Front Springs - Mustang Evolution
Old 07-13-2013, 08:32 PM   #1
OzzyLiriano's Avatar
Front Springs
Is their any springs that lower the car less than 1" inch in the front?
I heard boss oem springs are lower than gts, would those fit my car?
OzzyLiriano is offline   Reply With Quote
Old 07-13-2013, 08:34 PM   #2
Redstang1's Avatar
No I don't think there is but even if there was it wouldn't be worth the money and time to put them on
Redstang1 is offline   Reply With Quote
Old 07-13-2013, 11:57 PM   #3
Evil2014GT's Avatar
Yeah. 1 inch is like the minimum. Why do you want such a small drop anyway. Im failing to grasp the point.
2014 Mustang GT Base MT82 -Stock 3.73s, Roush axleback, Steeda 93R tune, Steeda Hi-flow X-pipe, 19" Charcoal AMR's, smoked front and rear side markers, 20% tint, quarter window louvers, Steeda Ultralite springs, Koni Str.t shocks/struts, MM camber plates, J&M adjustable panhard bar, BMR LCAs and relo brackets, Barton shifter and 2-post bracket, Black Modern Billet Grilles
Evil2014GT is offline   Reply With Quote
Old 07-14-2013, 01:58 AM   #4
His body kit prevents a larger drop.
Mikeyt03 is offline   Reply With Quote
Old 07-14-2013, 04:03 AM   #5
Exactly, only thing i can do is either just drop the rear one inch and call it a day, or put in the boss oem springs in the front. Anyone know if the brembo track pack springs are any different from the stock gt?
Old 07-14-2013, 04:04 AM   #6
No drop and im running 275/35/20 in the front!
Old 07-14-2013, 07:35 AM   #7
When I first lowered my car last year I went with the roush suspension kit and it lowered it about 3/4 in front and 1 inch rear it wasnt enough so I went with BMR, but I still have the springs if your interested.
Boss IM, with Araid cai, bama 93 race tune, GT500 cat back, jba off-road x-pipe & longtubes, mgw shifter,4.10 gears, Aluminum Flywheel & driveshaft, Adjustable Panhard Rod, BMR adj. uca & lca, BMR relo. brackets, BMR Springs with 1.5" drop, BMR adj. swaybar, BMR tubular K member 1/2 drop motor mounts & BMR tubular A arms, steeda alu. rad. support, aluminum water pump pully, 85mm BBK TB, Rear seat delete. Boss oil cooler, Battery in trunk. AC delete, Evap delete
brianw64 is offline   Reply With Quote
Old 07-14-2013, 08:14 AM   #8
Pm me the price and model number because i didn't know they had those, and ive looked everywhere
Old 07-14-2013, 09:28 AM   #9
gtstyles2's Avatar
I think u can s get away with an inch drop in the front, just make sure wherever u go, u always back into parking spots and come into angles on speed bumps and driveways and u should be fine
Old 07-14-2013, 09:30 AM   #10
Evil2014GT's Avatar
Ahh gotcha. Didnt know he had a body kit. Car looks great!
Old 07-14-2013, 10:04 AM   #11
Yeah but i could do that, i could but that would mean im 3 1/2 off the ground and ive already scratched the bottom
Old 07-14-2013, 10:12 AM   #12
gtstyles2's Avatar
Yea I hear u, I believe u have another DD, maybe depending where your going, u use that... I guess it's easy for me to say since I drive the DD 90% of the time... It's rough around my area, and I really don't NEED the Stang but I still love it
Old 07-14-2013, 07:06 PM   #13
I was going today to several apartments and my lip was about 2 1/2 inches to 3 from the floor, if only there was a one and a half drop!!!!!!!!!!!
Old 07-19-2013, 09:25 AM   #14
So after a lot of research I found out that the hieght difference between the boss and a gt up front is 11mm, which is a great approx. 1/2 drop up front.
So I will be getting those leaving me a 4 1/2 clearance on the sides of my splitter and in the middle of the of the splitter 3 3/4
On the rear ill be doing p spring
With my koni yellows and steeda heavy duty mounts
Already have bmr lca and bmr relocation brackets and bmr panhard bar installed
And to fill the gap even more on the rear I'm changing the rear nitto invos 295/35/20 to 305/35/20 nitto 555r
I can finally do a happy dance!
Old 07-19-2013, 09:32 AM   #15
Evil2014GT's Avatar
Those tires aren't going to fill the gap anymore. They both have a 35 sidewall.. Unless for some reason the invos run thinner..
Old 07-19-2013, 09:36 AM   #16
Wider on my rim will make it taller, idc if does or not, my car is black, it looks dropped and its not
Old 07-19-2013, 09:38 AM   #17
Evil2014GT's Avatar
What size rim?
Old 07-19-2013, 10:01 AM   #18
What size rim?
20x11
Old 07-19-2013, 10:09 AM   #19
Evil2014GT's Avatar
20x11
It may help a very little bit. But a 305 is not going to bulge barely at all on a 11 inch rim. Mine barely bulge on a 19x10.
Old 07-19-2013, 10:13 AM   #20
A 305 tire is taller. It'll take up some gap, but Ozzie...you've got a 20x11, just go with a 315-35-20 invo. That tire is made for a 20x11 rim. It fits perfect.
Old 07-19-2013, 10:22 AM   #21
Evil2014GT's Avatar
Im seriously doubt you are going to notice much hieght difference, if any at all by going from a 295 to a 305. Especially sticking with the same manufacturer. But i agree, go with 315.
Old 07-19-2013, 11:05 AM   #22
I would but they i want the 555r and they are only built to 305, nitto street radial 315 is really meant for drag and with all the raining in south florida i really dont want to end wraped around a tree
Old 07-19-2013, 11:26 AM   #23
Nt05R might come wider
Old 07-19-2013, 11:37 AM   #24
Evil2014GT's Avatar
Thats what i was thinking too. But he said he wants something that is decent in the rain. Ozzy check out the regular nt05 tho.. It comes in a 315/35/20. Sick looking tire IMO.
http://www.nittotire.com/Tire/nt05
Old 07-19-2013, 12:20 PM   #25
Are this better than 555r?
Old 07-19-2013, 12:30 PM   #26
Evil2014GT's Avatar
Well if you want good wet weather performance, the 555r is not gonna be a good choice either. Its a street radial. You would want the regular 555 which i dont believe comes in a 305. I think a 285 is the biggest. The nt05 does however come in a 315. Both are great tires. I personally like the look of the nt05 better.
Old 07-19-2013, 01:39 PM   #27
I knew that but nt05r are NOT meant for any rain....ill look into them and do my research vs 555r, thanks for the info tho
Old 07-19-2013, 02:25 PM   #28
Evil2014GT's Avatar
Thats what im saying the 555r's are not meant for rain either. The "r" is basically the race tire. The nt05r and the 555r are both street radials and will equally suck in the rain. If you're looking for a good wet tire you need the regular 555 or nt05. Cant go wrong with either one. But the regular 555 does not come as wide as you want it.
09:58 PM
