2013 brake fluid leak - Mustang Evolution
Old 06-23-2013, 07:42 AM   #1
CaliSpecial5.0's Avatar
Hey guys,
Just wanted to let you know about my issue so you can check yours bc as I'm sure you know brake fluid eats through paint. I have a 2013 CS GT with less then 5k miles on it I brought new in Dec. my brake fluid is leaking out of the reservoir where the top and bottom attach, my guess is a bad o-ring. I wipe down my engine everytime i wash it and thought it was dirt build up until I stuck my finger into the groove and came back with oil, checked the rest of it and its been leaking for some time....not cool.
CaliSpecial5.0 is offline   Reply With Quote
Old 06-23-2013, 07:46 AM   #2
George T's Avatar
Thanks for the info. I've had my 2013 for 4 months, just noted that the pinion seal in dripping, going to dealer tomorrow to fix.
George T is offline   Reply With Quote
Old 06-23-2013, 11:54 AM   #3
Grabber Blue5.0's Avatar
What you are seeing is probably just normal seepage which master cylinders are known for.
Old 06-23-2013, 12:05 PM   #4
Um, that's crap. First of all it's not the booster, its the master cylinder. Master cylinders are not "known for" seepage. if you have liquid brake fluid there you have a leak in a primary safety system and it will get worse. I changed out many, many, many MCs in 30 years of doing this and I've never had one have "normal seepage" on anything from a 60s 4 drum car to a modern car with ABS and TC. Seepage up top at the lid = guaranteed water contamination in the future, leaks below indicate a potential brake failure situation in the making.
Old 06-23-2013, 04:50 PM   #5
Had my pinion seal replaced at 5k miles
buschris is offline   Reply With Quote
Old 06-24-2013, 05:19 PM   #6
Blu13stang's Avatar
Yeah really explain that one ?
Blu13stang is offline   Reply With Quote
Old 06-24-2013, 06:37 PM   #7
Umm...I don't think so.
Mikeyt03 is offline   Reply With Quote
Old 06-24-2013, 07:01 PM   #8
EricJames's Avatar
My 14 GT and my dads 13 GT both had the same problem. I read online that the new ones got overfilled and they boil over.
EricJames is offline   Reply With Quote
Old 06-25-2013, 10:19 AM   #9
BIGHOSS5.0's Avatar
We are talking about a Mustang...Not a Harley Davidson
BIGHOSS5.0 is offline   Reply With Quote
Old 06-25-2013, 10:28 AM   #10
I guess no one does maintenance and checks their fluid levels
Old 06-25-2013, 10:54 AM   #11
BIGHOSS5.0's Avatar
check all of mine every Saturday morning. Nothing out of the ordinary so far. 2012 with 15k miles
Old 06-25-2013, 11:25 AM   #12
Lol!
Old 06-25-2013, 12:06 PM   #13
Mine doesn't leak either. I don't think I've ever seen one leaky at all
Old 06-25-2013, 02:37 PM   #14
Thanks for the clarification. What would I do without you.
Old 06-25-2013, 05:42 PM   #15
gtstyles2's Avatar
I've heard from a few ppl at local shows that some master cylinders are leaking on some 13 and newer models
Old 06-25-2013, 07:28 PM   #16
BIGHOSS5.0's Avatar
I know, I know...I'm fixing the worlds problems from my computer, one at a time
Old 06-26-2013, 05:46 AM   #17
bucko's Avatar
Hopefully they finished the sentence about how they took it in for warranty work to get it corrected.
Old 06-26-2013, 04:05 PM   #18
I have an appt to take it in for this and two other issues already, I'll try to remember to get back on here and let you all know what they say.
Is there 2011 and up common issues thread yet? I tried searching for one even before I bought my car and the only thing I rally saw was the Chinese manual tranny problem.
Old 06-26-2013, 04:32 PM   #19
gtstyles2's Avatar
Yea leaking brake fluid definitely sucks it melts paint which really sucks if its in the engine bay, I've watched mine and it seems fine so far... Mines a 2011
Old 06-27-2013, 02:25 AM   #20
MedxGT's Avatar
As it was explained to me, you should not be adding any brake fluid. The level works down to the 'low' level, as pads are worn down on the disk brakes. When the brake indicator light comes on (from low fluid), it's time to change the pads (and IMO the fluid too).
MedxGT is offline   Reply With Quote
11:31 PM
