you're running the stock 18's. a 275 would go a long way to reduce spinning out. I'm running 275's and it made a huge difference in my launch and overall traction. I think the 18's are an 8 inch wide or 8.5 inch wide wheel. You might wanna double check that a 275 won't be too wide for that rim.
Old 06-09-2013, 08:33 PM   #7
Tominkc's Avatar
I have the 19x9.5 wheels!! I believe!! But they are the 19" rims!! I read on here someplace that 285's fit fine with no rubbing!!
---------- Post added at 09:28 PM ---------- Previous post was at 09:25 PM ----------
If you looking at my profile pictures, that's my first 2012 I had!! It was just a base Model, I now have the 2012 premium package!! With the 19" rims and tower brace in front!!!
---------- Post added at 09:33 PM ---------- Previous post was at 09:28 PM ----------
[QUOTE="Tominkc;1682897"]I have the 19x9.5 wheels!! I believe!! But they are the 19" rims!! I read on here someplace that 285's fit fine with no rubbing!!
If you looking at my profile pictures, that's my first 2012 I had!! It was just a base Model, I now have the 2012 premium package!! With the 19" rims and tower brace in front!! But I'm sure wider tires would really help!! From a dead stop and taking off, my rear end is all over the place, it even does it at a 10 mph roll than stomp on the pedal, it takes off but once I hit the power band, forget it, tires brake loose !! I know wider tires would help, but I was wondering if new LCA's and relocating brackets on the second hole would help at all!! Right know I get no wheel hop at all
Old 06-09-2013, 09:42 PM   #8
Oh, lol! You tricked me!
Yeah, go 285's bro! That'll eliminate your excess wheel spin.
Old 06-09-2013, 10:11 PM   #9
Evil2014GT's Avatar
Breaking the tires loose at 50mph??!!!!!! Sounds a little exaggerated to me!!!! Even with stock width tires!!!! What are you other mods??!!
2014 Mustang GT Base MT82 -Stock 3.73s, Roush axleback, Steeda 93R tune, Steeda Hi-flow X-pipe, 19" Charcoal AMR's, smoked front and rear side markers, 20% tint, quarter window louvers, Steeda Ultralite springs, Koni Str.t shocks/struts, MM camber plates, J&M adjustable panhard bar, BMR LCAs and relo brackets, Barton shifter and 2-post bracket, Black Modern Billet Grilles
Evil2014GT is offline   Reply With Quote
Old 06-09-2013, 10:34 PM   #10
tc x 4's Avatar
It doesn't to me, I've had mine come around at 60mph power shifting 2-3.
Old 06-09-2013, 10:36 PM   #11
Evil2014GT's Avatar
Really?? Guess i didn't drive mine long enough before the rim/tire upgrade haha. Had the AMR's on within 600 miles. Not to mention all the suspension upgrades i did at around 1200 miles.
Old 06-09-2013, 11:05 PM   #12
Mine has never lost traction at that speed so your not the only one. My car was getting pretty decent traction with just the stock wheels and tires. My car ran a 13.21 bone stock on the first run with street tires. Was able to knock out a 12.99 with 19" 2013 gt500 replicas and nitto invos. Now I have ford racing LCA's and I rarely ever lose traction. I lost traction the other night getting onto the highway while it was raining. I was in 2nd gear with a slow *** bus in front of me and was trying to go around him.
Old 06-10-2013, 03:30 AM   #13
tc x 4's Avatar
There could have been a little sand on the road,idk it was winter time on a country road. Trust me, 360s in a new car is not fun, some how I kept it on the road.
Old 06-10-2013, 04:37 AM   #14
I've broken traction going from 2-3. I don't know how fast but it definitely got squirrelly on stock 235's. Road condition plays a big part in these circumstances.
Old 06-10-2013, 05:10 AM   #15
Tominkc's Avatar
I have a SCT 93 race tune, LT Headers, Hi Flow Cats. Magnaflow comp series exhauste, lowered 1.25"
Old 06-10-2013, 05:10 AM   #16
audioAl's Avatar
Cool Brackets
Brackets will improve grip also wider tires.
2014 DIB 3.7 "Blue Cyclone" /Sold
2016 ruby red GT 300 A with 3.55:1 gear/SVE resonator delete X-pipe/ UPR catch can/Airaid/AEM/Steeda/ BMR CB005/BMR CB006 brace/BMR cc plates/SVE springs/
Old 06-10-2013, 05:12 AM   #17
Tominkc's Avatar
Thanks!! I knew wider tires would help, but wasnt sure about the LCA's and relocating brackets
Old 06-10-2013, 05:33 AM   #18
Do tires 1st. For a noticeable increase in traction.
Old 06-10-2013, 08:26 AM   #19
jayman33's Avatar
Tires will help next I would work on your UCA. Here are some videos of a guy that showed the flaws of the stock UCA. The third link (UCA) is the heart of your rear end (lol, I said rear end).
A boss.....
jayman33 is offline   Reply With Quote
Old 06-10-2013, 08:32 AM   #20
Dang, I only can chirp 3rd... Guess those performance mods really give it a huge kick to spin when you stomp it at 50...
Have you checked your tire pressure??
cstone94 is offline   Reply With Quote
Old 06-10-2013, 12:29 PM   #21
Tominkc's Avatar
Yes, I check them all the time plus I fill them with nitrogen so the pressure won't flex so much!!!
