Front end noise - Mustang Evolution
Old 07-15-2013, 09:18 PM   #1
Front end noise
I have gt500 mounts, and they squeek like a mother f****** when there is suspension travel at low speeds. When I do CPR on my front end I can hear my passenger side mount squeaking but in the car sometimes it sounds like both sides are squeaking.
Please tell me there is a fix for this because I literally want to punch a hole in my dash whenever I go under 30 miles an hour. What should I trouble shoot? Are these things Greasable? Maybe the spindle nut is loose? Frustrated : (
Mikeyt03 is offline   Reply With Quote
Old 07-15-2013, 09:34 PM   #2
BlackFiveOh813's Avatar
There is a technical service bulletin out by for for 11-13 Mustangs front lower control arm hydro bushings, that has to deal with suspension noise at low speeds over things like speed bumps and what not, if thats the case Ford should replace them for free
BlackFiveOh813 is offline   Reply With Quote
Old 07-15-2013, 10:20 PM   #3
It's not that. I had that issue too, but it's not the same sound. Unless lowering my car made the sound different. They replaced the drivers side lca and not the passenger side. So that's initially what I thought. But it didn't start really until I lowered my car. I'll have ford check it out, but I think it's my mounts.
Old 07-15-2013, 10:57 PM   #4
Evil2014GT's Avatar
Im sure you did, but did you use the stock lower spring isolators from the stock springs? If not that will definitely cause squeaking.
Other than that, double check the front strut bolts, as well as the sway bar end link bolts. If you reused the original bolts, make sure to put locktite on them, as they can back out. According to Ford they are all one time use bolts. But most of us (myself included) reuse the stockers and just add locktite.
2014 Mustang GT Base MT82 -Stock 3.73s, Roush axleback, Steeda 93R tune, Steeda Hi-flow X-pipe, 19" Charcoal AMR's, smoked front and rear side markers, 20% tint, quarter window louvers, Steeda Ultralite springs, Koni Str.t shocks/struts, MM camber plates, J&M adjustable panhard bar, BMR LCAs and relo brackets, Barton shifter and 2-post bracket, Black Modern Billet Grilles
Evil2014GT is offline   Reply With Quote
Old 07-15-2013, 11:06 PM   #5
Isolaters are on. Locktite in all bolts, but I'm going to have my shop check the torque specs again. It's a very rubbery squeak. Definitely not metal on metal.
Old 07-15-2013, 11:11 PM   #6
Evil2014GT's Avatar
Hmm. Did you get new struts as well?
Old 07-16-2013, 12:17 AM   #7
Yup koni strt
Old 07-16-2013, 12:29 AM   #8
Evil2014GT's Avatar
Are you sure your not just hearing the sound of the strut compressing? I have thr str.ts as well, and i have definitely noticed they are louder when compressed then the stock struts. It does sound like a rubber rub a bit.
Old 07-16-2013, 01:01 AM   #9
No I'm sure. I hear it over bumps too.
Old 07-16-2013, 06:13 AM   #10
Phoenix335's Avatar
I have this as well, I think it is the sway bar bushings.
Phoenix335 is offline   Reply With Quote
Old 07-16-2013, 07:11 AM   #11
It has to be my strut mount. If it were my sway bar I would heard it before my suspension install.
Old 07-16-2013, 09:00 AM   #12
My dash will have a hole in it by the end of the week if I don't figure this out.. I'm thinking about just dropping it off to steeda and having the put in the HD mounts.
Old 07-16-2013, 09:54 AM   #13
Evil2014GT's Avatar
Cant go wrong with steeda or maximum motorsport plates. Thats weird the GT500s are making noise so quick though. Maybe you got a bad set.
11:49 PM
