Eibach springs 2014 GT - Mustang Evolution
Old 06-21-2013, 05:32 PM   #1
Teebone's Avatar
I have had my new GT for a week 2014 track pack. My question is has anyone used the Eibach springs 1.5 drop with 19" wheels?
Also the camber bolts is there enough adjustment built into them?
This is a really good site with a ton of info hope its not a rethread I couldn't find any info on it
Teebone is offline   Reply With Quote
Old 06-21-2013, 06:03 PM   #2
I dont have a track pack but I have a 12 GT with 1.5 drop with camber bolts and 19's zero issues, they arent eibach springs
Boss IM, with Araid cai, bama 93 race tune, GT500 cat back, jba off-road x-pipe & longtubes, mgw shifter,4.10 gears, Aluminum Flywheel & driveshaft, Adjustable Panhard Rod, BMR adj. uca & lca, BMR relo. brackets, BMR Springs with 1.5" drop, BMR adj. swaybar, BMR tubular K member 1/2 drop motor mounts & BMR tubular A arms, steeda alu. rad. support, aluminum water pump pully, 85mm BBK TB, Rear seat delete. Boss oil cooler, Battery in trunk. AC delete, Evap delete
brianw64 is offline   Reply With Quote
Old 06-21-2013, 06:11 PM   #3
JKTek's Avatar
I'm having the eibach pro kit plus suspension set put on my 2013 gt vert in a couple of weeks. Ordered the camber bolts as well. I'll post pics of it after its done, oh and I also have 19's...
JKTek is offline   Reply With Quote
Old 06-21-2013, 06:21 PM   #4
Tpost08's Avatar
I believe the 1.5 is the pro kit. I was told that with those and a panhard bar I would be alright. I'm not look for any performance gain right now just the dropped look. (Due to money). I'll be running with 20's. so you should be alright.
Tpost08 is offline   Reply With Quote
Old 06-21-2013, 08:32 PM   #5
Teebone's Avatar
Thanks yes the 1.5 drop is the pro kit. I used these springs many moons ago on a 95 cobra they were great no bouncing no rubbing great ride. Hope they work the same as they did then if not better.
Old 06-21-2013, 08:57 PM   #6
JKTek's Avatar
Actually forgot to write, yes I'm also doing the steeda adjustable pan hard bar as well. The kit comes with the struts and shocks, so should improve the handling as well as the lowered stance.
Old 06-21-2013, 10:42 PM   #7
Tpost08's Avatar
Yeah. I'm just getting the springs. Then the whiteline panhard bar.
Old 06-21-2013, 11:04 PM   #8
JKTek's Avatar
I figured I'd invest the money and do the whole kit, I'm sure there are other pieces to the puzzle to get, but one thing at a time...well a few pieces at a time with the kit at least lol. I'll let you know how I think the ride changes once its done.
Old 06-22-2013, 12:43 AM   #9
Tpost08's Avatar
Sounds good.
Old 07-20-2013, 02:04 AM   #10
JKTek's Avatar
Pics! Picked it up from the shop yesterday just before it stormed. Definitely could tell the difference in feel, not harsher at all, just less roll in the corners, and much better handling. Really happy so far. Cant wait to get it on the road again today!
ID:	119451   Click image for larger version
Old 07-20-2013, 02:26 AM   #11
Tpost08's Avatar
Looks real good man. I ended up going with the eibach sportlines and koni shocks and struts adj panhard and camber plates. I'm hopefully installing in about 5 hours. Imma be tired. But got a buddy helping me.
Old 07-20-2013, 02:40 AM   #12
Jedimindtricks's Avatar
Looking Nice and low
Jedimindtricks is offline   Reply With Quote
Old 07-20-2013, 05:55 AM   #13
JKTek's Avatar
Thanks man. Yeah i had thought about the sportlines, but so many damn potholes out here and I got a bad back lol. Good luck on the install! Post some pics when its done.
Old 07-21-2013, 09:32 AM   #14
Alkhalil's Avatar
You should consider soon an adjustable upper control arm to correct the pinion angle. Dropping the car will increase the angle between the differential and the rear drive shaft. I have struggled with clunk noise and still suffering.
Alkhalil is offline   Reply With Quote
Old 07-21-2013, 11:06 AM   #15
Deerslayer's Avatar
Yes, we installed the Eibach pro -1.5" with the panhard bar and this GT had the track pack: here is the stance with 19" wheels:
2013 GT : 6sp MT, Track Pkg, 3.73 Rear End, Brembo Brakes, Vortech V3 SC, Boss IM, BBK 90mm TB, JLT CAI, ID1000 injectors, BAP, Brisk Plugs, Tial BOV, Lethal OR X Pipe, 3" over axle to GT500 Quad Exhaust, Dynotech Alum DS, MGW Shifter, Eibach R2 Coil Overs, Bob's Billet LCA's, UPR adj. UCA, Eibach Adj PH Bar, TruCarbon Carbon Fiber inside/out. Tuned by Jon Lund II Three salvaged Bosses worth of Parts live on in this car. 705.11rwhp 5.33pulley/Torque Booster Wastegate
Deerslayer is offline   Reply With Quote
Old 07-21-2013, 11:11 AM   #16
love it
Old 07-21-2013, 01:31 PM   #17
Teebone's Avatar
That's sweet looking!!!!!
Old 07-23-2013, 02:29 PM   #18
bellski's Avatar
I have Eibach ProKit setup on mine and am running 20's (11" rear with 315/35's) and have absolutely zero rubbing. I did install an adjustable panhard bar to center the axle up. You won't have any rubbing problems.
