So frustrated, don't know what else to do - Mustang Evolution
Old 06-24-2013, 05:52 PM   #1
Jsmorley81's Avatar
Ok, so I know there's a million threads on this and trust me I've read them all and have done all I can do. But after installing both upper and lower control arms plus upper control arm bracket. Torqed all bolts "several times". I'm still hearing that f@$&>%g clunk coming from the rear suspension. It happens when hitting bumps, hitting the gas from a dead stop or while moving. I've got j&m lowers and steeda upper with the j&m upper bracket. I don't know what else to do. I've double and triple checked all bolts and its still there. Some one help before i just take it all off and go back to stock. What am I doing wrong here?
---------- Post added at 06:52 PM ---------- Previous post was at 06:50 PM ----------
And looks to me like the lower control arms are moving which is where a think the popping noise is coming from. But I torqued them all down to 130 ft. Lbs. so I don't know. Any one else have this problem?
Jsmorley81 is offline   Reply With Quote
Old 06-24-2013, 06:01 PM   #2
GE3G's Avatar
If u have a pamhard bar check the nuts... Mine came alttle loose and and damn did this noise annoy me
GE3G is offline   Reply With Quote
Old 06-24-2013, 06:33 PM   #3
xxPIKExx's Avatar
My panhard bar came loose as well. Every little bump caused a rattle. Tightened it back up, no more rattle
xxPIKExx is offline   Reply With Quote
Old 06-24-2013, 06:37 PM   #4
mine made a noise and i ditched the torque wrench I tightened them suckers as tight as i could get them, i had a clunk when i took off or bump from rear drivers side, then after i tightened it was gone
Boss IM, with Araid cai, bama 93 race tune, GT500 cat back, jba off-road x-pipe & longtubes, mgw shifter,4.10 gears, Aluminum Flywheel & driveshaft, Adjustable Panhard Rod, BMR adj. uca & lca, BMR relo. brackets, BMR Springs with 1.5" drop, BMR adj. swaybar, BMR tubular K member 1/2 drop motor mounts & BMR tubular A arms, steeda alu. rad. support, aluminum water pump pully, 85mm BBK TB, Rear seat delete. Boss oil cooler, Battery in trunk. AC delete, Evap delete
brianw64 is offline   Reply With Quote
Old 06-25-2013, 06:09 AM   #5
GE3G's Avatar
Mine was exactly like that.... A speed bump didnt make as much noise but a pot hole or crack in the road or even minor bumps would drive u crazy
Old 06-25-2013, 09:10 AM   #6
Evil2014GT's Avatar
Im in the same boat man. Although mine is pretty faint. Ive also checked all bolts and have found no problems. Im lost.
2014 Mustang GT Base MT82 -Stock 3.73s, Roush axleback, Steeda 93R tune, Steeda Hi-flow X-pipe, 19" Charcoal AMR's, smoked front and rear side markers, 20% tint, quarter window louvers, Steeda Ultralite springs, Koni Str.t shocks/struts, MM camber plates, J&M adjustable panhard bar, BMR LCAs and relo brackets, Barton shifter and 2-post bracket, Black Modern Billet Grilles
Evil2014GT is offline   Reply With Quote
Old 06-25-2013, 08:22 PM   #7
Jsmorley81's Avatar
well I finally found out what it was. I ordered my J&M upper control arm bracket from ebay from the seller named "modifymystang" in his posting it clearly stated that it fit the 2011 gt Mustang 5.0... so I bought it the upper stock oem bolt under the seat did not fit the bracket, so I thought that I would have to buy one. so thats what i did. It was much smaller than the oem bolt, being a 14mm. come to find out after calling J&M tech line, that J&M does not even make a bracket for 2011 plus mustangs.. thank god I talked to him. he was super helpful.. so I want to say to all If you own a 2011 plus mustang do not purchase any J&M control arm upper bracket off ebay or any where for that matter. after pulling it off I noticed it was not an EXACT fit but it was so close you can not tell.. I just noticed all the wear marks on it from where it was and was not touching the car.. pulled it out and put factory back in untill I get my new one from steeda.. Talked to the seller on ebay. he said he thought they would fit any model and that J&M's website just updated the info on their site so he had no clue it would not work. not buying that line. but at least he is going to refund all money.... it has been one hell of a big hassle, but so glad the damn clunk is gone and I can have some peace now while driving. good thing I found out before that little 14mm bolt I put in there broke off or I probably would not be here to write this........
Old 06-25-2013, 09:36 PM   #8
Evil2014GT's Avatar
Wow man, glad you figured it out. And before anything serious happened. Thats scary stuff, especially with a UCA. As you said that could have really messed you up. Im with you, and not buying the sellers line. Another reason why i will never buy a serious component like that off ebay. I would report him to paypal or ebay, just to make sure he didnt pull the same stunt with other buyers.
Old 06-26-2013, 12:05 AM   #9
Put loctite on all your bolts & nuts too...I've had control arms come loose before...pretty scary!
Grey 2011 GT Brembo, 3.73, ARH LT headers, catted x-pipe, Borla GT500 A/B, JLT cf CAI, MGW shifter, SCT, tuned, Boss oil cooler, Ford Racing springs & adj shocks, GT500 strut mounts, Steeda adj panhard/upper & lower arms. Roush 18x10" wheels with PS2 fronts, R888 305's rear. Eibach GT500 adj swaybars, Boss IM/Strut bar/steering wheel, Ford Racing 90mm TB, GT500 wing, BMR relo brackets, DSS aluminum driveshaft, Cervini Cobra R hood, 2014 GT500 headlight & rear end retrofit...
Matt K is offline   Reply With Quote
Old 06-26-2013, 12:57 AM   #10
Tyoung68's Avatar
Never use the green one... Unless you never want to take the bolt off
Old 06-26-2013, 05:27 AM   #11
tc x 4's Avatar
Yep, green loctite is considered permanent, I use it on internals.
Old 06-26-2013, 02:53 PM   #12
Napoleon85's Avatar
I'm just going to chime in and say it was probably a bad idea to mix&match manufacturers on the UCA and UCA mount as well. I would buy this as a matched set only. I suspect a lot of the clunking is from using an aftermarket UCA on the stock mount, or using someone elses mount on an aftermarket UCA.
I know the UPR UCA and mount are designed to work together, and I know the mount is different because the UCA comes with sleeves that you have to put in if using the stock UCA mount. I also know mine does not clunk, at all. Coincidence? I think not.
09:47 PM