But thanks for all the help!!! I'll go with the wider tires first!! So, next question!! ( which I'm sure it's been ask a million times). What would be the best tire?
Old 06-10-2013, 12:37 PM   #22
Tominkc's Avatar
Thanks for the videos. Helps me understand what's going on under there when getting on it!! So I guess it's UCA's also !! Thanks again!!
Old 06-10-2013, 02:29 PM   #23
2013 Green GT's Avatar
Thanks for sharing the videos! I guess the UCA does more then I thought. How did you get those videos? What type/kind of camera did you use?
2013 Green GT is offline   Reply With Quote
Old 06-10-2013, 03:06 PM   #24
BigP0314's Avatar
I live in Italy where the roads are half step down from Ice when it rains and I have to baby it or they spin no matter the gear
BigP0314 is offline   Reply With Quote
Old 06-10-2013, 04:24 PM   #25
The next question would be... what UCA is best? Anyone run with 3rd Link Wheel Hop Reduction Kit for Mustang (2011-2014)
http://www.roushperformance.com/part....cwC6R4xr.dpuf
I like roush, but does it work in comparison to BMR or others with adjustment? I would love to hear feedback.
Old 06-10-2013, 04:35 PM   #26
Here's my suggestion. This is what's under my baby. http://www.mustangevolution.com/foru....php?p=1662079 If you are gonna buy these parts, you might as well get them together and save a jack load of money. And save even more by taking advantage of their online coupon.
Old 06-10-2013, 07:00 PM   #27
Tominkc's Avatar
Interesting!!! Sounds good!! But I don't have any wheel hop at all. From a dead stop or while moving and than flooring it!! Just no traction!!!
Old 06-10-2013, 08:14 PM   #28
IMO wheel hop is cause of an inexperienced driver. I've been clutching gears ever since I was tall enough to reach the pedal. I've had my '11 GT over 3 years and I've never once made the rear wheels hop coming off the line. It's all in the clutching.
Shredding tires through the gears, now that's a completely different problem and tires are gonna be the best thing to remedy that.
I've heard a lot of good things about the nitto invos but one of the down sides is getting them to last for more then 20k miles.
Old 06-12-2013, 08:09 AM   #29
Rynarok's Avatar
Somewhat of a sidetrack, but how much benefit would you see if you upgraded just the UCA and not the LCA's? Or is this something that you should do both at once and call it a day?
Marcie; Black 2013 GT. MT82, .373, track + brembo, JLT CF CAI, Boss Manifold, MGW StS, Blowfish Trans Bracket & Driveshaft Loop, Whiteline trans bushing, RP motor & tranny oils, Flowmaster Outlaws, BMR UCA w/ mount, LCA w/ relo brackets, panhard, SR springs, KONI oranges, J&M CC plates, staggered leguna secas, MT street comps
***A good driver is the best method to get more performance out of any car. ***
AXLEBACKS THREADS =
Rynarok is offline   Reply With Quote
Old 06-12-2013, 11:32 AM   #30
Tominkc's Avatar
That's a good question !! I would like to know also!! Anything that will help with traction!!!
Old 06-12-2013, 01:41 PM   #31
tc x 4's Avatar
If I were only changing one, and not both, I'd go with the lowers. Lowers will eliminate 90% of your problem.
Old 06-12-2013, 02:53 PM   #32
2013fiveO's Avatar
I did lcas first and they greatly improved traction but I still get a little wheel hop but no where near as bad as before. So I ordered some ucas that are supposed to really eliminate the wheel hop when combined with the lcas . I should have done them both at the same time.
2013 GT 6MT, 3.31s, Brembo Pckg, Sync
Mods: AED Tune,Boss 302 IM, BBK 85mm TB,Kooks SS Shorty Headers,HF Cats,Alum 1pc DS,Hotchkis Subframe Connectors,Steeda CAI,Roush Axlebacks,Barton Shifter,SR Clutch Line,Boss Oil/Trans Coolers,SVT Fan,Steeda Sport Springs/LCAs/UCA/Shifter Bracket/HD Motor Mounts,BMR LCA Relo Brackets,Koni Shocks/Struts,GT500 Strut Mounts,JLT Oil Sep,Hood Struts,GT500 Spoiler,MMD Taillight Trim,OEM Leather Seats,MT Street Comps on black AMRs,MT ET Street Radial IIs on black Bullits(track duty).
2013fiveO is offline   Reply With Quote
Old 06-12-2013, 04:51 PM   #33
jayman33's Avatar
This is an honest question but.... where did you here this? Have you experienced this yourself? LCA's operate more on a front to rear stress movement and not so much up and down. When moving up and down the primary piece involved is the UCA... now the rear joint in the LCA will move up and down while the body side is stationary. The biggest improvement to LCA's when comparing aftermarket to OEM are the bushings then of course the arm itself.
A boss.....
Old 06-12-2013, 07:01 PM   #34
ARfirefighter's Avatar
Region: Arkansas
I'm lowered on sportlines with BMR LCA's and relo brackets with factory UCA. I never had wheel hope before unless it was wet out. I'd spin like crazy though. Now it seems like the car just plants like its supposed to when I gas on it. Still plan on UCA in the future though.
ARfirefighter is offline   Reply With Quote
Old 06-12-2013, 08:08 PM   #35
In cold weather with the P-Zero's I broke the back end loose in 4th at like 4000 RPM ... true story.
But, it WAS nearly freezing. But, I wasn't expecting it!
mmike87 is offline   Reply With Quote
08:44 AM