Name:	North Carolina 07-12 010.JPG
2011 GT M6 Premium- Mechanical upgrades include: Boss 302 Intake, JLT CAI, JPC LT Headers, Off Road X Pipe, and mufflers, 410 Gears, Granatelli Hot Street Coil Packs, 93 Octane Ghost Cam Tune by Jon Lund,Eibach ProKit Springs,shocks, struts and sway bars, BMR LCA's, Strut Tower Brace, and adjustable Panhard Bar, Maximum Motorsports Camber/Caster Plates, Barton Shortshifter and bracket, Wilwood Superlight Brakes w/6 and 4 piston calipers, Steeda Spyders- 9-1/2X20 with 275/35 and 11X20 with 315/35 Nitto Invos.
bellski is offline   Reply With Quote
Old 07-23-2013, 03:47 PM   #19
Tpost08's Avatar
Oh yeah. Forgot. Sportline kit with 20's and only 10" on the backs.
ID:	120111   Click image for larger version
Old 07-23-2013, 04:29 PM   #20
GE3G's Avatar
Eibach prokit with BMR Panhard bar and UPR Lower control arms
GE3G is offline   Reply With Quote
Old 07-23-2013, 06:38 PM   #21
Tpost08's Avatar
What spoiler do you have??
Old 07-24-2013, 05:45 AM   #22
GE3G's Avatar
GT500 spoiler pre painted from American Muscle
Old 08-27-2013, 11:17 PM   #23
Filth and Fury's Avatar
Seems like alot of people do the pro kit with stock shocks and struts, anyone know if that is a decent ride? I was planning on koni oranges. Ive also heard that with a mild drop the pro kit provides your pinion angle isnt affected too harshly. Does anyone know?
2013 Performance White GT/CS - Borla S-Type - Redline Hood Struts - Wincos Tint - Next Up: Full Suspension
Borla Exhaust Review: http://www.youtube.com/watch?v=5eZpnBuQiag
GT500 Muffler sound clip: http://www.youtube.com/watch?v=tkGKwxQkTc8
Filth and Fury is offline   Reply With Quote
Old 08-28-2013, 05:32 AM   #24
gtstyles2's Avatar
I have the Pro Plus kit that comes with shocks/struts and they're not too bad but if I were to do it over I would have gotten the Koni orange... And the the GT500 mounts for the front only because I heard that's a great setup... My setup right now is good but i know it can be better
Old 08-28-2013, 07:38 AM   #25
Tpost08's Avatar
You can always go better. I got the koni orange and wish I would have waited and gotten koni yellow. Haha. You feel everything. But, your either doing it for racing or looks. Not for comfort.
Old 09-15-2013, 08:53 PM   #26
DallasStang77's Avatar
Man that's slammed! Love it. Seems like its actually lowered better than mine. I have the sportlines but even with 285/30/20 it seems like it has a slightly larger gap on mine.
Guess what they say each car drops differently.
Great job nice looking car!
Old 09-15-2013, 09:01 PM   #27
Here's my car and the sportline drop. Actually it looks pretty slammed in pictures after all lol XD
ID:	129129   Click image for larger version
Old 09-16-2013, 05:31 AM   #28
Lawrence's Avatar
Really leaning towards these springs. What's the drop in inches for the back? Some sights say 1.5" others say 2.6" just want to clarify. Thanks.
Lawrence is offline   Reply With Quote
Old 09-16-2013, 06:25 AM   #29
gtstyles2's Avatar
Sportlines look awesome!! But u got balls parking over that curb lol
Old 09-16-2013, 06:43 AM   #30
If hes clearing parking blocks, the front is about 1.5 any lower abd he wouldn't clear them.
Mikeyt03 is offline   Reply With Quote
Old 09-16-2013, 07:34 AM   #31
Supposedly it's a 1.3" front and 2.0" rear drop.
Yeah for the most part I clear curbs. A 1.3" isn't a low drop. Most newer parking lots have I think a standard thickness in curb height and no problems here.
Some people say its a smooth ride though stiff. For the most part it's smooth and can take small imperfections well but it's when you hit some wavy parts of the road is when you start feeling like a boat because the stock struts are overpowered and can't dampen the spring rates.
The rear feels a bit more poised dealing with the ups and downs.
Changed out the LCA and added a relocation bracket. Slightly less bounce especially in the back I guess cause the slop is gone from the rubber bushing.
Get the sportlines. I think you would eventually enjoy it more. I do... Everytime I drive the car and everytime I walk to and from the car and everytime I get a thumbs up. =)
Old 09-16-2013, 10:10 PM   #32
Did you install a camber plate or bolt? I didn't but took it to two alignment shops and not said my alignment is within spec.
I got the Sportlines with a 1.3" front drop. From what I remember not shop gave the same degree on the camber.
Your front tire looks almost like it has 0 camber while mine looks a bit tilted inwards.
Old 09-17-2013, 11:09 PM   #33
Did you install a camber plate or bolt? I didn't but took it to two alignment shops and both said my alignment is within spec.
Sorry second paragraph didn't make sense. Stupid iPhone correction.
"I got the Sportlines with a 1.3" front drop. From what I remember [both] shops gave the same degree on the camber [after the drop]." Said camber is within spec.
Old 09-18-2013, 01:15 AM   #34
Rselsing's Avatar
So from what I'm reading I'm gonna need a lot more things then just the springs for the lowering kit huh. I was looking at lowering spring and it drops 1.5 all around. Would the car be fine just lowering it with that or will I need all that your talking about?
Rselsing is offline   Reply With Quote
Old 09-18-2013, 03:13 AM   #35
Tpost08's Avatar
1.5 I would say is where you need I start looking at stuff to go with it. And I would really suggest camber plates instead of bolts. And also some shocks and struts. Because (from what I was told by a lot of people) you are goin to wear the stock shocks and struts out quick with that much of a drop.
10:39 AM
