Rear Axle Fluid Change at 3,000 Miles???? - Mustang Evolution
Old 07-15-2013, 04:13 PM   #1
ford302ize's Avatar
Hey, I have a 14' GT Manual and the owners manual says that the rear axle is lubricated for life, but further down the page it says that it should be changed every 3,000 or 3 months in extreme conditions. I rarely drive the car hard, but I live in GA and the temperature is sometimes over 90 in the summer. The page number in the manual that came with my car is 333, also it is online at owner.ford.com under the owner's manual 1st printing (also page 333). How should I deal with this? I just rolled over 1,000 miles and had the oil changed. If someone could clear this up I would appreciate it.
My Toys. 2014 GT Base with Manual Trans. Borla S-Type Axle Backs. 2005 Honda VTX 1300C.
ford302ize is offline   Reply With Quote
Old 07-15-2013, 04:31 PM   #2
tc x 4's Avatar
Lol Georgia isn't extreme by any means. The om is referring to something in mud or desert conditions.
Old 07-15-2013, 05:12 PM   #3
throw in some royal purple and its good, not to mention a better oil
Boss IM, with Araid cai, bama 93 race tune, GT500 cat back, jba off-road x-pipe & longtubes, mgw shifter,4.10 gears, Aluminum Flywheel & driveshaft, Adjustable Panhard Rod, BMR adj. uca & lca, BMR relo. brackets, BMR Springs with 1.5" drop, BMR adj. swaybar, BMR tubular K member 1/2 drop motor mounts & BMR tubular A arms, steeda alu. rad. support, aluminum water pump pully, 85mm BBK TB, Rear seat delete. Boss oil cooler, Battery in trunk. AC delete, Evap delete
brianw64 is offline   Reply With Quote
Old 07-15-2013, 08:12 PM   #4
Ftodaro's Avatar
Do you have a Torsen LSD or open diff.
The Torsen is bullet proof. No clutches, just helical gears. Ford uses synthetic fluid, unless you are, road racing, dragging or auto crossing frequently, once per year or 12,000 miles is safe.
Frank
2014 GT, Track Package, Deep Impact Blue. Roush Axle back, MGW short shifter.
Ftodaro is offline   Reply With Quote
02:25 AM
