Well trying to work a kink I just installed the vortech as we know but know having issues . When coming off throttle and putting car in neutral and slowing down the car dies and the little battery light come up meaning car died lol it smells really rich when it does and it will fire right back up. Also when the ac is on full blast it gets worse like it wants to die and idles really low . I checked the vaccum lines and everything is tight . I have no idea what to do
Your maf is more than likely fine. Just needs tuning adjustment to your idle air. Went through same issue and know several other sc guys that have to. Tune just needs tweaking.
---------- Post added at 09:47 PM ---------- Previous post was at 09:45 PM ----------
Op, clean out your pm box. Just tried to send you a message
I did and brenspeed is tweaking it and going back and forth with me and it only happens after car is warm and 10-15 mins of being run . Also the ac practically makes car stutter and lights flicker and idle bounces like crazy from 500-780
You can keep it from dying if you let the rpms down while in gear. Like if coming to a stop whe in fourth just let yourself get down to say 10 mph before throwing it in neutral. It can be annoying but it'll keep the car running.
Ya ya but what's done is done and if a Dyno tune doesn't fix it blower is coming off and in trading in car that's how pissed I am . Shouldn't be one issue after another the vortech tune should have been fine why else would they send it
This has turned into a friggin nightmare for you. I know we all want to learn and be able to say " I did this myself "
But this is why you pay a professional to install and tune something. Because if something goes wrong it's their problem and you don't take your car off their property till it's done and done right.
Those plugs are likely on the front of the cylinder heads right where the main bracket for the vortech would have bolted in. You could have knocked one loose while bolting that stuff on.
Related Threads
Mustang Evolution Forum
2.1M posts
50.8K members
Since 2003
