0-60 2013 automatic transmission - Mustang Evolution
Old 06-15-2013, 07:24 PM   #1
gtlovin's Avatar
I turn off adv traction control off put it in sport and I only hit 5.6-5-8 anyone know anything to do to lower that
gtlovin is offline   Reply With Quote
Old 06-15-2013, 07:27 PM   #2
86 muscle's Avatar
How are you launching? What rpm? Wheel spin? Current mods?
86 muscle is offline   Reply With Quote
Old 06-15-2013, 07:31 PM   #3
gtlovin's Avatar
No mods and no wheel spin
Old 06-15-2013, 07:38 PM   #4
86 muscle's Avatar
How do you launch n
Old 06-15-2013, 08:59 PM   #5
Twisted 13's Avatar
In my white one I went to the track bone stock. Took traction control all the way off, launched at about 900rpm, 1/4 tank of gas, spinning my a$$ off and cut a 5.49 on the best one. I left if in drive didn't do sport mode. The more empty the tank got the worse my times got obviously the less weight = more spin got harder to launch.
Twisted 13 is offline   Reply With Quote
Old 06-16-2013, 04:06 AM   #6
OzzyLiriano's Avatar
You pick up some serious power after the 60 foot, im going to check my times but i could swear im faster until ur 60 foot...5.49
Your a 13 auto aswell?
OzzyLiriano is offline   Reply With Quote
Old 06-16-2013, 08:13 AM   #7
Twisted 13's Avatar
Yupp automatic. I couldn't get my 60 foot any faster that night, I figured 2.1 wasn't bad on the gross pirellis.
Old 06-16-2013, 02:04 PM   #8
Ravnus's Avatar
Lower air pressure to 25psi. It should help. It did for me
Ravnus is offline   Reply With Quote
Old 06-18-2013, 08:21 AM   #9
Im pretty sure he is talking 0-60 mph not 60' times.
Brad598400 is offline   Reply With Quote
Old 06-18-2013, 08:40 AM   #10
2013mustang5.0's Avatar
My 0-60 on mt is only best of 5.2 seconds for Some reason and no wheel spin.....
2013 mustang 5.0 track pack(first mustang)
2013mustang5.0 is offline   Reply With Quote
Old 06-18-2013, 09:04 AM   #11
Sticky tires, and get a tune for the automatic. A tune for that thing will really wake up the shift points. Also throwing in an aftermarket stall converter will drastically lower your times but that will probably void the warranty so nogo there i suppose.
Old 06-18-2013, 09:11 AM   #12
I was able to get 2.066 on the crappy all season p. From the base model 18s with an elapsed time of 8.410 at 86 mph
Stock!
Old 06-19-2013, 07:10 PM   #13
Stock!
1/8 mile? i have a stick with full mods and m/t's 19's and my best run in the 8th was something like 7,94 @ like 90 or 91 cant remember exact time, but that was my first and only time at the track, but from what i hear those auto's are very consistant and fast with the right setup
Boss IM, with Araid cai, bama 93 race tune, GT500 cat back, jba off-road x-pipe & longtubes, mgw shifter,4.10 gears, Aluminum Flywheel & driveshaft, Adjustable Panhard Rod, BMR adj. uca & lca, BMR relo. brackets, BMR Springs with 1.5" drop, BMR adj. swaybar, BMR tubular K member 1/2 drop motor mounts & BMR tubular A arms, steeda alu. rad. support, aluminum water pump pully, 85mm BBK TB, Rear seat delete. Boss oil cooler, Battery in trunk. AC delete, Evap delete
brianw64 is offline   Reply With Quote
Old 06-20-2013, 05:29 PM   #14
Alkhalil's Avatar
I have MT and normally get 5.2. Best so far is 4.9 but that happened once. No stickies or mods
Alkhalil is offline   Reply With Quote
Old 06-21-2013, 08:39 AM   #15
CaliSpecial5.0's Avatar
The best I've done with the 2013 auto is a 5.5
CaliSpecial5.0 is offline   Reply With Quote
Old 06-21-2013, 02:28 PM   #16
Yes they are, next im doing 3.55 gears
Old 06-22-2013, 10:48 AM   #17
2011 Kona Blue's Avatar
I thought the stock 5.0's were running 4.3 to 4.4, 0-60 mph times. 5.5 runs seem really high for the 5.0?
Old 06-22-2013, 10:51 AM   #18
13 stang22's Avatar
I agree with that. if its a manual he may be new at shifting which is understanble and if it's an auto he may jus need a bama tune. then he will see mid 4s
13 stang22 is offline   Reply With Quote
Old 06-22-2013, 11:19 AM   #19
Just curious, what gear ratio do you have?
Old 06-22-2013, 02:13 PM   #20
Alkhalil's Avatar
With the stock auto, the second and third gears are low ratios. To improve 0-60, a final drive of 3.73 or better will definitely help. The stock is only 3.15.
Old 06-22-2013, 02:56 PM   #21
the problem is traction with these 5.0's a good set of sticky's will get you into the 4's, i wish i could find my slips, i made four passes and i know my 60' time was in the 4 second area but i think i tossed them
Old 06-22-2013, 08:00 PM   #22
I was still under the impression that a stock 5.0 with factory tires were running in the mid 4 second range for 0-60 mph.
Old 07-04-2013, 07:41 PM   #23
Mrc728's Avatar
Just hit 500 miles so just really starting to push her, hit 5.1 0-60 yesterday, best so far but that was not quite wot, I'm sure I could get under 5.
Mrc728 is offline   Reply With Quote
01:17 PM
